Full Version: A Confluence ZEITGEIST [ 17 Krypton | 18 Leia | 19 Matrix | 20 Nexus | 21 Omega ]
New skin update for KOD 17 (Krypton)! :-)
3.1.6 (2018-08-25)
- Changed no-focus and focus textures and text colors for many buttons and ListItems (Great visual improvement)
- Slightly changed Dynamic Range Compression feature main volume values
- Improved and added some textures (rt/rt audience/mc/imdb rating icons)
- Added some "Internal developer options"/features in Skin Settings (Not relevant for end users)
- Other improvements and additions
3.1.7 (2018-08-29)
- Added home screen widget for Live-TV (recently played TV channels)
- Other minor improvements
Once again thank you very much for this excellent skin!
I'm so sorry for being that annoying guy who comes asking how to disable/not show a feature and specially a just added feature, but is it possible to disable the widget with the recent played tv channels? If not, what file should be changed or deleted in order to clear (reset) it?
Thank you very much for everything.
edit: to clear/reset I found that deleting the file "TV29.db" at ~/kodi/userdata/Database does the job.
Thanks for the feedback.
I'll look into adding an option to disable the home screen widget for recently played tv channels. Should be no big deal.
Resetting it every time by deleting a db file does not sound that great. :-D
Greets
Here we go:
3.1.8 (2018-08-30)
- [Skin Settings] Added option to hide home screen widget for Live-TV (recently played TV channels)
Thank you very much!
Cheers!
This is hard to replicate since it hardly ever happens but when there is caching during video play, does the skin display the information that caching is being made and the percentage?
A couple of days ago I played a video that had to to some caching and I have the idea that the picture just froze and nothing about caching was displayed and the playback just resumed some time after.
If it doesn't already, it would be a nice feature to add in the future. I remember seeing this in another skin.
3.1.9 (2018-09-14)
- Reworked video/audio/codec/subtitle/language-flags images (video info dialog and fullscreen video osd)
- Reworked and optimized video info dialog (Display of actors and more)
@pemartins
As in Original Confluence, there is no "caching in progress" indicator for slow web streams etc. when playback stops because of caching.
As i never run into situations where caching leads to playback stopping, i did not intend to invest much time in it. If i remember correctly, i once evaluated adding some indicator but took a step back after running into some conceptional issues. Maybe i'll have a look again sometime.
Hi!
Му setup: Rasoberry Pi3 + Libreelec + skin.aczg-4.1.3
Tell me how to make the main menu when you select "Music" and "Video" to get directly to the "Files" section.
In other words, you need to do the same as when you select on "Pictures". For example:
Select "Pictures" - > USB disk + Pictures
Select "Music" - > USB disk + Music
Select "Video" - > USB disk + Video
I wanted to get the same in the skin.aczg-3.0.74
In what file are these settings?
Note:
In the picture HG10_02 is my USB drive.
(2018-03-07, 14:28)axbmcuser Wrote: [ -> ]@all
Do some of you guys use the skin on KODI 17 in combination with skin helper service and OMDB api key to get the nice live ratings for rotten tomatoes, metacritic and imdb?
 Yes...
Recently OMDB started offering audience score again and possibly critics consensus. Is that something you would consider adding to your listitem.helper?
possible bug on krypton:
displays all movies as NR on windows 7
@Edworld
Indeed working on a new version of ListItem Helper which at last may will work independent (Without using marcelveldts script.module.metadatautils) and with changed support for OMDB. No release timeframe yet - just a quick info.
Regarding ratings:
Could you tell me what ListItem.MPAA value these items have that are visually showing the default "NR" rating for you?
I guess your ListItem.MPAA may have 0,6,12,16 or 18 as value. If this is the case there will be a fix in the next skin version. :-)
Greets
(2018-10-14, 17:03)axbmcuser Wrote: [ -> ]@Edworld
Regarding ratings:
Greets
MPAA ratings: I have G.PG, R, etc.
Oh okay.
Just to be sure: What are the exact values of your different ListItem.MPAA?
Can we verify the complete list of possible values?
Possible ListItem.MPAA in your case:
"G"
"PG"
"R"
What about PG-13? What's your value? "PG13" or "PG-13"?
Will fix it.
PG-13
NC-17
NR
Thanks. Will be fixed in next release. Including added support for US TV ratings like "TV-MA".
