Full Version: NHL TV™
seems to work fine through Windows too - thank you
(2016-02-15, 10:35)richyw Wrote: [ -> ]Hi
Tried 2016.2.14 last night - works fine now I think (Kodi 15.2 on Fire Stick)
After watching a game I logged out and then watched part of a 2nd and 3rd game (logged out each time)
No usage attempts this time - will try again tonight
Picture quality is excellent - better than ever
Richy UK
I wouldn't recommend logging out unless you absolutely have to, you will eventually trip the sign on restriction if you do too many in a short amount of time.
There really isn't any reason you should ever log out now, the addon will update your cookies and session key on the fly as you change streams. I only left the logout feature in there for the off chance someone should need to force a new login.
(2016-02-15, 16:11)eracknaphobia Wrote: [ -> ]
Richy UK
Thanks - that's even better
I only did it because I read previously that too many log-ins on various apps could have been the issue
I will try again tonight - normal use - and let you know how it goes
Many thanks again for your help
Richy
UK
Hi, awesome add-on. Thanks for your efforts!
Can I get a little help though? I'm having a hard time installing upgrade 2014.02.14 - I'm getting error messages saying that dependencies aren't met: BeautifulSoup4 (which I think I've resolved) and pytz (which I haven't figured out). Then installation of this nhl.tv addon fails...
I'm running Kodi 15.2 on Windows10. This is the first update where I've experienced this problem.
I'm also running nhl.tv (2014.02.14) on my Win7 and Mac OSX 10.11.3 without any issues... so thanks again!
I'll upload a log shortly. Meanwhile, is there any way that I can just wipe clean and do a clean install of this addon rather than bother trying to dabble with dependencies and such??
D.
Hello is there a way to make your app compatible to the unblock-us dns? Please help.
us there any way to help. Please
(2016-02-15, 18:57)derebela Wrote: [ -> ]Hi, awesome add-on. Thanks for your efforts!
D.
Have you tried simply uninstalling the addon and trying to install 2016.2.14?
(2016-02-15, 19:16)cruisecruise Wrote: [ -> ]Hello is there a way to make your app compatible to the unblock-us dns? Please help.
It is for some, so it's something you will have to ask unblock us about.
(2016-02-15, 19:21)eracknaphobia Wrote: [ -> ]
D.
Thanks for the quick reply. Yes, I have uninstalled and reinstalled several times... still getting the dependenci error. After I installed the BeautifulSoup4 manually that error seemed to be resolved. Now I'm faced with the "pytz failed to install" error message..
D.
(2016-02-15, 19:29)derebela Wrote: [ -> ]
D.
D.
Ok, I just wanted to check. Kodi should automatically download the dependencies for you but it seems that it is not happening for you. I just tested a fresh install on my win 10 pc and it went through fine, so I don't think it's an OS issue. If you can post a log we might be able to see whats going wrong.
(2016-02-15, 19:32)eracknaphobia Wrote: [ -> ]
(2016-02-15, 19:21)eracknaphobia Wrote: [ -> ]Have you tried simply uninstalling the addon and trying to install 2016.2.14?
D.
Hey. I've solved the problem. I went back and re-downloaded the pytz.zip file, installed it, and then reinstalled nhl.tv and everything is working again. I must have had a damaged pytz.zip file when I tried to install it manually before. Not sure why the dependencies didn't install automatically though?? We'll see what happens with future updates, I guess.
Thanks for your support. Sorry to waste your time.
D.
No problem at all
Hey erack,
I just donated $20 CDN via PayPal. Thanks for sharing this addon and supporting it!! Have a few beers on me!!
Cheers,
D.
Thanks so much Erack!
Sorry if this is a newb question that you don't have time to answer. Maybe someone else could tell me too. Can I skip an update and install subsequent ones or do I need to install every update? I.e. I'm currently on Feb 9. Can I update straight to Feb 14 or do I have to update each one in sequence?
Last question: Is there any way to automatically keep this updated? Otherwise it seems like I should bookmark this link (https://github.com/eracknaphobia/repo.er...deo.nhlgcl) and check back before I'm going to watch some hockey?
Thanks a bunch!
(2016-02-15, 23:36)backcountryski Wrote: [ -> ]Thanks so much Erack!
Thanks a bunch!
If you install my repo (link on the first post) you will receive all updates automatically.
Sorry Eric, turns out it was updating itself since the Feb 9 file that I manually added. Works like a charm! Thanks for all of your hard work. You're killing it!
One last user suggestion. If it were possible, it would be rad to have another main menu folder for my team that I could click to see all of their games (most recent first) and just select the ones I missed to catch up.
Another cool feature might be to auto-run through all of yesterday's highlights and/or extended recaps so people could click a button and then sit there for 30 minutes seeing all of the goods from a given day.
Thanks man!
