Ok ,
I have copied part of the log , hiding the real url of the channels, instead of real domain I have put "myProvider" and instead of user and password and ip address: XXXX sequence....
So what happens is I open the iptv simple client, I click on the list on channel 10 ( http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8 in the log) it works correctly, I go in fullscreen , I click on remote button 3 and 0 in order to go to channel 30 (http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/48.m3u8 in the log) it works I can see the channel, after I click always in full screen on button 1 and 0 in order to go back to channel 10 (same of the first) and I'm redirected to the channel list exiting from full screen mode, and this is what I see in the log:
11:05:39 123.205139 T:1966321664 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
11:05:39 123.383568 T:1966321664 DEBUG: OnKey: return (0xf00d) pressed, action is Select
11:05:39 123.433746 T:1966321664 DEBUG: Loading settings for pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr
11:05:39 123.450821 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers(pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr)
11:05:39 123.451035 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
11:05:39 123.451164 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
11:05:39 123.451225 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
11:05:39 123.451401 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
11:05:39 123.451530 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
11:05:39 123.451660 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
11:05:39 123.451782 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
11:05:39 123.451897 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
11:05:39 123.451973 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
11:05:39 123.452072 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
11:05:39 123.452202 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
11:05:39 123.452324 T:1966321664 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
11:05:39 123.452507 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
11:05:39 123.452721 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
11:05:39 123.452797 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
11:05:39 123.452858 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
11:05:39 123.452919 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: VideoPlayer (1)
11:05:39 123.453056 T:1966321664 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
11:05:39 123.566277 T:1946153984 DEBUG: CAESinkPi
rain delay:99ms now:0ms
11:05:39 123.566422 T:1946153984 DEBUG: CAESinkPi
einitialize
11:05:39 123.566750 T:1946153984 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000000
11:05:39 123.573212 T:1946153984 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_render handle 0x74101b70
11:05:39 123.574471 T:1966321664 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData
11:05:39 123.581299 T:1966321664 NOTICE: VideoPlayer: Opening: pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr
11:05:39 123.581512 T:1966321664 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
11:05:39 123.581642 T:1966321664 DEBUG: CMMALRenderer::CMMALRenderer
11:05:39 123.581718 T:1966321664 DEBUG: CMMALRenderer::UnInitMMAL pool((nil))
11:05:39 123.581787 T:1966321664 DEBUG: CMMALRenderer:
reInit
11:05:39 123.582161 T:1582367744 NOTICE: Thread VideoPlayer start, auto delete: false
11:05:39 123.582512 T:1582367744 NOTICE: Creating InputStream
11:05:39 123.583145 T:1582367744 DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'LA 7'
11:05:39 123.583275 T:1582367744 DEBUG: opening live stream on url 'http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8'
11:05:39 123.609711 T:1582367744 DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr
11:05:39 123.610916 T:1582367744 DEBUG: CFileCache::Open - opening <live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8> using cache
11:05:39 123.611450 T:1582367744 DEBUG: CurlFile::Open(0x6488c348) http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:05:39 123.612045 T:1582367744 INFO: easy_aquire - Created session to http://myProvider
11:05:39 123.935188 T:1582367744 DEBUG: CCurlFile::Open - effective URL: <http://xxx.xxx.xxx.xxx:8000//streaming/clients_live.php?username=xxxxxxxxxx&password=xxxxxxxxxx&stream=326&extension=m3u8&hash=d7919d0ba7666e4e1d89d5a71fc7a383&time=0&external_device=>
11:05:39 123.935524 T:1511138304 NOTICE: Thread FileCache start, auto delete: false
11:05:39 123.936134 T:1511138304 INFO: CFileCache:
rocess - Hit eof.
11:05:39 123.986206 T:1511138304 DEBUG: Thread FileCache 1511138304 terminating
11:05:39 123.986397 T:1582367744 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:05:39 123.986511 T:1582367744 NOTICE: Creating Demuxer
11:05:39 124.001297 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:40 124.256874 T:1582367744 DEBUG: Previous line repeats 2 times.
11:05:40 124.257050 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://xxx.xxx.xxx.xxx:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=326&type=hls&segment=326_6798.ts&hash=251640c4a5e378716a1e0612d8a03d6f&time=1128752', offset 0, playlist 0
11:05:40 124.257195 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:40 124.257484 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:05:40 124.257637 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:40 124.332191 T:1966321664 DEBUG: ------ Window Init (DialogBusy.xml) ------
11:05:40 124.664406 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] HTTP error 500 Internal Server Error
11:05:40 124.664856 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] Failed to open segment of playlist 0
11:05:40 124.665009 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://xxx.xxx.xxx.xxx:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=326&type=hls&segment=326_6799.ts&hash=2ceb7a2eecdd0ac4868db7aa42746b63&time=1122548', offset 0, playlist 0
11:05:40 124.665138 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:40 124.665337 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:05:40 124.665482 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:40 125.073105 T:1582367744 DEBUG: ffmpeg[5E510400]: [h264] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:41 125.198128 T:1582367744 DEBUG: Open - avformat_find_stream_info starting
11:05:41 125.279083 T:1582367744 DEBUG: Open - av_find_stream_info finished
11:05:41 125.279350 T:1582367744 INFO: ffmpeg[5E510400]: Input #0, hls,applehttp, from 'http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8':
