Full Version: NHL TV™
(2016-02-10, 16:42)RCCS Wrote: [ -> ][
Thanks Cookie..when I get home I will check which version. If it is not the latest version, how do I go about updating? Do I have to download it or would logging in and out of both Kodi and the addon do it?
Have no idea how to post a log, though.
Thanks for the help!
Did you install his Repo that is on the first page? If so it should automatically update but check to make sure.
If you haven't then I suggest doing so that way you are kept up to date.
Guide on how to post Log file:
http://kodi.wiki/view/Log_file/Easy
(2016-02-10, 16:27)cookiemonster70 Wrote: [ -> ]Unblock-us is working.
For others having issues make sure in addon information that it is currently version 2016.2.9. Then reboot your Kodi box for the updated version to acquire the new settings structure. I had the same issue and after rebooting all was good. Changes where made on how session keys are stored thus a reboot is required to make those changes active.
My rule of thumb is got hicups in an addon... Try a reboot to see if it fixes it. Specially after an update. If after a rebbot you still have issues then post a log because without it it is a shot in the dark to figure out what is happening.
I still have this very same problem. Here is my log: http://xbmclogs.com/pxvbwkqa0
(2016-02-10, 16:37)cookiemonster70 Wrote: [ -> ]
(2016-02-10, 04:19)eracknaphobia Wrote: [ -> ]I think the fact 12 games are on right now probably has a lot to do with it.
Yes it was painful till after 10pmEST. I'm doing some research into alternate CDN's and hope to have ability like I added on previous addon to change the CDN server which should help out. At this time i'm just compiling the data and hopefully will have something soon.
Sounds interesting. I'm a bit confused though, shouldn't the cdn network decide which server you should connect to based on your location? I suppose setting the cdn server manually might be a good thing for people who use proxies but not for people who are using there true location. Interested to here your thoughts.
Running an alienware alpha with windows 8 most current kodi and when I try and start the addon it says nhl tv error.. Any help I can get it would be greatly appreciated. Maybe a small guide on posting a log too would help
(2016-02-10, 20:08)Tad3r Wrote: [ -> ]Running an alienware alpha with windows 8 most current kodi and when I try and start the addon it says nhl tv error.. Any help I can get it would be greatly appreciated. Maybe a small guide on posting a log too would help
Reboot, Re-install addon. If it still doesn't work post a log.
From the first post:
*Please report any bugs, accompanied by a log file, that you may discover http://kodi.wiki/view/Log_file/Easy
Need Help. Have An Alienware Alpha i7 16gigs ram fresh install of kodi isenguard and when I type in my credentials then go to laung app fails. anyone else having this problem?
Are you serious?
Read the post above your last post.
Lucky! I haven't been able to get this addon to work with Unblock-us enabled on either the PC version or my Android TV (though it won't even launch for the TV) and tablet for a while now. Works on the official Ps4 app, though. Have to deal with soap opera effect to smooth out the crappy 30fps when I watch in-market games.... I've tried everything and nobody can seem to figure anything out from my logs.
11:53:30 T:7868 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:53:30 T:7868 NOTICE: -----------------------------------------------------------------------
11:53:30 T:7868 NOTICE: Starting Kodi (15.2 Git:20151019-02e7013). Platform: Windows NT x86 32-bit
11:53:30 T:7868 NOTICE: Using Release Kodi x32 build
11:53:30 T:7868 NOTICE: Kodi compiled Oct 19 2015 by MSVC 180030723 for Windows NT x86 32-bit version 6.0 (0x06000000)
11:53:30 T:7868 NOTICE: Running on Alienware ASM100 with Windows 8.1, kernel: Windows NT x86 64-bit version 6.3
11:53:30 T:7868 NOTICE: Host CPU: Intel® Core™ i7-4765T CPU @ 2.00GHz, 8 cores available
11:53:30 T:7868 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
11:53:30 T:7868 NOTICE: Running with restricted rights
11:53:30 T:7868 NOTICE: Aero is enabled
11:53:30 T:7868 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
11:53:30 T:7868 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
11:53:30 T:7868 NOTICE: special://masterprofile/ is mapped to: C:\Users\Darryl\AppData\Roaming\Kodi\userdata
11:53:30 T:7868 NOTICE: special://home/ is mapped to: C:\Users\Darryl\AppData\Roaming\Kodi\
11:53:30 T:7868 NOTICE: special://temp/ is mapped to: C:\Users\Darryl\AppData\Roaming\Kodi\cache
11:53:30 T:7868 NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
11:53:30 T:7868 NOTICE: Local hostname: Alpha-FJ4PD22
11:53:30 T:7868 NOTICE: Log File is located: C:\Users\Darryl\AppData\Roaming\Kodi\kodi.log
11:53:30 T:7868 NOTICE: load settings...
