Full Version: NHL TV™
(2017-10-13, 01:30)ibjeepin Wrote: [ -> ]
(2017-10-12, 15:04)eracknaphobia Wrote: [ -> ]Double check the Visual > Stream Quality. Seems the update maybe switching the value to 800K. Switch a different quality, preferably Best Available to fix. I will fix this issue in the next update.
I did just check stream quality and it was set to sd 800k. I just changed it to best available and I am in on regular live streams now!
(2017-10-13, 03:19)sesame_oil I also set the settings to "No preference" instead of "Akamai" works too. Wrote: [ -> ]
Tried to check the video quality setting. It was already set to "best available" and i tried a few other settings but still having the same issue where no streams will load.
I will reupload another log file in case it helps:
https://paste.ubuntu.com/25729883/
(2017-10-13, 04:22)takitoes Wrote: [ -> ]Tried to check the video quality setting. It was already set to "best available" and i tried a few other settings but still having the same issue where no streams will load.
i have the exact same issue as takitoes, uninstalled, cleared addon directory, reinstalled, set to best quality, CDN no preference and stream doesn't play. I am able to play streams from Mac or PC without an issue.
Here is the error....
                                           Error Type: <class 'simplejson.scanner.JSONDecodeError'>
                                           Error Contents: Expecting value: line 1 column 1 (char 0)
                                             File "/storage/.kodi/addons/plugin.video.nhlgcl/addon.py", line 67, in <module>
                                               streamSelect(game_id, epg, teams_stream, stream_date)
                                             File "/storage/.kodi/addons/plugin.video.nhlgcl/resources/lib/nhl_tv.py", line 324, in streamSelect
                                               stream_url, media_auth = fetchStream(game_id, content_id[n],event_id[n])
                                             File "/storage/.kodi/addons/plugin.video.nhlgcl/resources/lib/nhl_tv.py", line 453, in fetchStream
                                               login()
                                             File "/storage/.kodi/addons/plugin.video.nhlgcl/resources/lib/nhl_tv.py", line 617, in login
                                               json_source = r.json()
                                             File "/storage/.kodi/addons/script.module.requests/lib/requests/models.py", line 850, in json
                                               return complexjson.loads(self.text, **kwargs)
                                             File "/usr/lib/python2.7/site-packages/simplejson/__init__.py", line 516, in loads
                                             File "/usr/lib/python2.7/site-packages/simplejson/decoder.py", line 370, in decode
                                             File "/usr/lib/python2.7/site-packages/simplejson/decoder.py", line 400, in raw_decode
                                             File "/usr/lib/python2.7/site-packages/simplejson/scanner.py", line 127, in scan_once
                                             File "/usr/lib/python2.7/site-packages/simplejson/scanner.py", line 87, in _scan_once
                                           JSONDecodeError: Expecting value: line 1 column 1 (char 0)
21:47:43.070 T:139740790802560   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.nhlgcl/?url=&mode=104&name=%5BB%5D%5BCOLOR%3DFFF69E20%5D14%3A35+3rd%5B%2FCOLOR%5D+Chicago+%5BCOLOR%3DFF00B7EB%5D3%5B%2FCOLOR%5D+at+%5BCOLOR%3DFFAF1E2D%5DMontr%C3%A9al%5B%2FCOLOR%5D+%5BCOLOR%3DFF00B7EB%5D1%5B%2FCOLOR%5D%5B%2FB%5D&game_id=2017020041&epg=%5B%7B%22platform%22%3A+%22web%22%2C+%22items%22%3A+%5B%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22HOME%22%2C+%22mediaPlaybackId%22%3A+%2253212503%22%2C+%22callLetters%22%3A+%22TSN2%22%2C+%22guid%22%3A+%22989ccfeb-ad8a-433c-abcf-980d4fa7faef%22%7D%2C+%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22AWAY%22%2C+%22mediaPlaybackId%22%3A+%2253212603%22%2C+%22callLetters%22%3A+%22NBCSN%22%2C+%22guid%22%3A+%2260be6f32-2f7b-4da4-a731-cd8b5ad2bcdb%22%7D%2C+%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22fra%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22FRENCH%22%2C+%22mediaPlaybackId%22%3A+%2253212903%22%2C+%22callLetters%22%3A+%22RDS%22%2C+%22guid%22%3A+%22e75c62fc-b786-4285-91ad-24328078b665%22%7D%2C+%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22Multi-Cam+1%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22COMPOSITE%22%2C+%22mediaPlaybackId%22%3A+%2253213103%22%2C+%22callLetters%22%3A+%22%22%2C+%22guid%22%3A+%2250c6cd11-1641-49ff-a44c-ea6b291c35a6%22%7D%5D%2C+%22title%22%3A+%22NHLTV%22%7D%2C+%7B%22items%22%3A+%5B%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22HOME%22%2C+%22mediaPlaybackId%22%3A+%2253212703%22%2C+%22callLetters%22%3A+%22TSN690%22%7D%2C+%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22AWAY%22%2C+%22mediaPlaybackId%22%3A+%2253212803%22%2C+%22callLetters%22%3A+%22WGN%22%7D%2C+%7B%22eventId%22%3A+%22221-1006637%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22fra%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22FRENCH%22%2C+%22mediaPlaybackId%22%3A+%2253213003%22%2C+%22callLetters%22%3A+%22CHMP%22%7D%5D%2C+%22title%22%3A+%22Audio%22%7D%2C+%7B%22items%22%3A+%5B%5D%2C+%22topicList%22%3A+%22290860462%22%2C+%22title%22%3A+%22Extended+Highlights%22%7D%2C+%7B%22items%22%3A+%5B%5D%2C+%22topicList%22%3A+%22290860462%22%2C+%22title%22%3A+%22Recap%22%7D%2C+%7B%22items%22%3A+%5B%5D%2C+%22title%22%3A+%22Power+Play%22%7D%5D&teams_stream=CHIMTL&stream_date=2017-10-10T23%3A30%3A00Z]
So I tried again last night, quality was still set to best available after update. Still can’t watch live games on my iPad. I was able to watch recorded games from previous day still.
