Full Version: PVR Client doesn't start occasionally
Hi Folks!
I've got a strange problem. Sometimes i start my Kodi and everything runs quite fine. But occasionally i start it and get the Error that no PVR-Client started, and Kodi then freezes. Sometimes this message shows up for only 2 seconds and then everything works fine, but sometimes kodi then freezes.
I ain't got no idea whats wrong, so i really hope you could help me!
This is what i run:
kodi 2:15.1~git20150816.1137-final-0trusty
kodi-bin 2:15.1~git20150816.1137-final-0trusty
kodi-pvr-hts 2.1.17-1~trusty
tvheadend 3.4.28~geb79aee~trusty
Everything runs on Linux Mint 17.1. and was quite fine until version 15 of Kodi. Should i just roll back to 14.2? But i'm afraid i have to reconfigurate everything, and i'd be glad to avoid this...
This is my kodi.log when i get the freeze:
20:31:07 T:139804822357952  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:31:07 T:139804822357952  NOTICE: -----------------------------------------------------------------------
20:31:07 T:139804822357952  NOTICE: Starting Kodi (15.1 Git:d496682). Platform: Linux x86 64-bit
20:31:07 T:139804822357952  NOTICE: Using Release Kodi x64 build
20:31:07 T:139804822357952  NOTICE: Kodi compiled Aug 16 2015 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
20:31:07 T:139804822357952  NOTICE: Running on Ubuntu 14.04.3 LTS, kernel: Linux x86 64-bit version 3.13.0-37-generic
20:31:07 T:139804822357952  NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
20:31:07 T:139804822357952  NOTICE: Host CPU: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz, 2 cores available
20:31:07 T:139804822357952  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:31:07 T:139804822357952  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:31:07 T:139804822357952  NOTICE: special://masterprofile/ is mapped to: /home/MYUSERNAME/.kodi/userdata
20:31:07 T:139804822357952  NOTICE: special://home/ is mapped to: /home/MYUSERNAME/.kodi
20:31:07 T:139804822357952  NOTICE: special://temp/ is mapped to: /home/MYUSERNAME/.kodi/temp
20:31:07 T:139804822357952  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:31:07 T:139804822357952  NOTICE: Local hostname: MYUSERNAME-P35-DS3
20:31:07 T:139804822357952  NOTICE: Log File is located: /home/MYUSERNAME/.kodi/temp/kodi.log
20:31:07 T:139804822357952  NOTICE: load settings...
20:31:07 T:139804822357952  NOTICE: Found 1 Lists of Devices
20:31:07 T:139804822357952  NOTICE: Enumerated PULSE devices:
20:31:07 T:139804822357952  NOTICE:     Device 1
20:31:07 T:139804822357952  NOTICE:         m_deviceName      : Default
20:31:07 T:139804822357952  NOTICE:         m_displayName     : Default
20:31:07 T:139804822357952  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
20:31:07 T:139804822357952  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
20:31:07 T:139804822357952  NOTICE:         m_channels        : FL,FR
20:31:07 T:139804822357952  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
20:31:07 T:139804822357952  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
20:31:07 T:139804822357952  NOTICE:     Device 2
20:31:07 T:139804822357952  NOTICE:         m_deviceName      : alsa_output.pci-0000_00_1b.0.analog-stereo
20:31:07 T:139804822357952  NOTICE:         m_displayName     : Internes Audio Analog Stereo
20:31:07 T:139804822357952  NOTICE:         m_displayNameExtra: Analoge Ausgabe (PULSEAUDIO)
20:31:07 T:139804822357952  NOTICE:     Device 3
20:31:07 T:139804822357952  NOTICE:         m_deviceName      : ladspa_output.mbeq_1197.mbeq
20:31:07 T:139804822357952  NOTICE:         m_displayName     : LADSPA Plugin Multiband EQ on Internes Audio Analog Stereo