11:05:41 125.279503 T:1582367744 INFO: ffmpeg[5E510400]: Duration: N/A, start: 67992.680000, bitrate: N/A
11:05:41 125.279587 T:1582367744 INFO: ffmpeg[5E510400]: Program 0
11:05:41 125.279732 T:1582367744 INFO: ffmpeg[5E510400]: Metadata:
11:05:41 125.279892 T:1582367744 INFO: ffmpeg[5E510400]: variant_bitrate : 0
11:05:41 125.280701 T:1582367744 INFO: ffmpeg[5E510400]: Stream #0:0: Video: h264 (Baseline) ([27][0][0][0] / 0x001B), yuv420p(tv), 640x360 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
11:05:41 125.280991 T:1582367744 INFO: ffmpeg[5E510400]: Stream #0:1: Audio: mp3 ([3][0][0][0] / 0x0003), 44100 Hz, stereo, s16p, 128 kb/s
11:05:41 125.281166 T:1582367744 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0 (0)
11:05:41 125.281250 T:1582367744 DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1 (1)
11:05:41 125.283607 T:1582367744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.clock input port 80 output port 81 m_handle 0x648f7230
11:05:41 125.284233 T:1582367744 DEBUG: OMXClock::OMXStop
11:05:41 125.284416 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(0.000) pause_resume:1
11:05:41 125.284592 T:1582367744 NOTICE: Opening stream: 0 source: 256
11:05:41 125.284889 T:1582367744 DEBUG: DllBcm: Using omx system library
11:05:41 125.286278 T:1582367744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x648f7e50
11:05:41 125.287437 T:1582367744 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(120), nBufferSize(81920), nBufferAlignmen(16)
11:05:41 125.303810 T:1582367744 DEBUG: COMXVideo::Open - decoder_component(0x0x648f7e50), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 1
11:05:41 125.303925 T:1582367744 INFO: OMXPlayerVideo::OpenDecoder : Video codec omx-mvc width 640 height 360 profile 66 fps 25.000000
11:05:41 125.303993 T:1582367744 NOTICE: Creating video thread
11:05:41 125.304192 T:1582367744 NOTICE: Opening stream: 1 source: 256
11:05:41 125.304283 T:1511138304 NOTICE: Thread OMXPlayerVideo start, auto delete: false
11:05:41 125.304390 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_STARTED 0
11:05:41 125.304787 T:1582367744 NOTICE: Creating audio thread
11:05:41 125.305054 T:1499460608 NOTICE: Thread OMXPlayerAudio start, auto delete: false
11:05:41 125.305161 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_STARTED 0
11:05:41 125.305382 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 2
11:05:41 125.305527 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_SETSPEED 0
11:05:41 125.305611 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_STARTED 0
11:05:41 125.305687 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:41 125.305756 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 0
11:05:41 125.305885 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_STARTED 0
11:05:41 125.306206 T:1582367744 DEBUG: OnPlayBackStarted: play state was 1, starting 1
11:05:41 125.306419 T:1966321664 DEBUG: PlayFile: OpenFile succeed, play state 2
11:05:41 125.306534 T:1966321664 DEBUG: OnPlayBackStarted: play state was 2, starting 0
11:05:41 125.306747 T:1511138304 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-4503599627370496.000000, 0.000000, 1)
11:05:41 125.306870 T:1511138304 INFO: COMXPlayerVideo - Stillframe left, switching to normal playback
11:05:41 125.306969 T:1511138304 DEBUG: OMXVideo:
ecode VDec : setStartTime 0.021000
11:05:41 125.307518 T:1499460608 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(-4503599627370496.000000, 0)
11:05:41 125.307800 T:1511138304 INFO: Output - renderer not configured
11:05:41 125.307922 T:1582367744 DEBUG: CVideoPlayer::HandleMessages - player started 2
11:05:41 125.308029 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started 2 (s:1000 a:0 v:1)
11:05:41 125.308739 T:1499460608 DEBUG: COMXAudioCodecOMX:
ecode(0x69cf2880,417) format=6(8) chan=2 samples=1152 size=2304 data=0x5dbf0210,0x5b1f0210,(nil),(nil),(nil),(nil),(nil),(nil)
11:05:41 125.309586 T:1499460608 DEBUG: COMXAudioCodecOMX::GetData size=4608/9216 line=2304/4608 buf=0x69c76478, desired=65536
11:05:41 125.309868 T:1582367744 DEBUG: CVideoPlayer::HandleMessages - player started 1
11:05:41 125.309975 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started RESET
11:05:41 125.310104 T:1582367744 NOTICE: OMXClock using audio as reference
11:05:41 125.310478 T:1582367744 DEBUG: OMXClock::OMXReset audio / video : 1 / 1 wait mask 0->3 state : 2->1
11:05:41 125.310585 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started 1 (s:1000 a:1 v:1)
11:05:41 125.323578 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:41 125.327316 T:1966321664 DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr)
11:05:41 125.327896 T:1966321664 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
11:05:41 125.328209 T:1966321664 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
11:05:41 125.436279 T:1966321664 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
11:05:41 125.475136 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:41 125.522881 T:1765798912 DEBUG: script.toolbox: blurred img already created: /storage/.kodi/userdata/addon_data/script.toolbox/9211cddde96ef92b221125aa1ad94df830.png
11:05:41 125.585342 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:41 125.605911 T:1582367744 DEBUG: set caching from pvr to done. audio (1) = 76. video (1) = 76
11:05:41 125.606171 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 0
11:05:41 125.606392 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 1000
11:05:41 125.606544 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:41 125.606972 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_SETSPEED 1000
11:05:41 125.611458 T:1499460608 DEBUG: COMXAudio::SetCodingType OMX_AUDIO_CodingPCM
11:05:41 125.612305 T:1511138304 DEBUG: COMXVideo:
ortSettingsChanged -
[email protected] interlace:0 deinterlace:0
11:05:41 125.612587 T:1499460608 DEBUG: COMXAudio:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
11:05:41 125.612755 T:1499460608 INFO: COMXAudio::Initialize remap
nil) chan:2->2 norm:0 upmix:0 3:3
11:05:41 125.613976 T:1499460608 INFO: COMXAudio::Initialize 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
11:05:41 125.614296 T:1511138304 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_render input port 90 output port 90 m_handle 0x69c6b330
11:05:41 125.614471 T:1499460608 INFO: COMXAudio::Initialize 0.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00
11:05:41 125.614632 T:1499460608 INFO: COMXAudio::Initialize 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
11:05:41 125.617050 T:1511138304 INFO: Previous line repeats 5 times.
