Full Version: NHL TV™
Hey. From yesterday at Best available after about a minute starts to cut the picture on each match. What could be the reason. Does anyone else? Previously everything worked perfectly.
I have eracknaphobia repo install and it has updated to 10.9 but I noticed another box I have only has the kodi nhl.tv addon and it is still at 2.24. Any reason why its not updating?
(2017-10-11, 18:45)sask3m Wrote: [ -> ]I have eracknaphobia repo install and it has updated to 10.9 but I noticed another box I have only has the kodi nhl.tv addon and it is still at 2.24. Any reason why its not updating?
I had to install the repo zip file posted in the first post to get it to update properly. If you already tried this, just uninstall and reinstall.
I’m currently using this add on and I’m able to login. My issue is that the broadcast won’t load for any games but the Multicam works fine.
When I click on the main broadcast(home/away/national) the loading wheel shows up but when it goes away, nothing happens, just the game menu again.
Any help would be greatly appreciated
Quote:Looks like the error is in the login process. Double check your credentials, whether or not you use rogers and try again.
I have double and triple checked the login information and it is definitely correct.
I also downloaded the NHL app on my Android phone and used the same login on my phone to view a live game without any trouble (while connected to the same wifi network).
I even tried connecting my device to my phones mobile connection to get off the house wifi and see if that was the problem but no dice.
I can browse to the NHL website and watch the games through the same browser I am using to type this with the same credentials. But for some reason Kodi won't start the stream Sad
Any other ideas?
(2017-10-11, 15:50)eracknaphobia Wrote: [ -> ]
(2017-10-11, 06:56)takitoes Wrote: [ -> ]Ok, I have confirmed that I am running the latest version 2017.10.09. Created a log here with what appears to be the same problem:
https://paste.ubuntu.com/25717927/
Thanks again for your time and help Smile
Erack
Thanks for keeping up this app the only app I use. I too am on Rogers sub and have the same version install and I too am finding that I am actually able to watch rogers multicam version live of a game but not the network broadcast games of the exact same game. I feel this is a rogers / multiple server authentication scheme as the multi cam games are exclusive to rogers.
(2017-10-12, 02:17)Eric.blanchy Wrote: [ -> ]I’m currently using this add on and I’m able to login. My issue is that the broadcast won’t load for any games but the Multicam works fine.
+1 on this same issue.
Double check the Visual > Stream Quality. Seems the update maybe switching the value to 800K. Switch a different quality, preferably Best Available to fix. I will fix this issue in the next update.
Hi guys,
I´m on a Pi3 with OSMC and Kodi 17.3 and on a Pi3 with Librelec and Kodi 17.4.
On both Systems I can start the Addon, but no video life or archived will be played. Here you can find my logfile.
EDIT: A few minutes ago, I saw that there was an Update from this Addon. I´v updatet to version 2017.10.9 but same problem. No Video Stream will start. I have a purchased pass from NHLTV.
Anyone an idea?
See my post above. Did that not work?
(2017-10-12, 19:57)eracknaphobia Wrote: [ -> ]See my post above. Did that not work?
I switch the quality to best available before I wrote here?! So, this doesn´t help me.
Do you have another idea?
(2017-10-12, 22:47)bergi_37 Wrote: [ -> ]
Ok, well I didn't see you say anything about it so how should I know if you tried it or not?
(2017-10-12, 22:57)eracknaphobia Wrote: [ -> ]
Ok, I tried some more Options in Visual Settings. So now it works with HD 5600. Great!! Thanks for your hard work.
(2017-10-10, 00:59)eracknaphobia Wrote: [ -> ]
(2017-10-10, 00:14)RCCS Wrote: [ -> ]So I have the new update but should the video settings be on Best Available or 5600?
i just went try it out on one of todays earlier games and that lag is still there.  Is anyone else experiencing this?  Its not buffering at all, i dont know what else to call it besides a constant lag and then a jump forward, ever so subtle.
Thanks as always.
Best Available and 5600 are essential the same. I'd just leave it as best available unless you need to run a lower quality.
Hey Erack,
I am still having this lag/delay issue going on.  Any thoughts on it?  I have the proper video settings set up and have never had this issue with your add on before.  Everything else looks crisp and great.
(2017-10-12, 15:04)eracknaphobia Wrote: [ -> ]Double check the Visual > Stream Quality. Seems the update maybe switching the value to 800K. Switch a different quality, preferably Best Available to fix. I will fix this issue in the next update.
I did just check stream quality and it was set to sd 800k. I just changed it to best available and I am in on regular live streams now!