20:31:07 T:139804822357952  NOTICE:         m_displayNameExtra: LADSPA Plugin Multiband EQ on Internes Audio Analog Stereo (PULSEAUDIO)
20:31:07 T:139804822357952  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:31:07 T:139804822357952  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:31:07 T:139804822357952  NOTICE: Default DVD Player: dvdplayer
20:31:07 T:139804822357952  NOTICE: Default Video Player: dvdplayer
20:31:07 T:139804822357952  NOTICE: Default Audio Player: paplayer
20:31:07 T:139804822357952  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:31:07 T:139804822357952  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:31:07 T:139804822357952  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:31:07 T:139804822357952  NOTICE: Loaded playercorefactory configuration
20:31:07 T:139804822357952  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:31:07 T:139804822357952  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:31:07 T:139804324140800  NOTICE: Thread ActiveAE start, auto delete: false
20:31:07 T:139804391253760  NOTICE: Thread AESink start, auto delete: false
20:31:07 T:139804391253760  NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 88 ms
20:31:07 T:139804822357952  NOTICE: Running database version Addons19
20:31:08 T:139804822357952  NOTICE: ADDONS: Using repository repository.xbmc.org
20:31:08 T:139804354676480  NOTICE: Thread PeripBusCEC start, auto delete: false
20:31:08 T:139804346283776  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
20:31:08 T:139804337891072  NOTICE: Thread RemoteControl start, auto delete: false
20:31:08 T:139804822357952  NOTICE: Setup SDL
20:31:08 T:139804822357952  NOTICE: Checking resolution 16
20:31:08 T:139804822357952   ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:36, error_code:5, request_code:18 minor_code:0
20:31:08 T:139804822357952  NOTICE: Using visual 0x28
20:31:09 T:139804822357952  NOTICE: GL_VENDOR = NVIDIA Corporation
20:31:09 T:139804822357952  NOTICE: GL_RENDERER = GeForce 9500 GT/PCIe/SSE2
20:31:09 T:139804822357952  NOTICE: GL_VERSION = 3.3.0 NVIDIA 340.93
20:31:09 T:139804822357952  NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
20:31:09 T:139804822357952  NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 524288
20:31:09 T:139804822357952  NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 524288
20:31:09 T:139804822357952  NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
20:31:09 T:139804822357952  NOTICE: Running database version Addons19
20:31:09 T:139804822357952  NOTICE: Running database version ViewModes6
20:31:09 T:139804822357952  NOTICE: Running database version Textures13
20:31:09 T:139804822357952  NOTICE: Running database version MyMusic52
20:31:09 T:139804822357952  NOTICE: Running database version MyVideos93
20:31:09 T:139804822357952  NOTICE: Running database version TV29
20:31:09 T:139804822357952  NOTICE: Running database version Epg10
20:31:09 T:139804822357952  NOTICE: start dvd mediatype detection
20:31:09 T:139804821219072  NOTICE: Thread DetectDVDMedia start, auto delete: false
20:31:10 T:139804822357952 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
20:31:10 T:139804822357952 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
20:31:10 T:139804822357952 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:31:10 T:139804822357952 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:31:10 T:139804004050688  NOTICE: Thread JobWorker start, auto delete: true
20:31:10 T:139804337891072  NOTICE: Thread LanguageInvoker start, auto delete: false
20:31:10 T:139804822357952  NOTICE: initialize done
20:31:10 T:139804822357952  NOTICE: Running the application...
