(2016-02-10, 00:47)cmaxwell Wrote: [ -> ]I noticed this yesterday as well (also in Australia)
I tried editing my hosts file to point the l3c one to akc and the content takes some time to get mirrored to akamai. For instance the Caps game from two days ago was on the akamai server but the Pens game from last night was not.
As far as I can tell they take a day or so to get to the hlslive-akc layer.
You can't edit your hosts file as the Host: header won't match. You need to generate a 301 redirect from one to the other using a web server. But because both hosts get content from the same source it will work live content. The only thing that will stop it is if the CDN is removed at some point as it may have only been an experiment.
here is 2 curl requests for headers off both hosts for the same file note the X-* headers are the same which the source is the same.
➜ ~ curl -I
http://hlslive-l3c.med2.med.nhl.com/ls04...0/30/56.ts
HTTP/1.1 200 OK
Cache-Control: max-age=604800
Content-Length: 362096
Content-Type: video/mpeg
ETag: "58670-52b4b6f4d1fe2"
Expires: Tue, 16 Feb 2016 22:57:56 GMT
Last-Modified: Tue, 09 Feb 2016 00:31:13 GMT
Accept-Ranges: bytes
Server: Apache/2.4.12 (Unix)
Access-Control-Allow-Origin: *
X-Served-By: hlscache03.med2.mlbam.net
X-Varnish: 247838586
X-Varnish-Cache: MISS
Date: Tue, 09 Feb 2016 22:57:56 GMT
Connection: keep-alive
➜ ~ curl -I
http://hlslive-akc.med2.med.nhl.com/ls04...0/30/56.ts
HTTP/1.1 200 OK
X-Varnish: 248151756 248146031
X-Varnish-Cache: HIT
Expires: Tue, 16 Feb 2016 22:58:12 GMT
Date: Tue, 09 Feb 2016 22:58:12 GMT
access-control-allow-origin: *
