Full Version: NHL TV™
(2016-02-19, 03:19)WHamilton Wrote: [ -> ]No idea is this right part of log you need to see. Any thoughts?
Via browser you can see the games?
Well i use Chrome, but tested with Firefox, works with that too.
Recaps or Highlights works on kodi?
(2016-02-19, 03:21)WHamilton Wrote: [ -> ]Recaps or Highlights works on kodi?
Nothing. When i try to open Gamecenter in Kodi, it just says "Check yout login credentials".
I think use the old Gamecenter app. You must use nhl.tv.
(2016-02-19, 03:36)WHamilton Wrote: [ -> ]I think use the old Gamecenter app. You must use nhl.tv.
I only see NHL GameCenter and NHL GameCenter Live addons on the list. And i downloaded that zip what is in first post of this thread.
This is a repo. You must in install the rebo and then in the addon Browser "install fo respotery nhl.tv.
(2016-02-19, 03:42)WHamilton Wrote: [ -> ]This is a repo. You must in install the rebo and then in the addon Browser "install fo respotery nhl.tv.
All right, now working great! Big thanks!
EDIT: Nevermind, great job. Smile
Update 2016.2.19 Released
- Fix for Todays Games saved to favorites
- Added new artwork
- Fix for scoring notification errors
- Added game preview paragraph to todays games
Hello,
I wrote with smartdnsproxy and they search for a solution.
Oh my god I love your add on. Can you perhaps make a fix to bring it to work? I need the dns for the rest of Kodi. Perhaps it's possible to deactivate dns only for your add on? Is there any fix possible. Will give you donation of course. Awesome work
Hi Erack,
Wow, this addon keeps getting better! Like your new artwork and restructuring of the presentation!
One issue I have is that the addon doesn't update automatically to the latest version (even though I have this set). I usually have to manually refresh your repo and then the addon will update. Not sure if there is a setting to refresh the repos automatically?
I have the addon installed in Kodi on a few different PCs here, and some of them (for whatever reason) also do not open to the correct day (when I select "today's games" - the day is set a few days in the past... corresponding to the date the version of the addon was released?)
Thanks again for your continued dedication to this!
Yesterday scoring works without a problem.
But the script has not ended. I ve checked this morning the log file and every minute the addon check the games from friday .
I think a good feature were in the main menu a point "Scoring restart".
Or could you perhaps deactivate the dns for your add on? I got answer and they said the dns should not affect Kodi. But it takes affect ;(
Not sure if this is even possible, could the add-on be updated to show when the games start in local time. I live in the UK and I try to spot any games I can watch at the weekend, and this would be super useful.