20:31:10 T:139804004050688  NOTICE: PVRManager - starting up
20:31:10 T:139803995657984  NOTICE: Thread PVRManager start, auto delete: false
20:31:10 T:139803987265280  NOTICE: Thread PVRClient start, auto delete: false
20:31:10 T:139804822357952  NOTICE: starting zeroconf publishing
20:31:10 T:139804822357952  NOTICE: starting upnp client
20:31:10 T:139804822357952  NOTICE: ES: Starting event server
20:31:10 T:139803316180736  NOTICE: Thread TCPServer start, auto delete: false
20:31:10 T:139803324573440  NOTICE: Thread EventServer start, auto delete: false
20:31:10 T:139803324573440  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:31:10 T:139803324573440  NOTICE: UDP: Listening on port 9777
20:31:10 T:139803307788032  NOTICE: Thread JobWorker start, auto delete: true
20:31:10 T:139804337891072  NOTICE: -->Python Interpreter Initialized<--
20:31:12 T:139803064530688  NOTICE: Thread PVRGUIInfo start, auto delete: false
and this is my kodi.log when everything works fine:
20:46:52 T:140646041409472  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:46:52 T:140646041409472  NOTICE: -----------------------------------------------------------------------
20:46:52 T:140646041409472  NOTICE: Starting Kodi (15.1 Git:d496682). Platform: Linux x86 64-bit
20:46:52 T:140646041409472  NOTICE: Using Release Kodi x64 build
20:46:52 T:140646041409472  NOTICE: Kodi compiled Aug 16 2015 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
20:46:52 T:140646041409472  NOTICE: Running on Ubuntu 14.04.3 LTS, kernel: Linux x86 64-bit version 3.13.0-37-generic
20:46:52 T:140646041409472  NOTICE: FFmpeg statically linked, version: 2.6.4-kodi-2.6.4-Isengard
20:46:52 T:140646041409472  NOTICE: Host CPU: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz, 2 cores available
20:46:52 T:140646041409472  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:46:52 T:140646041409472  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:46:52 T:140646041409472  NOTICE: special://masterprofile/ is mapped to: /home/MYUSERNAME/.kodi/userdata
20:46:52 T:140646041409472  NOTICE: special://home/ is mapped to: /home/MYUSERNAME/.kodi
20:46:52 T:140646041409472  NOTICE: special://temp/ is mapped to: /home/MYUSERNAME/.kodi/temp
20:46:52 T:140646041409472  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:46:52 T:140646041409472  NOTICE: Local hostname: MYUSERNAME-P35-DS3
20:46:52 T:140646041409472  NOTICE: Log File is located: /home/MYUSERNAME/.kodi/temp/kodi.log
20:46:52 T:140646041409472  NOTICE: load settings...
20:46:52 T:140646041409472  NOTICE: Found 1 Lists of Devices
20:46:52 T:140646041409472  NOTICE: Enumerated PULSE devices:
20:46:52 T:140646041409472  NOTICE:     Device 1
20:46:52 T:140646041409472  NOTICE:         m_deviceName      : Default
20:46:52 T:140646041409472  NOTICE:         m_displayName     : Default
20:46:52 T:140646041409472  NOTICE:         m_displayNameExtra: Default Output Device (PULSEAUDIO)
20:46:52 T:140646041409472  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
20:46:52 T:140646041409472  NOTICE:         m_channels        : FL,FR
20:46:52 T:140646041409472  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
20:46:52 T:140646041409472  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
20:46:52 T:140646041409472  NOTICE:     Device 2
20:46:52 T:140646041409472  NOTICE:         m_deviceName      : alsa_output.pci-0000_00_1b.0.analog-stereo
20:46:52 T:140646041409472  NOTICE:         m_displayName     : Internes Audio Analog Stereo
20:46:52 T:140646041409472  NOTICE:         m_displayNameExtra: Analoge Ausgabe (PULSEAUDIO)
20:46:52 T:140646041409472  NOTICE:     Device 3
20:46:52 T:140646041409472  NOTICE:         m_deviceName      : ladspa_output.mbeq_1197.mbeq
20:46:52 T:140646041409472  NOTICE:         m_displayName     : LADSPA Plugin Multiband EQ on Internes Audio Analog Stereo
20:46:52 T:140646041409472  NOTICE:         m_displayNameExtra: LADSPA Plugin Multiband EQ on Internes Audio Analog Stereo (PULSEAUDIO)
20:46:52 T:140646041409472  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:46:52 T:140646041409472  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
20:46:52 T:140646041409472  NOTICE: Default DVD Player: dvdplayer
20:46:52 T:140646041409472  NOTICE: Default Video Player: dvdplayer
20:46:52 T:140646041409472  NOTICE: Default Audio Player: paplayer
20:46:52 T:140646041409472  NOTICE: Disabled debug logging due to GUI setting. Level 0.