11:53:30 T:6944 NOTICE: Thread CWin32PowerStateWorker start, auto delete: false
11:53:30 T:7868 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
11:53:30 T:7868 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
11:53:30 T:7868 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:53:30 T:7868 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:53:30 T:7868 NOTICE: Default DVD Player: dvdplayer
11:53:30 T:7868 NOTICE: Default Video Player: dvdplayer
11:53:30 T:7868 NOTICE: Default Audio Player: paplayer
11:53:30 T:7868 NOTICE: Enabled debug logging due to GUI setting (2)
11:53:30 T:7868 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM"
11:53:30 T:7868 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:53:30 T:7868 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
11:53:30 T:7868 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
11:53:30 T:7868 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/mms/udp
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
11:53:30 T:7868 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
11:53:30 T:7868 NOTICE: Loaded playercorefactory configuration
11:53:30 T:7868 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:53:30 T:7868 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:53:30 T:7868 INFO: creating subdirectories
11:53:30 T:7868 INFO: userdata folder: special://masterprofile/
11:53:30 T:7868 INFO: recording folder:
11:53:30 T:7868 INFO: screenshots folder:
11:53:30 T:7828 NOTICE: Thread ActiveAE start, auto delete: false
11:53:30 T:7784 NOTICE: Thread AESink start, auto delete: false
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTSHD" on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_TRUEHD" on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_EAC3" on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_DTS" on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AC3" on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_LPCM" on device "SAMSUNG-4 (NVIDIA High Definition Audio)" seems to be not supported.
11:53:30 T:7828 NOTICE: Found 2 Lists of Devices
11:53:30 T:7828 NOTICE: Enumerated DIRECTSOUND devices:
11:53:30 T:7828 NOTICE: Device 1
11:53:30 T:7828 NOTICE: m_deviceName : {E4B52AC0-D51C-48E4-9D2F-50D1283279B8}
11:53:30 T:7828 NOTICE: m_displayName : HDMI - SAMSUNG-4 (NVIDIA High Definition Audio)
11:53:30 T:7828 NOTICE: m_displayNameExtra: DIRECTSOUND: SAMSUNG-4 (NVIDIA High Definition Audio)
11:53:30 T:7828 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
11:53:30 T:7828 NOTICE: m_channels : FL,FR
11:53:30 T:7828 NOTICE: m_sampleRates : 48000
11:53:30 T:7828 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
11:53:30 T:7828 NOTICE: Device 2
11:53:30 T:7828 NOTICE: m_deviceName : default
11:53:30 T:7828 NOTICE: m_displayName : default
11:53:30 T:7828 NOTICE: Device 3
11:53:30 T:7828 NOTICE: m_deviceName : {FBF058A3-20A8-44FE-898F-33551A5E6FC3}
11:53:30 T:7828 NOTICE: m_displayName : SPDIF - Realtek Digital Output(Optical) (Realtek High Definition Audio)
11:53:30 T:7828 NOTICE: m_displayNameExtra: DIRECTSOUND: Realtek Digital Output(Optical) (Realtek High Definition Audio)
11:53:30 T:7828 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
11:53:30 T:7828 NOTICE: Enumerated WASAPI devices:
11:53:30 T:7828 NOTICE: m_displayNameExtra: WASAPI: SAMSUNG-4 (NVIDIA High Definition Audio)
11:53:30 T:7828 NOTICE: m_sampleRates : 192000,48000,44100
11:53:30 T:7828 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
11:53:30 T:7828 NOTICE: m_displayNameExtra: WASAPI: Realtek Digital Output(Optical) (Realtek High Definition Audio)
11:53:30 T:7828 NOTICE: m_sampleRates : 192000,96000,48000,44100
11:53:30 T:7828 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:53:30 T:7784 INFO: CActiveAESink::OpenSink - initialize sink
11:53:30 T:7784 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:default
11:53:30 T:7784 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 65552
11:53:30 T:7784 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
11:53:30 T:7784 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
11:53:30 T:7784 DEBUG: Audio Device : SAMSUNG-4 (NVIDIA High Definition Audio)
11:53:30 T:7784 DEBUG: Sample Rate : 44100
11:53:30 T:7784 DEBUG: Sample Format : AE_FMT_FLOAT
11:53:30 T:7784 DEBUG: Bits Per Sample : 32
11:53:30 T:7784 DEBUG: Valid Bits/Samp : 32
11:53:30 T:7784 DEBUG: Channel Count : 2
11:53:30 T:7784 DEBUG: Block Align : 8
11:53:30 T:7784 DEBUG: Avg. Bytes Sec : 352800
11:53:30 T:7784 DEBUG: Samples/Block : 32
11:53:30 T:7784 DEBUG: Format cBSize : 22
11:53:30 T:7784 DEBUG: Channel Layout : FL,FR
11:53:30 T:7784 DEBUG: Channel Mask : 3
11:53:30 T:7784 DEBUG: Frames : 661
11:53:30 T:7784 DEBUG: Frame Samples : 1322
11:53:30 T:7784 DEBUG: Frame Size : 8
11:53:30 T:7784 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
11:53:30 T:7784 DEBUG: Output Device : default
11:53:30 T:7784 DEBUG: Channel Layout: FL,FR
11:53:30 T:7868 NOTICE: Running database version Addons19
11:53:30 T:7868 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/cpluff.dll)
11:53:30 T:7784 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.nosefart has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in repository.eracknaphobia has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.vortex has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.modplug has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.wma has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.vorbis has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.wav has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.flac has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in plugin.video.nhlgcl has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.ym has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in skin.re-touched has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.sidplay has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in script.module.pytz has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.aac has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.vgmstream has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.snesapu has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.lame has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.confluence has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
11:53:30 T:7868 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
11:53:30 T:7868 NOTICE: ADDONS: Using repository repository.xbmc.org
11:53:30 T:7868 NOTICE: ADDONS: Using repository repository.eracknaphobia
11:53:30 T:7804 NOTICE: Thread RemoteControl start, auto delete: false
11:53:30 T:7868 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
11:53:30 T:7804 DEBUG: CRemoteControl::Connect - connecting to: ::1:24000 ...