11:05:41 125.617226 T:1511138304 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_scheduler input port 10 output port 11 m_handle 0x69c9a990
11:05:41 125.617470 T:1499460608 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_decode input port 120 output port 121 m_handle 0x648fe420
11:05:41 125.619545 T:1499460608 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_decode) - port(120), nBufferCountMin(4), nBufferCountActual(16), nBufferSize(65536), nBufferAlignmen(16)
11:05:41 125.621559 T:1511138304 DEBUG: ResolutionUpdateCallBack - change configuration. video:1920x1080. framerate: 25.00. 640x360 format: BYPASS
11:05:41 125.621887 T:1511138304 DEBUG: CRenderManager::Configure - change configuration. 640x360. display: 640x360. framerate: 25.00. format: BYPASS
11:05:41 125.631538 T:1499460608 DEBUG: COMXAudio::Initialize Input bps 32 samplerate 44100 channels 2 buffer size 529200 bytes per second 352800
11:05:41 125.631805 T:1499460608 DEBUG: pcm->direction : input
11:05:41 125.631981 T:1499460608 DEBUG: pcm->nPortIndex : 0
11:05:41 125.632126 T:1499460608 DEBUG: pcm->eNumData : 0
11:05:41 125.632271 T:1966321664 DEBUG: DeleteRenderer - deleting renderer
11:05:41 125.632393 T:1499460608 DEBUG: pcm->eEndian : 1
11:05:41 125.632500 T:1966321664 DEBUG: CMMALRenderer::~CMMALRenderer
11:05:41 125.632614 T:1499460608 DEBUG: pcm->bInterleaved : 1
11:05:41 125.632706 T:1966321664 DEBUG: CMMALRenderer::UnInitMMAL pool((nil))
11:05:41 125.632797 T:1499460608 DEBUG: pcm->nBitPerSample : 32
11:05:41 125.632881 T:1499460608 DEBUG: pcm->ePCMMode : 0
11:05:41 125.632957 T:1966321664 DEBUG: LinuxRendererGL: Cleaning up GL resources
11:05:41 125.633057 T:1499460608 DEBUG: pcm->nChannels : 2
11:05:41 125.633148 T:1499460608 DEBUG: pcm->nSamplingRate : 44100
11:05:41 125.633240 T:1966321664 DEBUG: LinuxRendererGL: Cleaning up GL resources
11:05:41 125.633408 T:1499460608 DEBUG: COMXAudio::Initialize device passthrough 0 hwdecode 0
11:05:41 125.633522 T:1966321664 DEBUG: CRenderManager::Configure - 3
11:05:41 125.633720 T:1499460608 INFO: Audio codec channels 2 samplerate 44100 bitspersample 16
11:05:41 125.635704 T:1499460608 DEBUG: COMXAudio:
ecode ADec : setStartTime 0.000000
11:05:41 125.639870 T:1499460608 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x69c76250
11:05:41 125.642036 T:1499460608 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x58ac7a18
11:05:41 125.642708 T:1499460608 INFO: COMXAudio::ApplyVolume - Volume=0.16 (* 1.00 * 1.00)
11:05:41 125.643234 T:1966321664 NOTICE: Using GL_TEXTURE_2D
11:05:41 125.643425 T:1499460608 DEBUG: COMXAudio:
ortSettingsChanged - Output bps 16 samplerate 44100 channels 2 buffer size 529200 bytes per second 176400
11:05:41 125.643532 T:1499460608 DEBUG: pcm->direction : output
11:05:41 125.643616 T:1499460608 DEBUG: pcm->nPortIndex : 231
11:05:41 125.643700 T:1499460608 DEBUG: pcm->eNumData : 0
11:05:41 125.643799 T:1499460608 DEBUG: pcm->eEndian : 1
11:05:41 125.643936 T:1499460608 DEBUG: pcm->bInterleaved : 1
11:05:41 125.644020 T:1499460608 DEBUG: pcm->nBitPerSample : 16
11:05:41 125.644112 T:1499460608 DEBUG: pcm->ePCMMode : 0
11:05:41 125.644249 T:1499460608 DEBUG: pcm->nChannels : 2
11:05:41 125.644447 T:1499460608 DEBUG: pcm->nSamplingRate : 44100
11:05:41 125.646042 T:1499460608 DEBUG: COMXAudio:
ortSettingsChanged - bits:32 mode:0 channels:2 srate:44100 nopassthrough
11:05:41 125.668213 T:1966321664 DEBUG: GL: Requested render method: 0
11:05:41 125.668373 T:1966321664 NOTICE: GL: Using BYPASS render method
11:05:41 125.668465 T:1966321664 NOTICE: GL: NPOT texture support detected
11:05:41 125.668556 T:1966321664 DEBUG: CLinuxRendererGLES: Reorder drawpoints due to method change from 1 to 256
11:05:41 125.668709 T:1966321664 DEBUG: OMXPlayerVideo::SetVideoRect 0,0,640,360 -> 1017,120,1837,581 (0,0,0,0,mono)
11:05:41 125.669113 T:1966321664 DEBUG: COMXVideo::SetVideoRect 0,0,640,360 -> 1017,120,820,461 t:100000
11:05:41 125.678696 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:41 125.684227 T:1582367744 DEBUG: CVideoPlayer::HandleMessages - player started 1
11:05:41 125.684448 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started RESET
11:05:41 125.684860 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started 1 (s:1000 a:1 v:1)
11:05:41 125.687279 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:41 125.699699 T:1765798912 DEBUG: script.toolbox: Average Color: FFF0F0F0
11:05:41 125.701820 T:1499460608 INFO: COMXPlayerAudio - Switching to normal playback
11:05:41 125.702156 T:1582367744 DEBUG: CVideoPlayer::OMXDoProcessing Resume 0.53,0.33 (A:01 V:01) EOF:0 FULL:0 T:0.20
11:05:41 125.702309 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:41 125.796997 T:1511138304 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
11:05:41 125.844391 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://xxx.xxx.xxx.xxx:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=326&type=hls&segment=326_6800.ts&hash=cbaf78c8292114c97ec8c69bda8d92ef&time=1108072', offset 0, playlist 0
11:05:41 125.844757 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:41 125.845131 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:05:41 125.845436 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:41 126.076363 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:44 128.274963 T:1499460608 DEBUG: Previous line repeats 3 times.
11:05:44 128.275177 T:1499460608 INFO: ffmpeg[595FF400]: [mp3] overread, skip -7 enddists: -4 -4
11:05:45 129.548264 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:47 131.284805 T:1966321664 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x0000, modifier: 0x0
11:05:47 131.444275 T:1966321664 DEBUG: OnKey: return (0xf00d) pressed, action is Select
11:05:47 131.444534 T:1966321664 DEBUG: Activating window ID: 12005
11:05:47 131.444641 T:1966321664 DEBUG: ------ Window Deinit (MyPVRChannels.xml) ------
11:05:47 131.448059 T:1966321664 NOTICE: Display resolution ADJUST : 1920x1080 (1920x1080) @ 50.00 - Full Screen (26) (weight: 0.000)
11:05:47 131.448318 T:1966321664 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
11:05:47 131.448425 T:1966321664 INFO: Loading skin file: VideoFullScreen.xml, load type: KEEP_IN_MEMORY
11:05:47 131.476303 T:1966321664 DEBUG: OMXPlayerVideo::SetVideoRect 0,0,640,360 -> 0,0,1920,1080 (0,0,0,0,mono)
11:05:47 131.476822 T:1966321664 DEBUG: COMXVideo::SetVideoRect 0,0,640,360 -> 0,0,1920,1080 t:100000
11:05:50 134.333649 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:50 134.479492 T:1582367744 DEBUG: Previous line repeats 1 times.
