hi,
i install today ios 9.0.2 and then kodi 15.1... but now it never start, kodi crash on start up.
I remove also the guisettings.xml file.
What i need too do more?
Same here, iPad Air...tried the version on the repo, the latest nightlie and RC3...clean install
same here, but Memphiz announced before will not work it on ios9 because in that moment didnt have a jailbreak...
http://forum.kodi.tv/showthread.php?tid=239610
but now we have it just we need a time for there fix the situation...
Hello guys i'm new to the forum. I have also jailbroken in to IOS 9.0.2 today and had the same problem as you guys but, I did get it to work. Here are the simple steps.
1.From the Cydia app search and install Icleaner.(this is a nice toll to always free up space on your device by clearing cache and temp files)
2. Run ICleaner and perform a "clean".
3. Open up Kodi it should work now
Hope it works for you guys.
(2015-10-14, 20:13)antonioj Wrote: [ -> ]did not work for me :/
Try reinstalling Kodi again and then do the cleaning thing
tried reinstalling, cleaning several times, no result
This is very weird I have tried installing on another device and is not working...Guess i got lucky on the one that works
Here's a screenshot i just took
(2015-10-14, 19:38)u2pop Wrote: [ -> ]same here, but Memphiz announced before will not work it on ios9 because in that moment didnt have a jailbreak...
This is not true. I have written that it won't work in general. The missing jailbreak at that point made it only available to developers. Now that its jailbroken its still a problem that Apple changed a major thing related to loading dylibs. ATM i have no solution for fixing this in a way so that resulting Kodi versions will run on all our supported ios versions.
Stop trying - i will keep you posted in the sticky once a solution was found.
It seems all the people saying it works for them have 32bit devices right?
Now I have installed 15.2 RC3 and it works for me. Ipad 2 iOS 9.0.2 jailbroken by Pangu. At first it didn't show Kodi icon. I have tried restart a few times but it didn't show. Then I have installed some random app from Cydia and then Kodi also appeared. I didn't notice anything not working but I use it mostly for Genesis and playing from network share. Hope this helps someone.