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
11:53:30 T:7868 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
11:53:30 T:7868 DEBUG: CWin32StorageProvider::Initialize: No optical drive found.
11:53:30 T:7868 NOTICE: Found screen: Generic PnP Monitor on NVIDIA GeForce GPU, adapter 0.
11:53:30 T:7868 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Previous line repeats 2 times.
11:53:30 T:7868 NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 720x576@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 720x576@ 72.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 720x576@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1600x1024@ 59.94 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1600x1024@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Additional mode: 1842x1036@ 60.00 - Full Screen
11:53:30 T:7868 NOTICE: Checking resolution 16
11:53:30 T:7868 DEBUG: CWinEventsWin32::WndProc: window resize event
11:53:30 T:7868 DEBUG: CWinEventsWin32::WndProc: window move event
11:53:30 T:7868 DEBUG: CWinSystemWin32::ResizeInternal - resizing due to size change (0,0,1920,1080 fullscreen)->(0,0,1920,1080 fullscreen)
11:53:30 T:7868 DEBUG: CWinEventsWin32::WndProcWindow is active
11:53:30 T:7868 DEBUG: CRenderSystemDX::InitRenderSystem - trying D3D9Ex...
11:53:30 T:7868 DEBUG: CRenderSystemDX::InitRenderSystem - using D3D9Ex
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice on adapter 0
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - using hardware vertex processing
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - adapter 0: nvd3dum.dll, NVIDIA GeForce GPU, VendorId 4318, DeviceId 5010
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - using D3DCAPS2_DYNAMICTEXTURES
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - texture caps: 0x0001ECC5
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_NPOT
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - RENDER_CAPS_DXT_NPOT
11:53:30 T:7868 DEBUG: CRenderSystemDX::CreateDevice - nVidia workaround - disabling RENDER_CAPS_DXT_NPOT
11:53:30 T:7868 DEBUG: CWinSystemWin32::SetFullScreen (windowed fullscreen) on screen 0 with size 1920x1080, refresh 60.000000
11:53:30 T:7868 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
11:53:30 T:7868 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
11:53:30 T:7868 INFO: load keymapping
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/appcommand.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/gamepad.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Alienware.Dual.Compatible.Controller.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.AppleRemote.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Harmony.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Interact.AxisPad.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Logitech.RumblePad.2.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.360.Controller.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Microsoft.Xbox.Controller.S.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Nintendo.Wii.U.Pro.Controller.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Ouya.Controller.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.PS3.Remote.Keyboard.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.PS4.Controller.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.Sony.PLAYSTATION®3.Controller.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/joystick.WiiRemote.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/keyboard.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/mouse.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/remote.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/keymaps/touchscreen.xml
11:53:30 T:7868 INFO: Loading special://xbmc/system/IRSSmap.xml
11:53:30 T:7868 INFO: * Adding remote mapping for device 'Microsoft MCE'
11:53:30 T:7868 INFO: * Adding remote mapping for device 'Abstract'
11:53:30 T:7868 DEBUG: CButtonTranslator::Load - no userdata IRSSmap.xml found, skipping
11:53:30 T:7868 INFO: GUI format 1920x1080, Display 1920x1080@ 60.00 - Full Screen
11:53:30 T:7868 DEBUG: guilib: Fill viewport on change for solving rendering passes
11:53:30 T:7868 INFO: CLangInfo: loading resource.language.en_gb language information...
11:53:30 T:7868 DEBUG: trying to set locale to eng_usa
11:53:30 T:7868 INFO: global locale set to English_United States.1252
11:53:30 T:7868 INFO: CLangInfo: loading resource.language.en_gb language strings...
11:53:30 T:7868 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: resource://resource.language.en_gb/strings.po
11:53:30 T:7868 DEBUG: POParser: loaded 3312 strings from file resource://resource.language.en_gb/strings.po
11:53:30 T:7868 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Motorola Nyxboard Hybrid"
11:53:30 T:7868 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "CEC Adapter"
11:53:30 T:7868 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "Pulse-Eight CEC Adapter"
11:53:30 T:7868 DEBUG: PERIPHERALS::CPeripherals::LoadMappings - loaded node "iMON HID device"
11:53:30 T:7868 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcec.dll)
11:53:30 T:8060 NOTICE: Thread PeripBusCEC start, auto delete: false
11:53:30 T:7868 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcurl.dll)
11:53:30 T:5736 NOTICE: Thread PeripBusUSB start, auto delete: false
11:53:30 T:7868 DEBUG: CDatabaseManager::Initialize, updating databases...
11:53:30 T:7868 NOTICE: Running database version ViewModes6
11:53:30 T:7868 NOTICE: Running database version Textures13
11:53:30 T:7868 NOTICE: Running database version MyMusic52
11:53:30 T:7868 NOTICE: Running database version MyVideos93
11:53:30 T:7868 NOTICE: Running database version TV29
11:53:30 T:7868 NOTICE: Running database version Epg10
11:53:30 T:7868 DEBUG: CDatabaseManager::Initialize, updating databases... DONE
11:53:30 T:7868 DEBUG: DPMS: supported power-saving modes: OFF STANDBY
11:53:30 T:7868 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
11:53:30 T:7868 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
11:53:30 T:7868 DEBUG: Activating window ID: 12997
11:53:30 T:7868 DEBUG: ------ Window Init () ------
11:53:30 T:7868 INFO: load splash image: C:\Program Files (x86)\Kodi\media\Splash.png
11:53:30 T:7868 INFO: Unloading old skin ...
