I have
Minix Neo X5mini Android 4.1 TV player.
Android 4.1.2 OS, Rockchip RK3066 Dual-Core Cortex A9 Processor, Quad-Core Mali-400, 1GB DDR3 + 8GB NAND Flash
I'm using latest version of Kodi from Google Play for playing videos - everything is ok.
But with Tvheadend plugin there is no video output. HD MPEG4 DVB-T streams are ok, but normal DVB-T stream in MPEG2 has no video output.
It is not Raspberry Pi, I cannot buy any codec license.
How can I solve this? Is possible to force video decoding on CPU?
You should be able to disable hardware acceleration from the settings. Can you try playing an MPEG-2 file locally (not through PVR)?
Rockchip devices not fully supported by Kodi.
If you disable hardware acceleration, you will be able to watch the "normal DVB-T mpeg2" but you will get stuttering in all other videos.
http://forum.kodi.tv/showthread.php?tid=241921
I installed VLC from Google Play. The same stream (URL) works great in VLC. In Kodi I see only black screen.
I create
Android/data/org.xbmc.kodi/files/.kodi/userdata/advancedsettings.xml, but nothing happened.
<advancedsettings>
<video>
<stagefright>
<!-- -1 is default, 0 is never used this codec, 1 is always use this codec, bypassing blacklist -->
<useavccodec>1</useavccodec>
<usevc1codec>1</usevc1codec>
<usevpxcodec>1</usevpxcodec>
<usemp4codec>1</usemp4codec>
<usempeg2codec>1</usempeg2codec>
</stagefright>
<mediacodec>
<usevc1codec>0</usevc1codec>
<usevpxcodec>0</usevpxcodec>
<usemp4codec>0</usemp4codec>
<usempeg2codec>0</usempeg2codec>
</mediacodec>
</video>
</advancedsettings>
Is possible deactivate HW acceleration only for MPEG2 in advancedsettings.xml?
What I need to use
stagefright or
mediacodec?
you need to disable both mediacodec and stagefright in order to play mpeg2
according to
http://kodi.wiki/view/Advancedsettings.xml
<mediacodec> tags as well as stagefright tags, but this was in error. There are only stagefright options for official Kodi builds.
Is possible to disable only mpeg2? There is xml elemnt for this:
What is better for Android 4.2.2?
Stagefright or
mediacodec?
I edited my previous post,
Do you see video if you disable both stagefright and mediacodec?
Yes, if I disable HW decoding in Kodi GUI I see DVB-T (MPEG-2 TS) video.
But all other videos are terrible - H264 1280x720 is very bad.
I try modifiing advancedsettings.xml. In every cases nothing happened. It look like Kodi ignore this file.
<advancedsettings>
<video>
<stagefright>
<useavccodec>-1</useavccodec>
<usevc1codec>-1</usevc1codec>
<usevpxcodec>-1</usevpxcodec>
<usemp4codec>-1</usemp4codec>
</stagefright>
<mediacodec>
</mediacodec>
</video>
</advancedsettings>
I will try to use XBMC 13.3 (13.3 not support Tvheadend PVR) for H264 and Kodi 15.1 for MPEG2 :-(
kodi ignore mediacodec tags:
<mediacodec>
</mediacodec>
so if you enable stagefright, disable mediacodec and use
<advancedsettings>
<video>
<stagefright>
</stagefright>
</video>
</advancedsettings>
you'll see the video.