11:05:50 134.479736 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://xxx.xxx.xxx.xxx:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=326&type=hls&segment=326_6801.ts&hash=f9e18036c7723e45074e3108b857a977&time=1102808', offset 0, playlist 0
11:05:50 134.479980 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:50 134.480377 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:05:50 134.480637 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:50 134.706406 T:1966321664 DEBUG: Keyboard: scancode: 0x04, sym: 0x0033, unicode: 0x0033, modifier: 0x0
11:05:50 134.706879 T:1966321664 DEBUG: OnKey: three (0xf033) pressed, action is number3
11:05:50 134.709305 T:1966321664 INFO: Loading skin file: DialogNumeric.xml, load type: KEEP_IN_MEMORY
11:05:50 134.715103 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:50 134.751663 T:1966321664 DEBUG: ------ Window Init (DialogNumeric.xml) ------
11:05:50 134.754776 T:1966321664 DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
11:05:50 134.755066 T:1966321664 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
11:05:50 134.800995 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:51 135.232101 T:1966321664 DEBUG: Previous line repeats 1 times.
11:05:51 135.232346 T:1966321664 DEBUG: Keyboard: scancode: 0x0b, sym: 0x0030, unicode: 0x0030, modifier: 0x0
11:05:51 135.232620 T:1966321664 DEBUG: OnKey: zero (0xf030) pressed, trying keyboard action f130
11:05:51 135.955917 T:1582367744 DEBUG: ffmpeg[5E510400]: [NULL] Current profile doesn't provide more RBSP data in PPS, skipping
11:05:52 136.462448 T:1966321664 DEBUG: ------ Window Deinit (DialogNumeric.xml) ------
11:05:52 136.462723 T:1966321664 DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
11:05:52 136.462921 T:1966321664 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
11:05:52 136.667877 T:1966321664 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
11:05:52 136.681747 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg::GENERAL_FLUSH
11:05:52 136.684052 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg::GENERAL_FLUSH
11:05:52 136.714127 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 3
11:05:52 136.714432 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
11:05:52 136.714600 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
11:05:52 136.714722 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(0.000) pause_resume:1
11:05:52 136.715378 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_SETSPEED 0
11:05:52 136.715546 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:52 136.715683 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_STARTED 0
11:05:52 136.716782 T:1582367744 DEBUG: OMXClock::OMXFlush
11:05:52 136.717484 T:1582367744 DEBUG: OMXClock::OMXStop
11:05:52 136.718201 T:1582367744 DEBUG: OMXClock::OMXMediaTime set config OMX_IndexConfigTimeCurrentAudioReference = 0.00
11:05:52 136.719757 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 0
11:05:52 136.719986 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_STARTED 0
11:05:52 136.745712 T:1582367744 DEBUG: CDVDInputStreamPVRManager::Close - stream closed
11:05:52 136.745972 T:1635775488 DEBUG: DoWork - Saving file state for video item pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr
11:05:52 136.746826 T:1582367744 DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'SKY UNO HD'
11:05:52 136.746979 T:1582367744 DEBUG: opening live stream on url 'http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/48.m3u8'
11:05:52 136.762772 T:1582367744 DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_459288904.pvr
11:05:52 136.764130 T:1582367744 DEBUG: CFileCache::Open - opening <live/xxxxxxxxxx/xxxxxxxxxx/48.m3u8> using cache
11:05:52 136.764816 T:1582367744 DEBUG: CurlFile::Open(0x6489c848) http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/48.m3u8
11:05:52 136.841415 T:1477964800 NOTICE: Thread FileCache start, auto delete: false
11:05:52 136.841858 T:1477964800 INFO: CFileCache:
rocess - Hit eof.
11:05:52 136.892044 T:1477964800 DEBUG: Thread FileCache 1477964800 terminating
11:05:52 136.892258 T:1582367744 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/48.m3u8
11:05:52 136.894547 T:1582367744 NOTICE: Creating Demuxer
11:05:52 136.894958 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:52 137.000626 T:1582367744 DEBUG: Previous line repeats 1 times.
11:05:52 137.000885 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://myProvider:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=48&type=hls&segment=48_6704.ts', offset 0, playlist 0
11:05:52 137.001038 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:52 137.001236 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:05:52 137.001373 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:53 137.573227 T:1582367744 DEBUG: Open - avformat_find_stream_info starting
11:05:53 137.892136 T:1582367744 DEBUG: Open - av_find_stream_info finished
11:05:53 137.892334 T:1582367744 INFO: ffmpeg[5E510400]: Input #0, hls,applehttp, from 'http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/48.m3u8':
11:05:53 137.892487 T:1582367744 INFO: ffmpeg[5E510400]: Duration: N/A, start: 67041.780567, bitrate: N/A
11:05:53 137.892578 T:1582367744 INFO: ffmpeg[5E510400]: Program 0
11:05:53 137.892654 T:1582367744 INFO: ffmpeg[5E510400]: Metadata:
11:05:53 137.892761 T:1582367744 INFO: ffmpeg[5E510400]: variant_bitrate : 0
11:05:53 137.893051 T:1582367744 INFO: ffmpeg[5E510400]: Stream #0:0: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 1280x720, 25 fps, 25 tbr, 90k tbn, 180k tbc
