2024-11-07, 17:38
@Thomas_AR
Just released 6.7.44 with some most likely final changes for the trailer search stuff (as previously announced). Maybe have a final look, re-change your settings - if even necessary - and we should be done for now in that regard.
I also added some minor improvements for the "Android apps" section i have barely ever used during testing while pushing a minor update to the skin related helper add-on "Cinema Helper".
The "Android apps" section now has a better header and should look and feel better when used. Also the main menu entry now has the correct string "Android apps" (before: "Android").
Maybe not of big use to you, but while we were at improving some Android related stuff i thought these improvements could not hurt.
Is this a typo? :-) Did you mean "Was NOT aware of this"?
I made some touchscreen tests and when viewing fullscreen video _without_ having the OSD open (meaning: play/pause/etc buttons not being visible), using swipe left/right seems to work quite well.
Kodi default keymaps are not ideal and should be improved to also make this exact swipe gestures possible when the OSD is open, so the L/R swipe gesture always works when viewing fullscreen video, despite the state of the player OSD being open/closed.
That being said, happy to evaluate the idea of further changes/additions in regards to 10 second skipping.
I'll try to check if Kodi even support a double-tap for touchscreens. Or are you aware that it does?
You might have more experience in touch screen usage with Kodi. :-)
I had a first look but did not install it yet to fully test and understand the concept.
Not sure if Confluence ZEITGEIST could benefit from this, since it seems to be a replacement for the official Kodi YT App which might not be what everyone wants.
But i will have to see when looking more into it. :-)
Thanks for the info on this.
Quote:I will check out the "Vídeo Skip Steps" function. Was aware of this.