iOS 11 not jail broken, using Cydia impactor to load ipa files from Deb file for Kodi 17.4 64bit.
Again my Kodi completely crashes when I select a live game to watch. I can see the list of games and scores, I select a game, I select which broadcast (home or away), starts to load video but crashes within 5-10 seconds.
I’ve already tried uninstalling and reinstalling the addon but it didn’t work before. Should I try again?
Not sure what else I can do.
Thanks again
(2017-10-13, 18:38)scottwin Wrote: [ -> ]So I tried again last night, quality was still set to best available after update. Still can’t watch live games on my iPad. I was able to watch recorded games from previous day still.
Thanks again
Crash for me too with my ipad. iOS 11 and kodi 17.4.
(2017-10-13, 21:59)Jezze Wrote: [ -> ]
Thanks again
Okay well I’m kinda glad to hear I’m not the only one having this issue.
Are you able to watch previously recorded games?
Is your iPad jail broken?
Do you have any idea how to see the log file? If yours is jail broken I think you can use an app called ifile to see all the files on your iPad including the Kodi folder. If so can you post the log file so Erack can have a look and perhaps diagnose the issue?
Sorry for all the questions lol.
(2017-10-13, 23:14)scottwin Wrote: [ -> ]
Thanks again
Only recorded games works. Dont have jailbroken ipad so i cant upload log file.
(2017-10-14, 00:13)Jezze Wrote: [ -> ]Only recorded games works. Dont have jailbroken ipad so i cant upload log file.
Ok thanks, let us know if you figure out a fix and I'll do same
So i have a strange problem. I am using nhl tv on my laptop through kodi with no problem. I also have kodi on my pc but nhl app doesnt work. So i reinstalled kodi from scratch did a full backup of kodi on my laptop and then did a full restore on my pc with kodi fresh installed and still nhl will not work it loads the game list but when you click on a game it says nhl tv error check log. I have double checked all the settings compared to my laptop and all are the same. Why would it work on one but not the other? confused  thanks in advance
EDITED: with more testing done.
First of all THANK YOU VERY much for all your hard work eracknaphobia !!!! Wink
I have exactly the same problem on two windows 10 kodi 17.4 boxes.   My amazon fire tv (version 1) and android phone (both using kodi 17.4) work perfectly fine.
I've tried login out, uninstall, changing quality without any luck.
Thanks in advance.
Any help would be much appreciated.
i have same problem as above on android box running kodi 17.4 / and libreelec on a PC running 17.4
live games won't play, archived or previous days works fine
Hi
I'm running krypton build 17.3 with Android 6.0.1 and when I download NHL.TV is says failed dependency
Need help
@jerrbearfehr
We do not provide support when banned items are installed on your system.
If you require assistance, then remove your Build and all its repositories and add-ons and submit a debug log.
If you don't want to do that, then seek assistance where you downloaded your build from.
First off, thanks for all your hard work eracknaphobia, the community appreciates it!
Having issues on both my platforms, Android boxes and Windows 10 PC.
Here is a log off my Windows Kodi:
http://paste.ubuntu.com/25742821/
No clue what I am doing wrong, valid Rogers subscription, clean Krypton install and latest NHL TV version (2017.10.9).
Really hoping to get this solved, quality off the website or Android app is subpar at best, thinking about a refund from Rogers right now...
Thank you for your help!
Johnny