11:05:53 137.893372 T:1582367744 INFO: ffmpeg[5E510400]: Stream #0:1: Audio: aac (LC) ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 130 kb/s
11:05:53 137.893494 T:1582367744 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0 (0)
11:05:53 137.893570 T:1582367744 DEBUG: CDVDDemuxFFmpeg::AddStream(1, ...) -> 1 (1)
11:05:53 137.893707 T:1582367744 NOTICE: Opening stream: 0 source: 256
11:05:53 137.893967 T:1582367744 DEBUG: DllBcm: Using omx system library
11:05:53 137.903275 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.video_scheduler handle 0x69c9a990
11:05:53 137.914810 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.video_decode handle 0x648f7e50
11:05:53 137.915649 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.video_render handle 0x69c6b330
11:05:53 137.917145 T:1582367744 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_decode input port 130 output port 131 m_handle 0x58ac7b00
11:05:53 137.918274 T:1582367744 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.video_decode) - port(130), nBufferCountMin(1), nBufferCountActual(120), nBufferSize(81920), nBufferAlignmen(16)
11:05:53 137.931702 T:1582367744 DEBUG: COMXVideo::Open - decoder_component(0x0x58ac7b00), input_port(0x82), output_port(0x83) deinterlace 1 hdmiclocksync 1
11:05:53 137.931808 T:1582367744 INFO: OMXPlayerVideo::OpenDecoder : Video codec omx-mvc width 1280 height 720 profile 77 fps 25.000000
11:05:53 137.931915 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_STARTED 0
11:05:53 137.932007 T:1582367744 NOTICE: Opening stream: 1 source: 256
11:05:53 137.939789 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_STARTED 0
11:05:53 137.939941 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg::GENERAL_STREAMCHANGE
11:05:53 137.940201 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 2
11:05:53 137.940369 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 0
11:05:53 137.940491 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_STARTED 0
11:05:53 137.940628 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_STARTED 0
11:05:53 137.940720 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:53 137.941284 T:1582367744 DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_459288904.pvr)
11:05:53 137.942078 T:1511138304 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-4503599627370496.000000, 0.000000, 1)
11:05:53 137.942200 T:1511138304 INFO: COMXPlayerVideo - Stillframe left, switching to normal playback
11:05:53 137.942276 T:1511138304 DEBUG: OMXVideo:
ecode VDec : setStartTime 0.000000
11:05:53 137.942352 T:1499460608 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(-4503599627370496.000000, 0)
11:05:53 137.942841 T:1499460608 DEBUG: COMXAudioCodecOMX:
ecode(0x69cf2c90,364) format=8(8) chan=2 samples=1024 size=8192 data=0x69c76490,0x69c9aed0,(nil),(nil),(nil),(nil),(nil),(nil)
11:05:53 137.943069 T:1499460608 DEBUG: COMXAudioCodecOMX::GetData size=8192/8192 line=4096/4096 buf=0x5dc599b0, desired=65536
11:05:53 137.946945 T:1582367744 DEBUG: CVideoPlayer::HandleMessages - player started 2
11:05:53 137.947128 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started 2 (s:1000 a:0 v:1)
11:05:53 137.947220 T:1582367744 DEBUG: CVideoPlayer::HandleMessages - player started 1
11:05:53 137.947296 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started RESET
11:05:53 137.947769 T:1582367744 DEBUG: OMXClock::OMXReset audio / video : 1 / 1 wait mask 0->3 state : 2->1
11:05:53 137.947891 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started 1 (s:1000 a:1 v:1)
11:05:53 137.957443 T:1966321664 DEBUG: OMXPlayerVideo::SetVideoRect 0,0,640,360 -> 0,0,1920,1080 (0,0,0,0,mono)
11:05:53 137.957642 T:1966321664 DEBUG: COMXVideo::SetVideoRect 0,0,640,360 -> 0,0,1920,1080 t:100000
11:05:53 138.020905 T:1765798912 DEBUG: script.toolbox: blurred img already created: /storage/.kodi/userdata/addon_data/script.toolbox/82b4919a7b81c98f157525d5eecb613b30.png
11:05:54 138.117218 T:1765798912 DEBUG: script.toolbox: Average Color: FF937b79
11:05:54 138.374680 T:1582367744 DEBUG: set caching from pvr to done. audio (1) = 76. video (1) = 76
11:05:54 138.374847 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 0
11:05:54 138.375015 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 1000
11:05:54 138.375122 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_SETSPEED 1000
11:05:54 138.375275 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:54 138.378677 T:1893725184 DEBUG: COMXCoreComponent:
ecoderEventHandler - OMX.broadcom.audio_mixer Ignoring expected event: eEvent(0x1), nData1(0x8000101c), nData2(0x0), pEventData(0x(nil))
11:05:54 138.383224 T:1966321664 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
11:05:54 138.431580 T:1499460608 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_decode handle 0x648fe420
11:05:54 138.451080 T:1499460608 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_mixer handle 0x69c76250
11:05:54 138.452011 T:1499460608 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_render handle 0x58ac7a18
11:05:54 138.452240 T:1499460608 DEBUG: COMXAudio::SetCodingType OMX_AUDIO_CodingPCM
11:05:54 138.452637 T:1499460608 DEBUG: COMXAudio:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
11:05:54 138.452713 T:1499460608 INFO: COMXAudio::Initialize remap
11:05:54 138.452957 T:1499460608 INFO: COMXAudio::Initialize 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
11:05:54 138.453064 T:1499460608 INFO: COMXAudio::Initialize 0.00 1.00 0.00 0.00 0.00 0.00 0.00 0.00
11:05:54 138.453140 T:1499460608 INFO: COMXAudio::Initialize 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
11:05:54 138.454544 T:1499460608 INFO: Previous line repeats 5 times.