11:53:30 T:7868 INFO: load skin from: C:\Program Files (x86)\Kodi\addons\skin.confluence (version: 2.7.4)
11:53:30 T:7868 INFO: load fonts for skin...
11:53:30 T:7868 INFO: Loading fonts from C:\Program Files (x86)\Kodi\addons\skin.confluence\720p\Font.xml
11:53:30 T:7868 DEBUG: POParser: PO file has Win Style Line Endings. Converted in memory to Linux LF for file: C:\Program Files (x86)\Kodi\addons\skin.confluence\language\resource.language.en_gb\strings.po
11:53:30 T:7868 DEBUG: POParser: loaded 147 strings from file C:\Program Files (x86)\Kodi\addons\skin.confluence\language\resource.language.en_gb\strings.po
11:53:30 T:7868 INFO: Loading skin includes from C:\Program Files (x86)\Kodi\addons\skin.confluence\720p\includes.xml
11:53:30 T:7868 INFO: load new skin...
11:53:30 T:7868 INFO: Loading user windows, path C:\Program Files (x86)\Kodi\addons\skin.confluence\720p
11:53:30 T:7868 DEBUG: Load Skin XML: 1.15ms
11:53:30 T:7868 INFO: initialize new skin...
11:53:30 T:7868 INFO: Loading skin file: Pointer.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 DEBUG: CTextureBundleXBT::OpenBundle - Opened bundle C:\Program Files (x86)\Kodi\addons\skin.confluence\media\Textures.xbt
11:53:30 T:7868 INFO: Loading skin file: DialogVolumeBar.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 INFO: Loading skin file: DialogKaiToast.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 INFO: Loading skin file: DialogMuteBug.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 INFO: Loading skin file: DialogSeekBar.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 INFO: Loading skin file: DialogBusy.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 INFO: Loading skin file: DialogExtendedProgressBar.xml, load type: LOAD_ON_GUI_INIT
11:53:30 T:7868 INFO: Loading resource://resource.uisounds.confluence/sounds.xml
11:53:30 T:7868 INFO: skin loaded...
11:53:30 T:7868 DEBUG: JSONRPC: JSON schema type broadcastnext references an unknown type PVR.Details.Broadcast
11:53:30 T:7868 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
11:53:30 T:7868 INFO: JSONRPC: Adding type "PVR.Details.Channel" to list of incomplete definitions (waiting for "PVR.Details.Broadcast")
11:53:30 T:7868 DEBUG: JSONRPC: JSON schema type references an unknown type PVR.Details.Channel
11:53:30 T:7868 DEBUG: Invalid item definition in "items" for type channels
11:53:30 T:7868 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
11:53:30 T:7868 INFO: JSONRPC: Adding type "PVR.Details.ChannelGroup.Extended" to list of incomplete definitions (waiting for "PVR.Details.Channel")
11:53:30 T:7868 INFO: JSONRPC: Resolving incomplete types/methods referencing PVR.Details.Broadcast
11:53:30 T:7868 INFO: JSONRPC: Resolving incomplete types/methods referencing PVR.Details.Channel
11:53:30 T:7868 DEBUG: JSONRPC: JSON schema type stereoscopicmode references an unknown type GUI.Stereoscopy.Mode
11:53:30 T:7868 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
11:53:30 T:7868 INFO: JSONRPC: Adding type "GUI.Property.Value" to list of incomplete definitions (waiting for "GUI.Stereoscopy.Mode")
11:53:30 T:7868 INFO: JSONRPC: Resolving incomplete types/methods referencing GUI.Stereoscopy.Mode
11:53:30 T:7868 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
11:53:30 T:7868 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:53:30 T:7868 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
11:53:30 T:7868 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
11:53:30 T:7868 INFO: JSONRPC v6.25.2: Successfully initialized
11:53:30 T:7868 DEBUG: ADDON: Starting service addons.
11:53:30 T:7868 DEBUG: Activating window ID: 12999
11:53:30 T:7868 DEBUG: ------ Window Init (Startup.xml) ------
11:53:30 T:7868 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
11:53:30 T:7936 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:30 T:7936 INFO: initializing python engine.
11:53:30 T:7868 INFO: removing tempfiles
11:53:30 T:7868 NOTICE: initialize done
11:53:30 T:7936 DEBUG: CPythonInvoker(0, C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py): start processing
11:53:30 T:7868 DEBUG: CJoystick::Initialize : No Joystick found
11:53:30 T:7868 NOTICE: Running the application...
