2015-10-09, 22:19
I searched the web and this forum and the MINIX forum but I seem to be the only one with this problem:
I use my old PS3's sixaxis contoller (I know, not supported by minix..) as the "XBMC by MINIX" main remote (MINIX X6). Which works very well actually, but for one issue: idle timeout.
XBMC quits if the controller disconnects.
So sixaxis disconnects the controller, because I've not done anything with it for a specific amount of time, XBMC just quits. (see debug log here )
This can be at the homescreen, in a menu, streaming Twitch with an addon or just playing a video file - doesn't matter.
I can disable the idle timeout - which is a workaround at the moment - but that means that the controller drains it's battery after 2-3 days which sucks.
Any ideas ?
PS: I copied this thread from the Android forum since there was no replay after 7+ days
Any ideas ?
