Full Version: NHL TV™
Update 2017.11.24 Released
- Fixed Stream Quality setting
(2017-11-24, 20:26)eracknaphobia Wrote: [ -> ]Update 2017.11.24 Released
What kinda errors that quality settings gave before you fixed it? I wondering if that my issue was about that.
404. I used to build the stream url's manually but they changed from what they were in the past. So now I read them from the playlist file so it should be a lot more reliable going forward.
Ok I have a problem. For few days NHL.tv addon isn't working. I can't get any game to play, same with recaps and highlights.
It looks like this:
Any idea how to fix it? Sad
(2017-11-25, 00:58)wizardzik Wrote: [ -> ]Ok I have a problem. For few days NHL.tv addon isn't working. I can't get any game to play, same with recaps and highlights.
It looks like this:
Nothing useful in the screen shot. I'd need a proper debug log to see what's going on. See first post.
 Confirmed...  Thanks so very much!
I still can't get it to work do I need to reinstall?
It still says it's version 3/11/17
(2017-11-25, 22:25)Jenkins12 Wrote: [ -> ]I still can't get it to work do I need to reinstall?
 I downloaded the zip file mentioned in Post #1 of this thread.  Uninstalled the old version.  Installed the repository from the zip.  Installed NHL.TV from the new repository.
But...
I suspect I could have skipped uninstalling and simply installed the repo from the zip and then NHL.TV would have shown up in available upgrades.
I'm not sure how long you will have to wait to see the upgrade in the Official Kodi Addons repository?
Hope that helps.
Shaun
(2017-11-25, 06:16)eracknaphobia Wrote: [ -> ]
It looks like this:
Here you are, thanks
https://paste.ubuntu.com/26048649
I would like to install the latest version on my iphone but the version in the official Kodi add-on repository is 2017.11.3. Would be great if you could put the latest version there, too.
I too am having trouble getting any live streams to play.  I am having the same results on both windows and linux based systems.  I am a rogers subscriber if that helps.  I can gladly help out with troubleshooting if needed.
https://pastebin.com/Cdj1K6fJ
thanks for all the work you've put into this.
I'm having problems installing the add-on. It downloads ok, but then errors out while attempting to download pytz and finishes with a message about a dependency not available.
My logfile is at https://paste.ubuntu.com/26090154/
Is it normal for live games to buffer like a bitch but on demand games to work fine at the highest quality level in 60fps? I have a decent connection, running on an RPi 3, and it’s over Ethernet and not WiFi.
I can not watch he old matches (if for a week)
And for when, to be able to pass quickly the heaviness of the announcements with a key ?.
But because the NFL will not get an official app on Android TV or Amazon fire?.
(2017-12-02, 20:10)Elmarko Wrote: [ -> ]Is it normal for live games to buffer like a bitch but on demand games to work fine at the highest quality level in 60fps? I have a decent connection, running on an RPi 3, and it’s over Ethernet and not WiFi.
 Same problem for me.  The app has been mostly unusable this year Sad.  It's running on an Amazon Fire TV with Kodi.
When I stream from my laptop in the same physical place using the web site, the stream is fine.
Anything I can do to help troubleshooting, let me know.
