The big change here is full support for Kodi 15 Isengard.
Addressed issues since 3.1.0:
- Support for Kodi 15.
- Drop support for TvTunes (see: http://kodi.wiki/view/Add-on:TvTunes#TvT...rs_Only.29).
- Fix VideoExtras button for TV Shows.
- Move TV Show Next Aired info to Video Info dialog.
- Allow removal of Settings shortcut.
- Show IMDb Votes (green) Media Flag if not in Top 250 (gold). Configurable.
- Don't hide widget when submenu is focused on Default Home Layout.
- Mouse support for seekbar.
- Update PVR dialogs.
- Show date and time the addon repository was updated in Addon Browser.
- Add button to check for repository updates for addons.
- Add Poster Fixed Large viewtype.
Yeah baby now that's what I am talking about
Metropolis getting better and better!!!
Thanks Jingai
should you install from zip, or place in directory manually?
I am not seeing "TV Show Next Aired" info anywhere in the latest build.
Where did it go?
If it was moved I can not find it and I kind of liked where it was already.
Look at the release notes in the first post
(2015-10-10, 15:55)jingai Wrote: [ -> ]Look at the release notes in the first post
I did but perhaps I am doing something wrong.
Just to be sure how do you bring up the Video Info dialog?
Hit the I key on any item in the tvshow library.
(2015-10-10, 16:40)jingai Wrote: [ -> ]Hit the I key on any item in the tvshow library.
But I use a remote like 99% of the time.
Ok I got it now
I can use the remote after all.
I bring up a context menu and select TV Show Information and Next air date is right there near the bottom
Thanks again.
Jingai,
Is there any chance at all that you could include "OSD Commend Labels" that MacGyver created in his mod builds?
I know maybe not everyone would use it but I really would love and kind of need it.
Was really hoping this would make it into the Official build someday.
Thanks again for making the best Kodi Skin ever!!!
I see the fix for the VideoExtras TV listing didn't make it into this version. I copied the same dialogvideoinfo.xml file you gave me into the 720p folder, and it works again. Will you be able to make this fix permanent with some future release?
Sorry just missed that commit. It'll definitely be in the next one.
(2015-10-10, 17:18)gate1975mlm Wrote: [ -> ]Is there any chance at all that you could include "OSD Commend Labels" that MacGyver created in his mod builds?
The problem is that they definitely don't belong in the upper part of the OSD like that. I would need to find a more fitting spot for them to include this.
(2015-10-10, 16:47)gate1975mlm Wrote: [ -> ]I can use the remote after all.
Or map a button on your remote to it. On my Harmony, I map the "Info" button to it.