11:53:30 T:7868 DEBUG: Activating window ID: 10000
11:53:30 T:7936 NOTICE: -->Python Interpreter Initialized<--
11:53:30 T:7936 DEBUG: CPythonInvoker(0, C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py): the source file to load is "C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py"
11:53:30 T:7936 DEBUG: CPythonInvoker(0, C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py): setting the Python path to C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
11:53:30 T:7936 DEBUG: CPythonInvoker(0, C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py): entering source directory C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck
11:53:30 T:7936 DEBUG: CPythonInvoker(0, C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py): instantiating addon using automatically obtained id of "service.xbmc.versioncheck" dependent on version 2.1.0 of the xbmc.python api
11:53:30 T:7936 DEBUG: Version Check: Version 0.3.16 started
11:53:30 T:7868 DEBUG: ------ Window Init (Pointer.xml) ------
11:53:30 T:7868 DEBUG: ------ Window Deinit (Startup.xml) ------
11:53:30 T:7868 DEBUG: ------ Window Init (Home.xml) ------
11:53:30 T:7868 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
11:53:30 T:7876 NOTICE: Thread JobWorker start, auto delete: true
11:53:30 T:7876 DEBUG: CRecentlyAddedJob::UpdateMusic() - Running RecentlyAdded home screen update
11:53:30 T:7876 DEBUG: GetRecentlyAddedAlbumSongs() query: SELECT songview.* FROM (SELECT idAlbum FROM albumview ORDER BY idAlbum DESC LIMIT 10) AS recentalbums JOIN songview ON songview.idAlbum=recentalbums.idAlbum
11:53:30 T:7876 DEBUG: CMusicDatabase::GetRecentlyAddedAlbums query: select * from albumview where strAlbum != '' order by idAlbum desc limit 10
11:53:30 T:7876 DEBUG: CRecentlyAddedJob::UpdateVideos() - Running RecentlyAdded home screen update
11:53:30 T:7868 DEBUG: no profile autoexec.py (C:\Users\Darryl\AppData\Roaming\Kodi\userdata\autoexec.py) found, skipping
11:53:30 T:7868 DEBUG: CNetwork::NetworkMessage - Starting network services
11:53:30 T:7868 NOTICE: starting upnp client
11:53:30 T:7876 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from movie_view ORDER BY dateAdded desc, idMovie desc LIMIT 10
11:53:30 T:7868 NOTICE: ES: Starting event server
11:53:30 T:7868 INFO: JSONRPC Server: Successfully initialized
11:53:30 T:7136 NOTICE: Thread EventServer start, auto delete: false
11:53:30 T:7136 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
11:53:30 T:7136 NOTICE: UDP: Listening on port 9777
11:53:30 T:4432 NOTICE: Thread TCPServer start, auto delete: false
11:53:30 T:7876 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from episode_view ORDER BY dateAdded desc, idEpisode desc LIMIT 10
11:53:30 T:7876 DEBUG: CVideoDatabase::RunQuery took 0 ms for 0 items query: select * from musicvideo_view ORDER BY dateAdded desc, idMVideo desc LIMIT 10
11:53:30 T:7876 DEBUG: CRecentlyAddedJob::UpdateTotal() - Running RecentlyAdded home screen update
11:53:30 T:6748 NOTICE: Thread RSSReader start, auto delete: false
11:53:30 T:6748 DEBUG: CurlFile::Open(0C83F4F0) http://feeds.xbmc.org/xbmc
11:53:30 T:6748 INFO: XCURL:Big GrinllLibCurlGlobal::easy_aquire - Created session to http://feeds.xbmc.org
11:53:30 T:6748 DEBUG: Got rss feed: http://feeds.xbmc.org/xbmc
11:53:30 T:6748 DEBUG: RSS feed encoding: UTF-8
11:53:30 T:6748 DEBUG: Parsed rss feed: http://feeds.xbmc.org/xbmc
11:53:30 T:6748 DEBUG: CurlFile::Open(0C83F4F0) http://feeds.xbmc.org/latest_xbmc_addons
11:53:31 T:6748 DEBUG: Got rss feed: http://feeds.xbmc.org/latest_xbmc_addons
11:53:31 T:6748 DEBUG: RSS feed encoding: UTF-8
11:53:31 T:6748 DEBUG: Parsed rss feed: http://feeds.xbmc.org/latest_xbmc_addons
11:53:31 T:6748 DEBUG: CurlFile::Open(0C83F4F0) http://feeds.xbmc.org/updated_xbmc_addons
11:53:31 T:548 DEBUG: CMMNotificationClient::OnPropertyValueChanged: Changed device property of {0.0.0.00000000}.{e4b52ac0-d51c-48e4-9d2f-50d1283279b8} is {9855c4cd-df8c-449c-a181-8191b68bd06c}#0
11:53:31 T:6748 DEBUG: Got rss feed: http://feeds.xbmc.org/updated_xbmc_addons
11:53:31 T:7804 DEBUG: CRemoteControl::Connect - connecting to: 127.0.0.1:24000 ...