20:46:52 T:140646041409472  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
20:46:52 T:140646041409472  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:46:52 T:140646041409472  NOTICE: Loaded playercorefactory configuration
20:46:52 T:140646041409472  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:46:52 T:140646041409472  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:46:52 T:140645543192320  NOTICE: Thread ActiveAE start, auto delete: false
20:46:52 T:140645610305280  NOTICE: Thread AESink start, auto delete: false
20:46:52 T:140645610305280  NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 88 ms
20:46:52 T:140646041409472  NOTICE: Running database version Addons19
20:46:52 T:140646041409472  NOTICE: ADDONS: Using repository repository.xbmc.org
20:46:52 T:140645573728000  NOTICE: Thread PeripBusCEC start, auto delete: false
20:46:52 T:140645565335296  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
20:46:52 T:140645556942592  NOTICE: Thread RemoteControl start, auto delete: false
20:46:52 T:140646041409472  NOTICE: Setup SDL
20:46:52 T:140646041409472  NOTICE: Checking resolution 16
20:46:52 T:140646041409472   ERROR: CWinSystemX11::XErrorHandler: BadAtom (invalid Atom parameter), type:0, serial:36, error_code:5, request_code:18 minor_code:0
20:46:52 T:140646041409472  NOTICE: Using visual 0x28
20:46:52 T:140646041409472  NOTICE: GL_VENDOR = NVIDIA Corporation
20:46:52 T:140646041409472  NOTICE: GL_RENDERER = GeForce 9500 GT/PCIe/SSE2
20:46:52 T:140646041409472  NOTICE: GL_VERSION = 3.3.0 NVIDIA 340.93
20:46:52 T:140646041409472  NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
20:46:52 T:140646041409472  NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 524288
20:46:52 T:140646041409472  NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 524288
20:46:52 T:140646041409472  NOTICE: GL_EXTENSIONS = GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robust_buffer_access_behavior GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_separate_shader_objects GL_ARB_shader_bit_encoding GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KHR_debug GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_parameter_buffer_object2 GL_NV_path_rendering GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_shader_buffer_load GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_multisample GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vdpau_interop GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
20:46:52 T:140646041409472  NOTICE: Running database version ViewModes6
20:46:52 T:140646041409472  NOTICE: Running database version Textures13
20:46:52 T:140646041409472  NOTICE: Running database version MyMusic52
20:46:52 T:140646041409472  NOTICE: Running database version MyVideos93
20:46:52 T:140646041409472  NOTICE: Running database version TV29
20:46:52 T:140646041409472  NOTICE: Running database version Epg10
20:46:52 T:140646041409472  NOTICE: start dvd mediatype detection
20:46:52 T:140646040270592  NOTICE: Thread DetectDVDMedia start, auto delete: false
20:46:53 T:140646041409472 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
20:46:53 T:140646041409472 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
20:46:53 T:140646041409472 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
20:46:53 T:140646041409472 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
20:46:53 T:140646041409472  NOTICE: initialize done
20:46:53 T:140646041409472  NOTICE: Running the application...
