(2016-02-14, 04:31)chief27 Wrote: [ -> ] (2016-02-14, 04:03)andrewmo Wrote: [ -> ]+1 for 30FPS on recaps, the 60FPS only appears to be on the live feeds.
The replays are only 30 fps because thats what the NHL offers. Nothing devs can do about that.
I get 60 fps on live game and recap and full game replay.
Edit : sorry not on recap. Just full games replay and live games.
Not quite, I see 60fps 5000kbps for
Extended Highlights and
Recap in my NHL addon version.
http://forum.kodi.tv/showthread.php?tid=...pid2245030
I think this version seems playing 30fps 3500kbps for
Recap instead of 60fps 5000kbps stream.
I'm getting much better results with the 2016.2.13 version. I've switched between a few games this evening without getting the "too many attempts" error.
Erack, you are a beast!
@eracknaphobia: I was using the Gamecenter-Plugin for some time prior to Feb.1 with Kodi on my Philips Android TV since there was no "compatible" app for this Android version. It took some time since I found this thread. Now it's working again! Many thanks - it's brilliant! When will your new NHL.TV add on make it to the official Kodi repository?
I keep getting script error, please need help
Until Version 2.11 you got 60fps Streams.
(2016-02-14, 03:46)WHamilton Wrote: [ -> ]There is a problem with quality settings. Recaps and Highlights are only with 30fps.
And the options best, 5000, 3500, 2500 don't make a difference.
This will be fixed in the next release.
Quote:fanarts only display when a spoiler is active. It this correct?
This was intentional because when I was using actual pictures from the game sometimes the score would be on the screen. Now that I've switched the fanart to the two team logos, I can remove this restraint.
Quote:I am testing no spoilers only archives games. the early games are over but the scoring is already on.
I don't know what you want? I think there are more than enough options with spoilers, considering the official apps only allow an on or off option.
(2016-02-14, 05:52)monomorph Wrote: [ -> ]@eracknaphobia: I was using the Gamecenter-Plugin for some time prior to Feb.1 with Kodi on my Philips Android TV since there was no "compatible" app for this Android version. It took some time since I found this thread. Now it's working again! Many thanks - it's brilliant! When will your new NHL.TV add on make it to the official Kodi repository?
Not likely since there are already two others in the official kodi repo. I am completely fine with not being in there and kind of enjoy the "not-so-much" attention it gets, especially since I have other addons in the kodi repo I have to maintain. This started as a personal copy for myself that I decided to share. If others find it enjoyable then even better, but I'm not looking to draw a large audience. Although it seems that it may be too late considering the views on this thread have gone from 5,000 in December to over 25,000 in February.
(2016-02-14, 09:57)Jason74 Wrote: [ -> ]I keep getting script error, please need help
We need a log file. There is a link to the guide on how to upload a log on the first post.
(2016-02-14, 15:55)eracknaphobia Wrote: [ -> ] (2016-02-14, 05:52)monomorph Wrote: [ -> ]
Many thanks for that. You did us all a great favor. I watched 3 games last night without addon issue. Picture quality was great.
Great work.
Since 2/13 update I don't get the Sign On error anymore.
However when selecting a full game to watch from yesterday it just cranks for a while but doesn't actually start playing.
(2016-02-13, 18:33)hscotty55 Wrote: [ -> ]This add-on does not work on Pivos Tofu Linux. There is something in the Tofu Linux firmware that causes live games not to play.
Looks like it's caused by this for me (which really sucks):
http://www.pivosforums.com/viewtopic.php...1ad7a941e9
Log here:
http://xbmclogs.com/pcij5kim6
09:07:19 T:1547453488 DEBUG: ffmpeg[5C3C4430]: [hls,applehttp] HLS request for url 'http://hlslive-l3c.med2.med.nhl.com/ls04/nhl/2016/02/14/NHL_GAME_VIDEO_NSHFLA_M2_HOME_20160214/5000K/00/00/29.ts', offset 0, playlist 0
09:07:19 T:1547453488 DEBUG: ffmpeg[5C3C4430]: https protocol not found, recompile with openssl or gnutls enabled.
It does play recent full games fine on my Pivos XS box downstairs running android and Kodi 15.2.
Here's a log for that one:
http://xbmclogs.com/pl9myz08n
Don't think it's a plug in problem. The pre-MLB versions of the plugin worked fine on both boxes.
I use unlocator now instead of unblock us. And it works awesome on fire tv thank you
Hey guys
Running this app on a raspberry pi and I keep getting a playback error. Anybody know of a resolution?
I can post logs if that helps
Running 2016.2.13 and when I go to today's games I get the date 1970 and not today's date. The streaming works fine when I go to the right date and select the game, but any fix for why today's date does not take me to the right date?