11:53:31 T:6748 DEBUG: Parsed rss feed: http://feeds.xbmc.org/updated_xbmc_addons
11:53:31 T:6748 DEBUG: Thread RSSReader 6748 terminating
11:53:32 T:7868 DEBUG: Keyboard: scancode: 0x4b, sym: 0x0114, unicode: 0x0000, modifier: 0x0
11:53:32 T:7868 DEBUG: CInputManager::OnKey: left (0xf082) pressed, action is Left
11:53:32 T:7868 DEBUG: ------ Window Deinit (Pointer.xml) ------
11:53:32 T:7804 DEBUG: CRemoteControl::Connect - failed to connect
11:53:32 T:7804 INFO: CRemoteControl:Tonguerocess - failed to connect to irss, will keep retrying every 5 seconds
11:53:33 T:7868 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
11:53:33 T:7868 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
11:53:33 T:7868 DEBUG: Keyboard: scancode: 0x4d, sym: 0x0113, unicode: 0x0000, modifier: 0x0
11:53:33 T:7868 DEBUG: CInputManager::OnKey: right (0xf083) pressed, action is Right
11:53:34 T:7868 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
11:53:34 T:7868 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
11:53:34 T:7868 DEBUG: Activating window ID: 10025
11:53:34 T:7868 DEBUG: ------ Window Deinit (Home.xml) ------
11:53:34 T:7868 DEBUG: ------ Window Init (MyVideoNav.xml) ------
11:53:34 T:7868 INFO: Loading skin file: MyVideoNav.xml, load type: KEEP_IN_MEMORY
11:53:34 T:7868 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
11:53:34 T:7868 DEBUG: ParentPath = [addons://sources/video/]
11:53:34 T:7368 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:34 T:7368 DEBUG: Thread BackgroundLoader 7368 terminating
11:53:35 T:7936 DEBUG: Version Check: Version installed {u'major': 15, u'tag': u'stable', u'minor': 2, u'revision': u'20151019-02e7013'}
11:53:35 T:7936 DEBUG: Version Check: Version available {u'major': u'15', u'extrainfo': u'final', u'tagversion': u'', u'tag': u'stable', u'addon_support': u'yes', u'minor': u'2', u'revision': u'20151019-02e7013'}
11:53:35 T:7936 DEBUG: Version Check: There is no newer stable available
11:53:35 T:7936 INFO: CPythonInvoker(0, C:\Users\Darryl\AppData\Roaming\Kodi\addons\service.xbmc.versioncheck\service.py): script successfully run
11:53:35 T:7936 INFO: Python script stopped
11:53:35 T:7936 DEBUG: Thread LanguageInvoker 7936 terminating
11:53:35 T:7868 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
11:53:35 T:7868 DEBUG: CInputManager::OnKey: down (0xf081) pressed, action is Down
11:53:35 T:7440 NOTICE: Thread JobWorker start, auto delete: true
11:53:36 T:7868 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
11:53:36 T:7868 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
11:53:36 T:7868 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.nhlgcl/)
11:53:36 T:7868 DEBUG: ParentPath = [addons://sources/video]
11:53:36 T:7876 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NHL TV™('plugin://plugin.video.nhlgcl/','1','')
11:53:36 T:7876 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NHL TV™ (id=1) plugin...
11:53:36 T:7532 NOTICE: Thread LanguageInvoker start, auto delete: false
11:53:36 T:7532 INFO: initializing python engine.
11:53:36 T:7532 DEBUG: CPythonInvoker(1, C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py): start processing
11:53:36 T:7532 NOTICE: -->Python Interpreter Initialized<--
11:53:36 T:7532 DEBUG: CPythonInvoker(1, C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py): the source file to load is "C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py"
11:53:36 T:7532 DEBUG: CPythonInvoker(1, C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py): setting the Python path to C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl;C:\Users\Darryl\AppData\Roaming\Kodi\addons\script.module.pytz\lib;C:\Users\Darryl\AppData\Roaming\Kodi\addons\script.module.simplejson\lib;C:\Program Files (x86)\Kodi\system\python\DLLs;C:\Program Files (x86)\Kodi\system\python\Lib;C:\Program Files (x86)\Kodi\python27.zip;C:\Program Files (x86)\Kodi\system\python\lib\plat-win;C:\Program Files (x86)\Kodi\system\python\lib\lib-tk;C:\Program Files (x86)\Kodi;C:\Program Files (x86)\Kodi\system\python;C:\Program Files (x86)\Kodi\system\python\lib\site-packages
11:53:36 T:7532 DEBUG: CPythonInvoker(1, C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py): entering source directory C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl
11:53:36 T:7532 DEBUG: CPythonInvoker(1, C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py): instantiating addon using automatically obtained id of "plugin.video.nhlgcl" dependent on version 2.19.0 of the xbmc.python api
11:53:36 T:7532 ERROR: C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py:516: SyntaxWarning: import * only allowed at module level
def logout(display_msg=None):
11:53:36 T:7532 NOTICE: Mode: None
11:53:36 T:7532 NOTICE: Name: None
11:53:36 T:7532 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IOError'>
Error Contents: (2, 'No such file or directory', 'C:\\Users\\Darryl\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.nhlgcl\\cookies.lwp')
File "C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py", line 602, in <module>
categories()
File "C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py", line 14, in categories
logout()
File "C:\Users\Darryl\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py", line 519, in logout
cj.load(os.path.join(ADDON_PATH_PROFILE, 'cookies.lwp'),ignore_discard=True)
File "C:\Program Files (x86)\Kodi\system\python\Lib\cookielib.py", line 1761, in load
f = open(filename)
IOError: (2, 'No such file or directory', 'C:\\Users\\Darryl\\AppData\\Roaming\\Kodi\\userdata\\addon_data\\plugin.video.nhlgcl\\cookies.lwp')
11:53:36 T:7532 INFO: Python script stopped
11:53:36 T:7532 DEBUG: Thread LanguageInvoker 7532 terminating
11:53:36 T:7876 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
11:53:36 T:7868 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.nhlgcl/
11:53:36 T:7868 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.nhlgcl/) failed
11:53:36 T:7868 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video)
11:53:36 T:7868 DEBUG: ParentPath = [addons://sources/]
11:53:36 T:7212 NOTICE: Thread BackgroundLoader start, auto delete: false
11:53:36 T:7868 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
11:53:36 T:7212 DEBUG: Thread BackgroundLoader 7212 terminating
11:53:40 T:7868 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
