2007-01-18, 15:01
Hi.
I am using XBMC-SVN_2007-01-09_rev7554-T3CH-PROPER on a SONY KV-36FS76E (a PAL CRT 16:9 TV) connected using RGB SCART.
If I configure the video player using "Autoswitch between 16x9 and 4x3" parameter for the "Resolution" setting and "None" for "Framerate Conversion" XBMC uses always standard PAL resolutions, even for NTSC videos, and the TV set switches correctly between widescreen (16:9) and normal (4:3) mode.
If I select "Play NTSC videos in PAL60" parameter for the "Framerate Conversion" setting, when I play a NTSC video, XBMC uses a PAL60 resolution, but the TV set doesn't switch between widescreen and normal.
What's the matter? Is this a bug? Is there a fix?
Many thanks in advance.
Best regards.
Best regards.