11:05:54 138.454636 T:1499460608 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_decode input port 120 output port 121 m_handle 0x58ac7a18
11:05:54 138.455765 T:1499460608 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_decode) - port(120), nBufferCountMin(4), nBufferCountActual(16), nBufferSize(65536), nBufferAlignmen(16)
11:05:54 138.471573 T:1499460608 DEBUG: COMXAudio::Initialize Input bps 32 samplerate 48000 channels 2 buffer size 576000 bytes per second 384000
11:05:54 138.471741 T:1499460608 DEBUG: pcm->direction : input
11:05:54 138.471832 T:1499460608 DEBUG: pcm->nPortIndex : 0
11:05:54 138.471893 T:1499460608 DEBUG: pcm->eNumData : 0
11:05:54 138.471970 T:1499460608 DEBUG: pcm->eEndian : 1
11:05:54 138.472031 T:1499460608 DEBUG: pcm->bInterleaved : 1
11:05:54 138.472092 T:1499460608 DEBUG: pcm->nBitPerSample : 32
11:05:54 138.472153 T:1499460608 DEBUG: pcm->ePCMMode : 0
11:05:54 138.472244 T:1499460608 DEBUG: pcm->nChannels : 2
11:05:54 138.472305 T:1499460608 DEBUG: pcm->nSamplingRate : 48000
11:05:54 138.472382 T:1499460608 DEBUG: COMXAudio::Initialize device passthrough 0 hwdecode 0
11:05:54 138.472458 T:1499460608 INFO: Audio codec channels 2 samplerate 48000 bitspersample 16
11:05:54 138.472610 T:1499460608 DEBUG: COMXAudio:
ecode ADec : setStartTime 0.006755
11:05:54 138.475235 T:1499460608 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_mixer input port 232 output port 231 m_handle 0x5870f5f8
11:05:54 138.476517 T:1499460608 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x5870fd00
11:05:54 138.476776 T:1499460608 INFO: COMXAudio::ApplyVolume - Volume=0.16 (* 1.00 * 1.00)
11:05:54 138.477066 T:1499460608 DEBUG: COMXAudio:
ortSettingsChanged - Output bps 16 samplerate 48000 channels 2 buffer size 576000 bytes per second 192000
11:05:54 138.477127 T:1499460608 DEBUG: pcm->direction : output
11:05:54 138.477249 T:1499460608 DEBUG: pcm->nPortIndex : 231
11:05:54 138.477325 T:1499460608 DEBUG: pcm->eNumData : 0
11:05:54 138.477386 T:1499460608 DEBUG: pcm->eEndian : 1
11:05:54 138.477448 T:1499460608 DEBUG: pcm->bInterleaved : 1
11:05:54 138.477509 T:1499460608 DEBUG: pcm->nBitPerSample : 16
11:05:54 138.477570 T:1499460608 DEBUG: pcm->ePCMMode : 0
11:05:54 138.477631 T:1499460608 DEBUG: pcm->nChannels : 2
11:05:54 138.477692 T:1499460608 DEBUG: pcm->nSamplingRate : 48000
11:05:54 138.478897 T:1499460608 DEBUG: COMXAudio:
ortSettingsChanged - bits:32 mode:0 channels:2 srate:48000 nopassthrough
11:05:54 138.483688 T:1511138304 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
11:05:54 138.512421 T:1499460608 INFO: COMXPlayerAudio - Switching to normal playback
11:05:54 138.517029 T:1582367744 DEBUG: CVideoPlayer::HandleMessages - player started 1
11:05:54 138.517181 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started RESET
11:05:54 138.517288 T:1582367744 DEBUG: CVideoPlayer::HandleMessages player started 1 (s:1000 a:1 v:1)
11:05:54 138.529724 T:1582367744 DEBUG: CVideoPlayer::OMXDoProcessing Resume 1.20,0.16 (A:01 V:00) EOF:0 FULL:1 T:0.20
11:05:54 138.529892 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:05:54 138.589355 T:1511138304 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
11:05:54 138.691208 T:1511138304 WARNING: Previous line repeats 1 times.
11:05:54 138.691330 T:1511138304 DEBUG: COMXVideo:
11:05:54 138.692490 T:1511138304 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_render input port 90 output port 90 m_handle 0x69c75630
11:05:54 138.694199 T:1511138304 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.video_scheduler input port 10 output port 11 m_handle 0x69cb8680
11:05:54 138.697205 T:1511138304 DEBUG: ResolutionUpdateCallBack - change configuration. video:1920x1080. framerate: 25.00. 1280x720 format: BYPASS
11:05:54 138.697388 T:1511138304 DEBUG: CRenderManager::Configure - change configuration. 1280x720. display: 1280x720. framerate: 25.00. format: BYPASS
11:05:54 138.978653 T:1966321664 DEBUG: CRenderManager::Configure - 3
11:05:54 138.979355 T:1966321664 NOTICE: Display resolution ADJUST : 1920x1080 (1920x1080) @ 50.00 - Full Screen (26) (weight: 0.000)
11:05:54 138.981888 T:1966321664 NOTICE: Using GL_TEXTURE_2D
11:05:54 138.996796 T:1966321664 DEBUG: GL: Requested render method: 0
11:05:54 138.996979 T:1966321664 NOTICE: GL: Using BYPASS render method
11:05:54 138.997086 T:1966321664 NOTICE: GL: NPOT texture support detected
11:05:54 139.035187 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://myProvider:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=48&type=hls&segment=48_6705.ts', offset 0, playlist 0
11:05:54 139.035431 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:54 139.035706 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:05:54 139.035889 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:05:55 139.190247 T:1966321664 DEBUG: OMXPlayerVideo::SetVideoRect 0,0,1280,720 -> 0,0,1920,1080 (0,0,0,0,mono)
11:05:55 139.190781 T:1966321664 DEBUG: COMXVideo::SetVideoRect 0,0,1280,720 -> 0,0,1920,1080 t:100000
11:05:59 143.609543 T:1966321664 DEBUG: Keyboard: scancode: 0x02, sym: 0x0031, unicode: 0x0031, modifier: 0x0
11:05:59 143.609970 T:1966321664 DEBUG: OnKey: one (0xf031) pressed, action is number1
11:05:59 143.610550 T:1966321664 DEBUG: ------ Window Init (DialogNumeric.xml) ------
11:05:59 143.614120 T:1966321664 DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
11:05:59 143.614471 T:1966321664 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
11:06:00 144.309204 T:1966321664 DEBUG: Keyboard: scancode: 0x0b, sym: 0x0030, unicode: 0x0030, modifier: 0x0
11:06:00 144.309616 T:1966321664 DEBUG: OnKey: zero (0xf030) pressed, trying keyboard action f130
11:06:01 145.205490 T:1582367744 DEBUG: ffmpeg[5E510400]: [hls,applehttp] HLS request for url 'http://myProvider:8000/streaming/clients_live.php?extension=m3u8&username=xxxxxxxxxx&password=xxxxxxxxxx&stream=48&type=hls&segment=48_6706.ts', offset 0, playlist 0
11:06:01 145.205856 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:01 145.206177 T:1582367744 DEBUG: ffmpeg[5E510400]: [http] No trailing CRLF found in HTTP header.