11:53:40 T:7868 DEBUG: CInputManager::OnKey: escape (0xf01b) pressed, action is PreviousMenu
11:53:40 T:7868 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
11:53:40 T:7868 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
11:53:40 T:7868 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
11:53:40 T:7868 DEBUG: ------ Window Init (Home.xml) ------
11:53:41 T:7868 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
11:53:41 T:7868 DEBUG: ------ Window Init (Pointer.xml) ------
11:53:44 T:7868 DEBUG: CInputManager:TonguerocessMouse: trying mouse action leftclick
11:53:44 T:7868 DEBUG: Activating window ID: 10111
11:53:44 T:7868 DEBUG: ------ Window Init (DialogButtonMenu.xml) ------
11:53:44 T:7868 INFO: Loading skin file: DialogButtonMenu.xml, load type: KEEP_IN_MEMORY
11:53:45 T:7868 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
11:53:45 T:7868 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
11:53:45 T:7868 DEBUG: ------ Window Deinit (Pointer.xml) ------
11:53:46 T:7868 INFO: Python, unloading python shared library because no scripts are running anymore
11:53:47 T:7868 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
11:53:47 T:7868 DEBUG: CInputManager::OnKey: return (0xf00d) pressed, action is Select
11:53:47 T:7868 DEBUG: CAnnouncementManager - Announcement: OnQuit from xbmc
11:53:47 T:7868 DEBUG: GOT ANNOUNCEMENT, type: 8, from xbmc, message OnQuit
11:53:47 T:7868 NOTICE: Storing total System Uptime
11:53:47 T:7868 NOTICE: Saving settings
11:53:47 T:7868 NOTICE: stop all
11:53:47 T:7868 NOTICE: stop player
11:53:47 T:7868 INFO: stopping PVRManager
11:53:47 T:7876 DEBUG: Thread JobWorker 7876 terminating (autodelete)
11:53:47 T:7868 DEBUG: CNetwork::NetworkMessage - Signaling network services to stop
11:53:47 T:7868 NOTICE: ES: Stopping event server
11:53:47 T:7868 DEBUG: CNetwork::NetworkMessage - Waiting for network services to stop
11:53:47 T:7440 DEBUG: Thread JobWorker 7440 terminating (autodelete)
11:53:47 T:7868 NOTICE: stopping upnp
11:53:48 T:7136 NOTICE: ES: UDP Event server stopped
11:53:48 T:4432 DEBUG: Thread TCPServer 4432 terminating
11:53:48 T:7136 DEBUG: Thread EventServer 7136 terminating
11:53:48 T:5736 DEBUG: Thread PeripBusUSB 5736 terminating
11:53:48 T:8060 DEBUG: Thread PeripBusCEC 8060 terminating
11:53:48 T:7868 NOTICE: stop sap announcement listener
11:53:48 T:7868 NOTICE: clean cached files!
11:53:48 T:7868 NOTICE: unload skin
11:53:48 T:7868 INFO: Unloading old skin ...
11:53:48 T:7868 DEBUG: ------ Window Deinit () ------
11:53:48 T:7868 DEBUG: ------ Window Deinit (Home.xml) ------
11:53:48 T:7868 DEBUG: ------ Window Deinit (DialogButtonMenu.xml) ------
11:53:48 T:7868 DEBUG: CTextureBundleXBT::Cleanup - Closed bundle
11:53:48 T:7868 DEBUG: ADDON: Stopping service addons.
11:53:48 T:7828 DEBUG: Thread ActiveAE 7828 terminating
11:53:48 T:7784 DEBUG: Thread AESink 7784 terminating
11:53:48 T:7868 DEBUG: CAESinkDirectSound:Big Grineinitialize: Cleaning up
11:53:48 T:7868 NOTICE: stopped
11:53:48 T:7868 NOTICE: destroy
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.nosefart has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.vbox has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.audioencoder has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in repository.eracknaphobia has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in kodi.audiodecoder has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.modplug has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in kodi.guilib has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.vortex has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.vorbis has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.wma has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.wav has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in plugin.video.nhlgcl has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.flac has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.ym has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in kodi.resource has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.milkdrop has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.dxspectrum has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in script.module.pytz has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.sidplay has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in skin.re-touched has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.pctv has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.vgmstream has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.xbmc.builtin.aac has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in resource.language.en_gb has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.stalker has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audiodecoder.snesapu has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in audioencoder.lame has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.webinterface has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in resource.uisounds.confluence has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.filmon has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been uninstalled.'
11:53:48 T:7868 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been uninstalled.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0180 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0F48 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0408 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0888 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0690 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0210 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C35418 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043C0498 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04C34B60 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043564A0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043361A8 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04335F68 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 043562F0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 INFO: ADDON: cpluff: 'An unreleased information object was encountered at address 04335FB0 with reference count 1 when destroying the associated plug-in context. Not releasing the object.'