20:46:53 T:140645498824448  NOTICE: Thread JobWorker start, auto delete: true
20:46:53 T:140645498824448  NOTICE: PVRManager - starting up
20:46:53 T:140645213660928  NOTICE: Thread PVRManager start, auto delete: false
20:46:53 T:140645205268224  NOTICE: Thread PVRClient start, auto delete: false
20:46:53 T:140645556942592  NOTICE: Thread LanguageInvoker start, auto delete: false
20:46:53 T:140646041409472  NOTICE: starting zeroconf publishing
20:46:53 T:140646041409472  NOTICE: starting upnp client
20:46:53 T:140646041409472  NOTICE: ES: Starting event server
20:46:53 T:140644651616000  NOTICE: Thread EventServer start, auto delete: false
20:46:53 T:140644651616000  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
20:46:53 T:140644651616000  NOTICE: UDP: Listening on port 9777
20:46:53 T:140644643223296  NOTICE: Thread TCPServer start, auto delete: false
20:46:53 T:140645556942592  NOTICE: -->Python Interpreter Initialized<--
20:46:54 T:140644631140096  NOTICE: Thread PVRGUIInfo start, auto delete: false
20:46:57 T:140644404164352  NOTICE: Thread EPGUpdater start, auto delete: false
20:46:57 T:140645213660928  NOTICE: Start - EPG thread started
20:47:01 T:140646040663808  NOTICE: Thread RSSReader start, auto delete: false
20:47:06 T:140646041409472  NOTICE: DVDPlayer: Opening: pvr://channels/tv/Alle Kanäle/pvr.hts_149.pvr
20:47:06 T:140646041409472 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
20:47:06 T:140645556942592  NOTICE: Thread DVDPlayer start, auto delete: false
20:47:06 T:140645556942592  NOTICE: Creating InputStream
20:47:07 T:140645556942592  NOTICE: Creating Demuxer
20:47:07 T:140645556942592   ERROR: Get - failed to get stream
20:47:07 T:140645556942592 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
20:47:07 T:140645556942592 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
20:47:07 T:140645556942592  NOTICE: Opening stream: 0 source: 256
20:47:07 T:140645556942592  NOTICE: Creating video codec with codec id: 28
20:47:07 T:140645556942592  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:47:07 T:140645556942592  NOTICE: Creating video thread
20:47:07 T:140645556942592  NOTICE: Opening stream: 5 source: 256
20:47:07 T:140645556942592  NOTICE: Finding audio codec for: 86019
20:47:07 T:140645556942592  NOTICE: Creating audio thread
20:47:07 T:140645556942592  NOTICE: Opening stream: 4 source: 256
20:47:07 T:140645556942592  NOTICE: Opening stream: 3 source: 256
20:47:07 T:140645556942592  NOTICE: CDVDMessageQueue(teletext)::WaitUntilEmpty
20:47:07 T:140645556942592 WARNING: CDVDMessageQueue(teletext)::Put MSGQ_NOT_INITIALIZED
20:47:07 T:140645556942592  NOTICE: waiting for teletext data thread to exit
20:47:07 T:140645556942592  NOTICE: Creating teletext data thread
20:47:07 T:140644391540480  NOTICE: Thread DVDPlayerVideo start, auto delete: false
20:47:07 T:140644391540480  NOTICE: running thread: video_thread
20:47:07 T:140644383147776  NOTICE: Thread DVDPlayerAudio start, auto delete: false
20:47:07 T:140644383147776  NOTICE: running thread: CDVDPlayerAudio::Process()
20:47:07 T:140644374755072  NOTICE: Thread DVDTeletextData start, auto delete: false
20:47:07 T:140644374755072  NOTICE: running thread: CDVDTeletextData
20:47:08 T:140645556942592  NOTICE: Opening stream: 0 source: 256
20:47:08 T:140645556942592  NOTICE: Creating video codec with codec id: 28
20:47:08 T:140645556942592  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
20:47:08 T:140644391540480  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating VDPAU(1280x720)