11:06:01 145.206406 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:01 145.523743 T:1966321664 DEBUG: ------ Window Deinit (DialogNumeric.xml) ------
11:06:01 145.524048 T:1966321664 DEBUG: CAnnouncementManager - Announcement: OnInputFinished from xbmc
11:06:01 145.524277 T:1966321664 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputFinished
11:06:01 145.732666 T:1966321664 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
11:06:01 145.737762 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg::GENERAL_FLUSH
11:06:01 145.743103 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg::GENERAL_FLUSH
11:06:01 145.745819 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
11:06:01 145.746063 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
11:06:01 145.746216 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 3
11:06:01 145.746399 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(0.000) pause_resume:1
11:06:01 145.747055 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_SETSPEED 0
11:06:01 145.747253 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 0
11:06:01 145.747391 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:06:01 145.747528 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_STARTED 0
11:06:01 145.747650 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_STARTED 0
11:06:01 145.748322 T:1582367744 DEBUG: OMXClock::OMXFlush
11:06:01 145.749130 T:1582367744 DEBUG: OMXClock::OMXStop
11:06:01 145.749664 T:1582367744 DEBUG: OMXClock::OMXMediaTime set config OMX_IndexConfigTimeCurrentAudioReference = 0.00
11:06:01 145.776917 T:1715205120 DEBUG: DoWork - Saving file state for video item pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_459288904.pvr
11:06:01 145.780365 T:1582367744 DEBUG: CDVDInputStreamPVRManager::Close - stream closed
11:06:01 145.781357 T:1582367744 DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'LA 7'
11:06:01 145.781616 T:1582367744 DEBUG: opening live stream on url 'http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8'
11:06:01 145.794434 T:1582367744 DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_2090944362.pvr
11:06:01 145.796860 T:1582367744 DEBUG: CFileCache::Open - opening <live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8> using cache
11:06:01 145.798065 T:1582367744 DEBUG: CurlFile::Open(0x69cb2430) http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:01 145.988510 T:1582367744 DEBUG: CCurlFile::Open - effective URL: <http://xxx.xxx.xxx.xxx:8000//streaming/clients_live.php?username=xxxxxxxxxx&password=xxxxxxxxxx&stream=326&extension=m3u8&hash=d7919d0ba7666e4e1d89d5a71fc7a383&time=0&external_device=>
11:06:01 145.988968 T:1477964800 NOTICE: Thread FileCache start, auto delete: false
11:06:01 145.989212 T:1477964800 INFO: CFileCache:
rocess - Hit eof.
11:06:01 146.039413 T:1477964800 DEBUG: Thread FileCache 1477964800 terminating
11:06:01 146.039703 T:1582367744 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:01 146.042114 T:1582367744 NOTICE: Creating Demuxer
11:06:01 146.042542 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:02 146.286957 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:02 146.287125 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:02 146.287476 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:02 146.541977 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:02 146.542145 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:02 146.542496 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:02 146.783081 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:02 146.783249 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:02 146.783691 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:02 147.040344 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:02 147.040482 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:02 147.040802 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:03 147.281906 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:03 147.282089 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:03 147.282440 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:03 147.544083 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:03 147.544312 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:03 147.544830 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:03 147.792587 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:03 147.792816 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:03 147.793411 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:04 148.250214 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:04 148.250443 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:04 148.250946 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:04 148.362930 T:1966321664 DEBUG: Previous line repeats 2 times.
11:06:04 148.363129 T:1966321664 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------
11:06:04 148.509476 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:04 148.510162 T:1582367744 DEBUG: ffmpeg[5E510400]: Using network protocols without global network initialization. Please use avformat_network_init(), this will become mandatory later.
11:06:04 148.763733 T:1582367744 DEBUG: Previous line repeats 2 times.
11:06:04 148.763977 T:1582367744 DEBUG: Error, could not open file http://myProvider:8000/live/xxxxxxxxxx/xxxxxxxxxx/326.m3u8
11:06:04 148.764130 T:1582367744 ERROR: OpenDemuxStream - Error creating demuxer
11:06:04 148.764236 T:1582367744 NOTICE: CVideoPlayer::OnExit()
11:06:04 148.764343 T:1582367744 DEBUG: CVideoPlayer::SetCaching - caching state 0
11:06:04 148.764572 T:1499460608 DEBUG: COMXPlayerAudio - CDVDMsg:
LAYER_SETSPEED 1000
11:06:04 148.764786 T:1511138304 DEBUG: COMXPlayerVideo - CDVDMsg:
LAYER_SETSPEED 1000
11:06:04 148.764923 T:1582367744 DEBUG: OMXClock::OMXSetSpeed(1.000) pause_resume:1
11:06:04 148.765488 T:1582367744 NOTICE: Closing stream player 1
11:06:04 148.775742 T:1499460608 NOTICE: thread end: OMXPlayerAudio::OnExit()
11:06:04 148.775940 T:1499460608 DEBUG: Thread OMXPlayerAudio 1499460608 terminating
11:06:04 148.778168 T:1893725184 DEBUG: COMXCoreComponent:
11:06:04 148.832092 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_decode handle 0x58ac7a18
11:06:04 148.851120 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_mixer handle 0x5870f5f8
11:06:04 148.852936 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.audio_render handle 0x5870fd00
11:06:04 148.853317 T:1582367744 NOTICE: Closing stream player 2
11:06:04 148.853516 T:1511138304 ERROR: OMXPlayerVideo: Got MSGQ_IS_ERROR(-1) Aborting
11:06:04 148.853622 T:1511138304 NOTICE: thread end: video_thread
11:06:04 148.853760 T:1511138304 DEBUG: Thread OMXPlayerVideo 1511138304 terminating
