Full Version: NHL TV™
(2016-02-20, 19:44)arqcan Wrote: [ -> ]Not sure if this is even possible, could the add-on be updated to show when the games start in local time. I live in the UK and I try to spot any games I can watch at the weekend, and this would be super useful.
I'm in Sweden and my games are shown in local time. Have you checked your time zone setting in your NHL account?
Add-on works perfectly now by the way, thanks for all your hard work!
I get error on full game replays saying "media is in unplayable state"
Hello, first time poster.
I have set up the addon on both my Macbook and a friends Windows PC. Both of us are Rogers customers and everything has worked perfectly.
However on my Himedia Q3 Android box, I cannot get any live games to play. I get to the selection of home or away stream, the stream shows opening 96%....then nothing.....and back to the list of games.
Anyone have any suggestions?
Thanks in advance
New update still working fine - watched a full Rangers game last night and this morning - no problems - excellent picture quality - great job
Kodi on firetv stick
Richy uk
Hey Erack,
Quick update; the addon is working perfecting via Kodi on all of my setups: OSX, Win10, Win7, AppleTV2, iPad, and iphone.
Thanks alot!
I'm using the Eminence skin, and for me the 'Big Posters' view appears to be the best for the games list. What file/line do I need to edit to make this the default?
(2016-02-20, 20:17)Mickelin Wrote: [ -> ]
I've had a quick check on the NHL website but there doesn't appear to be anything to let me set the time zone, i might be super dense and just not seeing it. I'll have a look in Kodi and see if its just a setting I've missed.
(2016-02-21, 19:06)arqcan Wrote: [ -> ]
Here in Germany. I see also the local start times.
(2016-02-21, 19:15)WHamilton Wrote: [ -> ]Here in Germany. I see also the local start times.
Same Smile
Also, just installed this addon to replace my old GCL ones, great plugin! Thanks for creating and updating it, it's really appreciated. Had zero issues so far and the menu structure looks great and it it is informative. Keep it up Smile
install add on i have sound no video can somebody help new to this
(2016-02-20, 16:16)cruisecruise Wrote: [ -> ]Or could you perhaps deactivate the dns for your add on? I got answer and they said the dns should not affect Kodi. But it takes affect ;(
Same problem here. Unlocator kicks me off every time. I am with cruisecruise. I would pay for this. Erack, this is INCREDIBLE! Great work - now if I could just get it to work w/unlocator :-(
Hi all, I installed the latest zip file on my nexus player. Everything installed fine but all I can play are the highlights (which look great by the way,) live games are just giving me an error. This is using Jarvis which just updated today, I never got a chance to try on an earlier build. Any ideas? Thanks.
(2016-02-22, 07:37)sask3m Wrote: [ -> ]Hi all, I installed the latest zip file on my nexus player. Everything installed fine but all I can play are the highlights (which look great by the way,) live games are just giving me an error. This is using Jarvis which just updated today, I never got a chance to try on an earlier build. Any ideas? Thanks.
problems with ssl would i say.
(2016-02-21, 19:00)sdsnyr94 Wrote: [ -> ]I'm using the Eminence skin, and for me the 'Big Posters' view appears to be the best for the games list. What file/line do I need to edit to make this the default?
I'll look into making a setting to allow the user to set View Mode, right now it's hard coded to Media Info 1. You can switch the xbmc.executebuiltin("Container.SetViewMode(504)") lines if you wish to do this manually for the time being.
(2016-02-21, 20:43)mazdarx8 Wrote: [ -> ]install add on i have sound no video can somebody help new to this
What platform are you using Kodi on? First I would look at your video acceleration options (System > Settings > Video > Acceleration) and try different variations until you get steady playback.
