Full Version: PVR Stalker (Stalker Middleware client)
If any nonsense occurs here like in the last thread, I will no longer support this add-on. This add-on is intended for legitimate uses only. I won't entertain any discussions of providers here.
This PVR addon connects Kodi to the Stalker Middleware portal that is typically accessed through IPTV STBs such as the MAG250/254 and others that support Stalker Middleware.
Addon Settings
  • MAC address: this should match your STB's
  • Server address: the portal address
Supported PVR features
  • Tv
  • EPG
  • Channel groups
  • Channel icons
Possible future features
  • Recordings
  • Timeshifting
  • XMLTV import
This addon is:
  • meant as a supplement to the your STB
  • a way to watch tv on Kodi supported devices
This addon is not:
  • meant as a replacement for MAG250/254 STBs
  • a means to circumvent any kind of authentication or authorization
Notes
  • Still a work in progress, and may not function as intended
  • Tested against the vanilla version of the portal. This addon may work depending on the changes that individual providers have made on their own
  • Portals that use unicast streams are not supported
Source code & test builds
Both of which are available here.
Links
Stalker Middleware source
Stalker Middleware wiki
more info
MAG STB info