11:06:04 148.863052 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.video_scheduler handle 0x69cb8680
11:06:04 148.890137 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.video_decode handle 0x58ac7b00
11:06:04 148.892029 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.video_render handle 0x69c75630
11:06:04 148.916779 T:1582367744 DEBUG: CDVDInputStreamPVRManager::Close - stream closed
11:06:04 148.917023 T:1784660992 DEBUG: DoWork - Saving file state for video item pvr://channels/tv/Tutti i Canali/pvr.iptvsimple_459288904.pvr
11:06:04 148.920135 T:1582367744 DEBUG: OMXClock::OMXStop
11:06:04 148.923431 T:1582367744 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.clock handle 0x648f7230
11:06:04 148.924103 T:1582367744 DEBUG: OnPlayBackStopped: play state was 2, starting 0
11:06:04 148.924652 T:1582367744 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
11:06:04 148.925049 T:1582367744 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
11:06:04 148.925659 T:1582367744 DEBUG: Thread VideoPlayer 1582367744 terminating
11:06:04 149.026413 T:1966321664 NOTICE: CVideoPlayer::CloseFile()
11:06:04 149.026718 T:1966321664 NOTICE: VideoPlayer: waiting for threads to exit
11:06:04 149.026871 T:1966321664 NOTICE: VideoPlayer: finished waiting
11:06:04 149.027084 T:1966321664 DEBUG: DeleteRenderer - deleting renderer
11:06:04 149.027191 T:1966321664 DEBUG: LinuxRendererGL: Cleaning up GL resources
11:06:04 149.027313 T:1966321664 NOTICE: CVideoPlayer::CloseFile()
11:06:04 149.027405 T:1966321664 NOTICE: VideoPlayer: waiting for threads to exit
11:06:04 149.027512 T:1966321664 NOTICE: VideoPlayer: finished waiting
11:06:04 149.027634 T:1966321664 DEBUG: DeleteRenderer - deleting renderer
11:06:04 149.036438 T:1956639744 INFO: CAESinkALSA - Unable to open device "default" for playback
11:06:04 149.062668 T:1956639744 NOTICE: Found 1 Lists of Devices
11:06:04 149.062897 T:1956639744 NOTICE: Enumerated PI devices:
11:06:04 149.063004 T:1956639744 NOTICE: Device 1
11:06:04 149.063293 T:1956639744 NOTICE: m_deviceName : HDMI
11:06:04 149.063461 T:1956639744 NOTICE: m_displayName : HDMI
11:06:04 149.063644 T:1956639744 NOTICE: m_displayNameExtra:
11:06:04 149.063766 T:1956639744 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:06:04 149.063858 T:1956639744 NOTICE: m_channels : FL,FR
11:06:04 149.063950 T:1956639744 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
11:06:04 149.064056 T:1956639744 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_AC3,AE_FMT_DTS,AE_FMT_EAC3
11:06:04 149.064163 T:1956639744 NOTICE: Device 2
11:06:04 149.064346 T:1956639744 NOTICE: m_deviceName : Analogue
11:06:04 149.064453 T:1956639744 NOTICE: m_displayName : Analogue
11:06:04 149.064545 T:1956639744 NOTICE: m_displayNameExtra:
11:06:04 149.064651 T:1956639744 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:06:04 149.064743 T:1956639744 NOTICE: m_channels : FL,FR
11:06:04 149.064850 T:1956639744 NOTICE: m_sampleRates : 48000
11:06:04 149.064957 T:1956639744 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
11:06:04 149.065048 T:1956639744 NOTICE: Device 3
11:06:04 149.065216 T:1956639744 NOTICE: m_deviceName : Both
11:06:04 149.065323 T:1956639744 NOTICE: m_displayName : HDMI and Analogue
11:06:04 149.065414 T:1956639744 NOTICE: m_displayNameExtra:
11:06:04 149.065521 T:1956639744 NOTICE: m_deviceType : AE_DEVTYPE_PCM
11:06:04 149.065643 T:1956639744 NOTICE: m_channels : FL,FR
11:06:04 149.065781 T:1956639744 NOTICE: m_sampleRates : 48000
11:06:04 149.065887 T:1956639744 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
11:06:04 149.066376 T:1946153984 INFO: CActiveAESink::OpenSink - initialize sink
11:06:04 149.066559 T:1946153984 DEBUG: CActiveAESink::OpenSink - trying to open device PI:HDMI
11:06:04 149.067291 T:1946153984 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
11:06:04 149.067474 T:1946153984 DEBUG: CAESinkPi:Initialize Format:15 Channels:2 Samplerate:44100 framesize:8 bufsize:17640 bytes/s=352800.00 dest=PI:HDMI
11:06:04 149.069244 T:1946153984 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x74101b70
11:06:04 149.071320 T:1946153984 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_render) - port(100), nBufferCountMin(1), nBufferCountActual(2), nBufferSize(17648), nBufferAlignmen(16)
11:06:04 149.071960 T:1946153984 DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
11:06:04 149.072067 T:1946153984 DEBUG: Output Device : HDMI
11:06:04 149.072174 T:1946153984 DEBUG: Sample Rate : 44100
11:06:04 149.072266 T:1946153984 DEBUG: Sample Format : AE_FMT_FLOAT
11:06:04 149.072372 T:1946153984 DEBUG: Channel Count : 2
11:06:04 149.072479 T:1946153984 DEBUG: Channel Layout: FL,FR
11:06:04 149.072586 T:1946153984 DEBUG: Frames : 2205
11:06:04 149.072678 T:1946153984 DEBUG: Frame Samples : 4410
11:06:04 149.072769 T:1946153984 DEBUG: Frame Size : 8
11:06:04 149.082077 T:1956639744 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
11:06:04 149.088165 T:1966321664 DEBUG: Radio UECP (RDS) Processor - delete ~CDVDRadioRDSData
11:06:04 149.088715 T:1966321664 DEBUG: CGUIWindowManager:
reviousWindow: Deactivate
11:06:04 149.089005 T:1966321664 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
11:06:05 149.126511 T:1966321664 DEBUG: CGUIWindowManager:
reviousWindow: Activate new
11:06:05 149.126862 T:1966321664 DEBUG: ------ Window Init (MyPVRChannels.xml) ------
11:06:05 149.128479 T:1966321664 DEBUG: CGUIMediaWindow::GetDirectory (pvr://channels/tv/1/)
11:06:05 149.128708 T:1966321664 DEBUG: ParentPath = [pvr://channels/tv/1/]
11:06:05 149.134460 T:1966321664 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/1)
11:06:05 149.284912 T:1715205120 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.image_decode input port 320 output port 321 m_handle 0x58743b60
11:06:05 149.285812 T:1715205120 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.image_decode) - port(320), nBufferCountMin(2), nBufferCountActual(2), nBufferSize(185232), nBufferAlignmen(16)
11:06:05 149.289062 T:1715205120 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.egl_render input port 220 output port 221 m_handle 0x648f7998
11:06:05 149.290253 T:1715205120 DEBUG: COMXCoreComponent::UseEGLImage component(OMX.broadcom.egl_render) - port(221), nBufferCountMin(1), nBufferCountActual(1), nBufferSize(15360) nBufferAlignmen(16)
11:06:05 149.315689 T:1715205120 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.image_decode handle 0x58743b60
11:06:05 149.325134 T:1715205120 DEBUG: COMXCoreComponent:
einitialize : OMX.broadcom.egl_render handle 0x648f7998
11:06:05 149.325867 T:1715205120 DEBUG: DecodeJpegToTexture: decoded special://masterprofile/Thumbnails/8/808ea05b.jpg 1280x720