20:47:08 T:140644391540480  NOTICE: VDPAU::CreateContext - creating decoder context
20:47:08 T:140644391540480  NOTICE: vdp_device = 0x00000001 vdp_st = 0x00000000
20:47:08 T:140644391540480  NOTICE: VDPAU Decoder capabilities:
20:47:08 T:140644391540480  NOTICE: name          level macbs width height
20:47:08 T:140644391540480  NOTICE: ------------------------------------
20:47:08 T:140644391540480  NOTICE: MPEG1             0  8192  2048  2048
20:47:08 T:140644391540480  NOTICE: MPEG2_SIMPLE      3  8192  2048  2048
20:47:08 T:140644391540480  NOTICE: MPEG2_MAIN        3  8192  2048  2048
20:47:08 T:140644391540480  NOTICE: H264_MAIN        41  8192  2048  2048
20:47:08 T:140644391540480  NOTICE: H264_HIGH        41  8192  2048  2048
20:47:08 T:140644391540480  NOTICE: VC1_SIMPLE        1  8190  2048  2048
20:47:08 T:140644391540480  NOTICE: VC1_MAIN          2  8190  2048  2048
20:47:08 T:140644391540480  NOTICE: VC1_ADVANCED      4  8190  2048  2048
20:47:08 T:140644391540480  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_NOISE_REDUCTION
20:47:08 T:140644391540480  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_SHARPNESS
20:47:08 T:140644391540480  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL
20:47:08 T:140644391540480  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_DEINTERLACE_TEMPORAL_SPATIAL
20:47:08 T:140644391540480  NOTICE: Mixer feature: VDP_VIDEO_MIXER_FEATURE_INVERSE_TELECINE
20:47:08 T:140644391540480  NOTICE:  (VDPAU) screenWidth:1280 vidWidth:1280 surfaceWidth:1280
20:47:08 T:140644391540480  NOTICE:  (VDPAU) screenHeight:720 vidHeight:720 surfaceHeight:720
20:47:08 T:140644357449472  NOTICE: Thread Vdpau Output start, auto delete: false
20:47:08 T:140644357449472  NOTICE: COutput::OnStartup: Output Thread created
20:47:08 T:140644357449472  NOTICE: VDPAU::COutput::CreateGlxContext - created context
20:47:08 T:140644357449472  NOTICE: VDPAU::COutput: vdpau gl interop initialized
20:47:08 T:140644274140928  NOTICE: Thread Vdpau Mixer start, auto delete: false
20:47:08 T:140644274140928  NOTICE: CMixer::OnStartup: Output Thread created
20:47:08 T:140644274140928  NOTICE:  (VDPAU) Creating the video mixer
20:47:08 T:140644357449472  NOTICE: VDPAU::COutput::InitBufferPool - Output Surface created
20:47:08 T:140644357449472  NOTICE: Previous line repeats 6 times.
20:47:08 T:140644357449472  NOTICE: VDPAU::COutput registered output surfaces
20:47:08 T:140644391540480  NOTICE:  fps: 50.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
20:47:08 T:140644391540480  NOTICE: Display resolution DESKTOP : 1920x1080@ 60.00 - Full Screen (16)
20:47:08 T:140646041409472  NOTICE: Previous line repeats 1 times.
20:47:08 T:140646041409472  NOTICE: Using GL_TEXTURE_2D
20:47:08 T:140646041409472  NOTICE: GL: Using VDPAU render method
20:47:08 T:140646041409472  NOTICE: GL: NPOT texture support detected
20:47:08 T:140646041409472  NOTICE: GL: Using GL_ARB_pixel_buffer_object
20:47:09 T:140644383147776  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, no pass-through)
20:47:09 T:140644383147776  NOTICE: CDVDPlayerAudio::OutputPacket duplicate 3 packets of duration 32
20:47:10 T:140645610305280  NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 82 ms
20:47:10 T:140644383147776  NOTICE: CDVDPlayerAudio::OutputPacket duplicate 3 packets of duration 32
20:47:10 T:140644357449472  NOTICE: Previous line repeats 1 times.
20:47:10 T:140644357449472  NOTICE: VDPAU::COutput registered output surfaces
20:47:10 T:140644383147776  NOTICE: Previous line repeats 3 times.
