Hello i have a problem
my m8s box wont play 7.1 audio through HDMI or optical cable. only 5.1.
i tried pass-trough and 7.1 speaker settings and dts decoder and ac3 ect
can you helt me
im running kodi 15.2 because armlogic screen problem
No one have the same problem?? How can I fix this
The AMLogic SoC in this device does not support 7.1 HD Audio passthrough only 5.1
This applies to all AMLogic devices.
Get an Intel equipped Chromebox if you want 7.1 HD Audio Passthrough or a RPi2 if you want HD Audio to be decoded by Kodi and output as Multichannel PCM Audio to an AVR.
Quote:Audio Output > AMLogic-HDMI/SPDIF with:
Passthrough Enabled:
DTS HD MA/HRA > output as lossy 5.1 DTS (or 6.1 DTS-ES)
Dolby True HD > output as lossy 5.1 Dolby (Digital)
(2015-10-15, 09:51)wrxtasy Wrote: [ -> ]The AMLogic SoC in this device does not support 7.1 HD Audio passthrough only 5.1
thanks for that answer..
so should i buy the invidia shield instead
