2016-05-24, 10:06
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
2016-05-24, 10:32
Great. Thanks for the feedback!
2016-05-26, 17:10
First of all... I really like your skin. Keep up the good work.
Secondly... I was able to add a custom menu item to my Confluence skin following this guide: http://www.trevorayers.com/add-menu-item...xbmc-kodi/
How can I do that with your skin. I'd like to add a "HOME VIDEOS" section, with a custom icon:
Also... is there a way to add transparency to the bar behind the menu items... I like how you did that with the bottom bar.
Thanks again for a great skin.
2016-05-31, 00:56
KODI 17.x Krypton-Version not that far away... hopefully
2016-05-31, 22:26
Skin Version for KODI 17.x Krypton now online!
Still some smaller things to do - Feedback welcome...
3.0.17 (2016-06-01)
- Initial Skin version for KODI 17.x (Krypton)
- Restored old height for DialogSettings (way too small in height in Stock Krypton Confluence)
- Added Skin-Settings Option to Hide TV main menu item (since there is no on/off option within TV-Settings anymore)
- Small changes in: DialogVideoInfo including ratingstars fixes
- Small changes in WallViews (poster not scaled+cropped for plugins-Containers anymore because they are no real posters in many cases but wider graphics which would be cut off)
3.0.17 (2016-06-01)
2016-06-02, 23:19
Love the skin. Quick question. I need Arial styled font because I have addons with Chinese characters. Under Confluence, I can select the Arial Type fonts options, but now that option is not available. I tried to install the Skin Font for Chinese, but encounter errors. How can I enable the font selection option?
2016-06-02, 23:56
Easiest way for a workaround at this point would be to backup the fonts in the Skins fonts-folder and then replace them with similar fonts renamed to the old filenames. (The new font files - Arial for example of course have to contain all the characters you need)
The old Arial-Option will not return anytime soon - as far as i can guess.
Greets
Greets
2016-06-03, 10:13
Thanks for the quick response and ideas. I just added the Arial set to the font.xml. Working now.
2016-06-03, 11:30
Oh - okay. Great! Did you duplicate the existing font-set from the .xml? Just to be safe: There are 1 or 2 additional font-definitions i added to the font.xml compared to the original. Just be sure you duplicate them all and don't only copy the font-set from an original confluence font-file.
2016-06-03, 21:37
KODI v16.x (Jarvis) Update online:
2.8.74 (2016-06-03)
- Small changes in: DialogVideoInfo including ratingstars, rating, duration, poster-aspectratio fixes
- Changes in PVR-Section (Added small channel thumbnails on the right)
2.8.74 (2016-06-03)
2016-06-04, 00:54
KODI v17.x (Krypton) Update online:
3.0.18 (2016-06-03)
- Synced changes from Confluence 3.0.18
- Small changes in: DialogVideoInfo including rating, duration, poster-aspectratio fixes
3.0.18 (2016-06-03)
2016-06-04, 09:21
(2016-06-03, 11:30)axbmcuser Wrote: [ -> ]Oh - okay. Great! Did you duplicate the existing font-set from the .xml? Just to be safe: There are 1 or 2 additional font-definitions i added to the font.xml compared to the original. Just be sure you duplicate them all and don't only copy the font-set from an original confluence font-file.
Thanks. I did as advised.
2016-06-06, 00:30
KODI 16.x (Jarvis)
2.8.75 (2016-06-06)
- Optimized MyVideoNav: Actions "Search" + "Update Library" moved to the top of the sidebar. Default sidebar-focus still remains on viewtype selection
KODI 17.x (Krypton)
3.0.19 (2016-06-06)
2.8.75 (2016-06-06)
KODI 17.x (Krypton)
3.0.19 (2016-06-06)
2016-06-13, 23:57
KODI 17.x (Krypton) UPDATE
3.0.23 (2016-06-14)
- Added "Extended Info" Script Support to "DialogVideoInfo" similar to "Estuary"-Skin:
Move DOWN on selected Actor to start Extended Info with additional Actor Information;
Added "Extended Info" Button
- "DialogVideoInfo" changes including: Addition of "Director"-Button (Same Director Search)
- Minor improvements
3.0.22 (2016-06-13)
3.0.21 (2016-06-13)
3.0.20 (2016-06-13)
- Synced changes from Confluence 3.0.22
3.0.23 (2016-06-14)
3.0.22 (2016-06-13)
3.0.21 (2016-06-13)
3.0.20 (2016-06-13)
2016-06-14, 08:47
@ axbmcuser, may I "borrow" your graphics for CCM-Phoenix? I'm well impressed with your clean flat look.
