Hi guys, can you help me ?:
I don't find the way to no switch to fullscreen video play when clicking in a video file.
I just need the video reproduction on background.
What code or function is needed?
For example this code switch automatically to fullscreen.
PlayMedia($ESCINFO[Window.Property(RandomMovie.1.File)])
if you're using the playmedia() action, then it can be done like this:
PlayMedia(media[,isdir][,1],[playoffset=xx])
Quote:Plays the media. This can be a playlist, music, or video file, directory, plugin or an Url. The optional parameter ",isdir" can be used for playing a directory. ",1" will start a video in a preview window, instead of fullscreen. If media is a playlist, you can use playoffset=xx where xx is the position to start playback from.
see:
List_of_built-in_functions (wiki)
(2015-10-10, 10:37)ronie Wrote: [ -> ]if you're using the playmedia() action, then it can be done like this:
see: List_of_built-in_functions (wiki)
Thanks for the info ronie !
But now it's imposible for me to play this content (plugin) on a preview video window
<content
limit="22"
target="video">
plugin://plugin.video.giantbomb/?mode=2&name=Trailers&url=http%3a%2f%2fapi.giantbomb.com%2fvideos%2f%3fapi_key%3dfa96542d69b4af7f31c2049ace5d89e84e225bef%26video_type%3d7%26sort%3d-publish_date%26format%3djson</content>
I can't find the correct place to put [,1]
