2016-02-10, 21:59
(2016-02-10, 21:43)Tad3r Wrote: [ -> ]I would like to apologize to everyone for my poor forum skills. still learning and appreciate how patient you all are.
Can you go edit your prior post so it doesn't take up so much space.
TIA
(2016-02-10, 21:26)Tad3r Wrote: [ -> ]this is the url for the log
http://www.xbmclogs.com/pqbairbcw
Yes I Did It Again To See If I COuld Get It To Work. But Still Nothing.
Do I Need The Gamecenter Addon For This One To Work?
(2016-02-10, 21:06)cookiemonster70 Wrote: [ -> ]That is true. however the NHL uses and believe even with the new system uses two CDN Providers (Level3 & Akamai) While they primarily use Akamai for VOD they do also put Live streams to Akamai as their secondary CDN for Live streams. So lately the issues and the ones on NHL.tv launch was that Level 3 had miss configured something on their network while Akamai functioned fine. Hence why some said things went without a hitch. What I'm researching is how they are dividing things up because it doesn't seem the same way as before NHL.tv. Once I get that figured out i'll be close to being able to add the option.
The option will help mostly those using a proxy/vpn/dns proxy however it will help those who do not and are in a saturated market such as Toronto/NY/Detroit/Chicago where almost every one in that area would connect to the same CDN provider server and dragging it down. While the other one is doing next to nothing.
It of coarse will still always connect to closest server for either Akamai or Level 3. This is where DNS proxy could work better as it will still go to the closest server to your real ip location rather then say a proxy/vpn that is in Germany which would cause your Latency to be much greater and thus give more freezing/buffering.
I know after I added the option on the previous addon many stopped having freezing and when they did had option to try another server which eliminated or minimized that issue.
Before they had 3 CDN providers but what I'm seeing right now is just the two I mentioned but like I said i'm still compiling data. My biggest fear is they separated Live & VOD on each separate CDN providers which maybe the account for all the issues they have as one CDN provider can not coupe with all the traffic when they have more then 3-4 Games in one night. So far this is what I'm seeing but they may fallback to their previous ways with all the complaints and bad publicity the new system has been taking. Though I'm still at the early stage of collecting data for this to say for certain.
(2016-02-10, 22:35)Mickelin Wrote: [ -> ]New user trying to get the addon working. I get "Error: Script Failed NHL.Tv" when launching the addon. Rebooted and re-installed addon several times. From what I can see in the log, seems to be something wrong with the install, since it is complaining about "no such file or directory".
Log here: http://xbmclogs.com/pqmjlao5d
Relevant parts starts around line 850
Thanks for any help!
(2016-02-10, 22:40)eracknaphobia Wrote: [ -> ](2016-02-10, 22:35)Mickelin Wrote: [ -> ]New user trying to get the addon working. I get "Error: Script Failed NHL.Tv" when launching the addon. Rebooted and re-installed addon several times. From what I can see in the log, seems to be something wrong with the install, since it is complaining about "no such file or directory".
Thanks, got it. looks like the new version has a bug that only effects users who never had any of the previous versions installed. For the time being you could install version 2016.2.7 then update to the latest.
(2016-02-10, 23:14)Mickelin Wrote: [ -> ](2016-02-10, 22:40)eracknaphobia Wrote: [ -> ](2016-02-10, 22:35)Mickelin Wrote: [ -> ]New user trying to get the addon working. I get "Error: Script Failed NHL.Tv" when launching the addon. Rebooted and re-installed addon several times. From what I can see in the log, seems to be something wrong with the install, since it is complaining about "no such file or directory".
Thanks, but no luck.Uninstalled 2.9, rebooted, installed 2.7, updated to 2.9, same error.
New log, NHL.tv launch at line 1855: http://xbmclogs.com/p0toy9trk
(2016-02-10, 21:15)cookiemonster70 Wrote: [ -> ](2016-02-10, 20:57)Steakface Wrote: [ -> ](2016-02-10, 16:27)cookiemonster70 Wrote: [ -> ]Unblock-us is working.Lucky! I haven't been able to get this addon to work with Unblock-us enabled on either the PC version or my Android TV (though it won't even launch for the TV) and tablet for a while now. Works on the official Ps4 app, though. Have to deal with soap opera effect to smooth out the crappy 30fps when I watch in-market games.... I've tried everything and nobody can seem to figure anything out from my logs.
Have you checked to make sure the DNS is set to unblock-us on your Kodi box(s) it maybe manually set to another such as google (8.8.8.8) are you setting the unblock-us DNS on your router on each individual device? As it sounds like the latter and the Kodi box(s) are set to other DNS.
Also one way to check is to in Kodi box(s) open browser and go to unblock-us.com and see if it passes it test
