Full Version: NHL TV™
When exactly are you getting the error? By the way I installed jarvis over isengard and pretty sure I didn't lose anything.
I can't watch the game Tor-Was tonight. Was working flawlessly with addfreetime yesterday.
What should I be looking for in the log to know that it's a blackout issue or a problem with the addon ?
The Washington feed was working for me a while ago.
I get Error script failed. I was able to watch the games through pros ports. I just figured since Game Center live is free with my internet package I would use it and hopefully get a little better feed. I guess I could load Jarvis and see if that helps. I will try it tomorrow. do you suggest I do a clean install or just install over. I did a clean install last time.
(2016-03-03, 03:25)Water101 Wrote: [ -> ]I get Error script failed. I was able to watch the games through pros ports. I just figured since Game Center live is free with my internet package I would use it and hopefully get a little better feed. I guess I could load Jarvis and see if that helps. I will try it tomorrow. do you suggest I do a clean install or just install over. I did a clean install last time.
I just d/l it and double click the exe and let it install over. If you can log in on nhl.com and watch the games then that log in will work. Have you checked through this thread I know others were having errors so you might a fix for your issue. By the way keep at it because this addon is light years ahead in quality than any app I've used.
(2016-03-03, 04:22)sask3m Wrote: [ -> ]
Thanks I will give it a try. I did research for a while that is how I was able to get the best app and get it to almost work
(2016-03-01, 16:58)eracknaphobia Wrote: [ -> ]Update 2016.3.1 Released
- Fix for scoring notifications not shutting down when all live games have finished
- Fix for Todays games rolling to the next day (est) when late games are still live
which time games rolling?
Now (4 am EST), next morning in germany (10 AM), i see the games of last night and because i use spoilers for live games / no spoilers for archive games the final score also.
(2016-03-02, 23:30)sask3m Wrote: [ -> ]
(2016-03-02, 21:27)Habskilla Wrote: [ -> ]Is there a way to record the stream for later/delayed viewing?
All the games are archived for viewing.
Yes there is, but there is no way to restart a live stream?
(2016-03-03, 18:33)Habskilla Wrote: [ -> ]
Probably won't happen. It's a Kodi limitation if I recall correctly. Only roku has that ability
Timewasted's version of the Add-on had this feature, but it is currently broken since the server switch in January.
(2016-03-03, 19:23)sarlan19 Wrote: [ -> ]
(2016-03-02, 23:30)sask3m Wrote: [ -> ]All the games are archived for viewing.
The PS3 can do it also, as did the latest version of the gamecenter app on kodi before it stopped. I asked the question about restarting a live stream earlier also. Apparently earlier in the thread it was stated that this probably won't happen. To me this is the only problem with an otherwise GREAT app. I use my PS3 for times like this since I can restart a live game there. If I catch up live or the game has ended I switch over to Kodi for the quality.
I'll pay to have this feature.
(2016-03-03, 23:17)Giantwinston Wrote: [ -> ]The PS3 can do it also, as did the latest version of the gamecenter app on kodi before it stopped. I asked the question about restarting a live stream earlier also. Apparently earlier in the thread it was stated that this probably won't happen. To me this is the only problem with an otherwise GREAT app. I use my PS3 for times like this since I can restart a live game there. If I catch up live or the game has ended I switch over to Kodi for the quality.
If it were easy to do, I would have done it by now. As already stated here
A little more on the topic:
Kodi has no built-in way to start a live stream from a certain point, it just automatically starts playing it. There is a beginning but there is no end. Think of it as a sliding scale, as new segments are fetched old ones are thrown out. Only when the stream is complete (has a beginning and an end) will kodi start from the beginning and be able to fast forward / rewind.
Additionally when a live stream is playing, the stream makes http calls to verify that the person playing it has valid authentication, these calls use to be incremented in a recognizable pattern. Timewasted was clever enough to study the live stream and from the pattern given create future segments to complete the stream thus tricking kodi into thinking it was a completed stream and therefore allowing to start from beginning and adding the ability to fast forward / rewind. Since the switch in January the http calls contain a random sequence so there really is no way to predict what the next call will look like.
Even more info:
https://developer.apple.com/library/ios/...index.html
Any help on my error(script failed:NHL Game Center Live) for Game center live same issue even when I installed Jarvis. I checked my settings in Kodi and it says I am running Kodi 14.2 GIT 2015-04-25-129d75b.
(2016-03-03, 23:56)Water101 Wrote: [ -> ]Any help on my error(script failed:NHL Game Center Live) for Game center live same issue even when I installed Jarvis. I checked my settings in Kodi and it says I am running Kodi 14.2 GIT 2015-04-25-129d75b.
Wrong thread, you probably want this one: http://forum.kodi.tv/showthread.php?tid=118853
(2016-03-03, 23:59)eracknaphobia Wrote: [ -> ]
I installed the your add on from the first page of this thread.