20:47:10 T:140644383147776  NOTICE: CDVDPlayerAudio::OutputPacket skipping a packets of duration 32
20:47:10 T:140644383147776  NOTICE: CDVDPlayerAudio::OutputPacket duplicate 1 packets of duration 32
20:47:19 T:140646041409472  NOTICE: Storing total System Uptime
20:47:19 T:140646041409472  NOTICE: Saving settings
20:47:19 T:140646041409472  NOTICE: stop all
20:47:19 T:140646041409472  NOTICE: stop player
20:47:19 T:140646041409472  NOTICE: CDVDPlayer::CloseFile()
20:47:19 T:140646041409472  NOTICE: DVDPlayer: waiting for threads to exit
20:47:19 T:140644391540480 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
20:47:20 T:140644383147776 WARNING: Previous line repeats 2 times.
20:47:20 T:140644383147776 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
20:47:20 T:140645556942592  NOTICE: CDVDPlayer::OnExit()
20:47:20 T:140645556942592  NOTICE: Closing stream player 1
20:47:20 T:140645556942592  NOTICE: Waiting for audio thread to exit
20:47:20 T:140644383147776  NOTICE: thread end: CDVDPlayerAudio::OnExit()
20:47:20 T:140645556942592  NOTICE: Closing audio device
20:47:20 T:140645556942592  NOTICE: Deleting audio codec
20:47:20 T:140645556942592  NOTICE: Closing stream player 2
20:47:20 T:140645556942592  NOTICE: waiting for video thread to exit
20:47:20 T:140644391540480  NOTICE: thread end: video_thread
20:47:20 T:140645556942592  NOTICE: deleting video codec
20:47:20 T:140645556942592  NOTICE: CVDPAU::Release pre-cleanup
20:47:20 T:140644274140928  NOTICE: CMixer::OnExit: Output Thread terminated
20:47:20 T:140645556942592  NOTICE: Closing stream player 3
20:47:20 T:140645556942592  NOTICE: Closing stream player 4
20:47:20 T:140645556942592  NOTICE: waiting for teletext data thread to exit
20:47:20 T:140644374755072   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true (-1)
20:47:20 T:140644374755072  NOTICE: thread end: data_thread
20:47:20 T:140646041409472  NOTICE: DVDPlayer: finished waiting
20:47:20 T:140646041409472  NOTICE:  (VDPAU) Close
20:47:20 T:140646041409472  NOTICE:  (VDPAU) FiniVDPAUOutput
20:47:20 T:140644357449472  NOTICE: VDPAU::COutput: vdpau gl interop finished
20:47:20 T:140644357449472  NOTICE: COutput::OnExit: Output Thread terminated
20:47:20 T:140646041409472  NOTICE: VDPAU::Close - closing decoder context
20:47:20 T:140646041409472  NOTICE: CDVDPlayer::CloseFile()
20:47:20 T:140646041409472  NOTICE: DVDPlayer: waiting for threads to exit
20:47:20 T:140646041409472  NOTICE: PVRManager - stopping
20:47:21 T:140645610305280  NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 88 ms
20:47:21 T:140646041409472  NOTICE: ES: Stopping event server
20:47:21 T:140646041409472  NOTICE: stopping upnp
20:47:21 T:140644651616000  NOTICE: ES: UDP Event server stopped
20:47:21 T:140646041409472  NOTICE: stopping zeroconf publishing
20:47:21 T:140646041409472  NOTICE: stop dvd detect media
20:47:21 T:140646041409472  NOTICE: stop sap announcement listener
20:47:21 T:140646041409472  NOTICE: clean cached files!
20:47:21 T:140646041409472  NOTICE: unload skin
20:47:22 T:140646041409472  NOTICE: stopped
20:47:22 T:140646041409472  NOTICE: destroy
20:47:22 T:140646041409472  NOTICE: closing down remote control service
20:47:22 T:140646041409472  NOTICE: unload sections
20:47:22 T:140646041409472  NOTICE: special://profile/ is mapped to: special://masterprofile/
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
20:47:22 T:140646041409472 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
20:47:22 T:140646041409472  NOTICE: application stopped...
Thanks for any advice!
Edit: I forgot to mention that i configured Kodi to show the TV-Menu when Kodi is started, since i mainly use it for watching TV.
I have the same issue. I disabled loading epg data from the local database, it helped a little bit.