11:53:48 T:7868 NOTICE: closing down remote control service
11:53:48 T:7804 DEBUG: Thread RemoteControl 7804 terminating
11:53:48 T:7868 NOTICE: unload sections
11:53:48 T:7868 NOTICE: special://profile/ is mapped to: special://masterprofile/
11:53:49 T:7868 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
11:53:49 T:7868 NOTICE: destroy
11:53:49 T:7868 WARNING: Attempted to remove window 10013 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10014 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10015 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10016 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10017 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10018 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10019 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10021 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10107 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10115 from the window manager when it didn't exist
11:53:49 T:7868 WARNING: Attempted to remove window 10104 from the window manager when it didn't exist
11:53:49 T:7868 NOTICE: closing down remote control service
11:53:49 T:7868 NOTICE: unload sections
11:53:49 T:7868 NOTICE: application stopped...
11:53:49 T:7868 DEBUG: PVRManager - destroyed
11:53:49 T:7868 DEBUG: SECTION:UnloadDll(special://xbmcbin/system/libcurl.dll)
11:53:49 T:7868 ERROR: dllFreeLibrary - Invalid hModule specified
(2016-02-10, 19:09)eracknaphobia Wrote: [ -> ]
(2016-02-10, 16:37)cookiemonster70 Wrote: [ -> ]
(2016-02-10, 04:19)eracknaphobia Wrote: [ -> ]I think the fact 12 games are on right now probably has a lot to do with it.
Yes it was painful till after 10pmEST. I'm doing some research into alternate CDN's and hope to have ability like I added on previous addon to change the CDN server which should help out. At this time i'm just compiling the data and hopefully will have something soon.
Sounds interesting. I'm a bit confused though, shouldn't the cdn network decide which server you should connect to based on your location? I suppose setting the cdn server manually might be a good thing for people who use proxies but not for people who are using there true location. Interested to here your thoughts.
That is true. however the NHL uses and believe even with the new system uses two CDN Providers (Level3 & Akamai) While they primarily use Akamai for VOD they do also put Live streams to Akamai as their secondary CDN for Live streams. So lately the issues and the ones on NHL.tv launch was that Level 3 had miss configured something on their network while Akamai functioned fine. Hence why some said things went without a hitch. What I'm researching is how they are dividing things up because it doesn't seem the same way as before NHL.tv. Once I get that figured out i'll be close to being able to add the option.
The option will help mostly those using a proxy/vpn/dns proxy however it will help those who do not and are in a saturated market such as Toronto/NY/Detroit/Chicago where almost every one in that area would connect to the same CDN provider server and dragging it down. While the other one is doing next to nothing.
It of coarse will still always connect to closest server for either Akamai or Level 3. This is where DNS proxy could work better as it will still go to the closest server to your real ip location rather then say a proxy/vpn that is in Germany which would cause your Latency to be much greater and thus give more freezing/buffering.
I know after I added the option on the previous addon many stopped having freezing and when they did had option to try another server which eliminated or minimized that issue.
Before they had 3 CDN providers but what I'm seeing right now is just the two I mentioned but like I said i'm still compiling data. My biggest fear is they separated Live & VOD on each separate CDN providers which maybe the account for all the issues they have as one CDN provider can not coupe with all the traffic when they have more then 3-4 Games in one night. So far this is what I'm seeing but they may fallback to their previous ways with all the complaints and bad publicity the new system has been taking. Though I'm still at the early stage of collecting data for this to say for certain.
(2016-02-10, 20:08)Tad3r Wrote: [ -> ]Running an alienware alpha with windows 8 most current kodi and when I try and start the addon it says nhl tv error.. Any help I can get it would be greatly appreciated. Maybe a small guide on posting a log too would help
For wanting a guide you sure don't seem to want to read them:
http://kodi.wiki/view/Log_file/Easy
Read step 7 carefully
(2016-02-10, 20:57)Steakface Wrote: [ -> ]
(2016-02-10, 16:27)cookiemonster70 Wrote: [ -> ]Unblock-us is working.
Lucky! I haven't been able to get this addon to work with Unblock-us enabled on either the PC version or my Android TV (though it won't even launch for the TV) and tablet for a while now. Works on the official Ps4 app, though. Have to deal with soap opera effect to smooth out the crappy 30fps when I watch in-market games.... I've tried everything and nobody can seem to figure anything out from my logs.
Have you checked to make sure the DNS is set to unblock-us on your Kodi box(s) it maybe manually set to another such as google (8.8.8.8) are you setting the unblock-us DNS on your router on each individual device? As it sounds like the latter and the Kodi box(s) are set to other DNS.
Also one way to check is to in Kodi box(s) open browser and go to unblock-us.com and see if it passes it test
(2016-02-10, 20:46)Tad3r Wrote: [ -> ]Need Help. Have An Alienware Alpha i7 16gigs ram fresh install of kodi isenguard and when I type in my credentials then go to laung app fails. anyone else having this problem?
Did you hit the OK or did you just hit back after entering he credentials. As the log indicates that no settings were entered thus not creating the proper folder.
(2016-02-10, 21:20)cookiemonster70 Wrote: [ -> ]
this is the url for the log
http://www.xbmclogs.com/pqbairbcw
Yes I Did It Again To See If I COuld Get It To Work. But Still Nothing.
Do I Need The Gamecenter Addon For This One To Work?
I would like to apologize to everyone for my poor forum skills. still learning and appreciate how patient you all are.
