(2016-03-12, 21:56)sask3m Wrote: [ -> ] (2016-03-12, 21:44)Mickelin Wrote: [ -> ] (2016-03-12, 08:11)sask3m Wrote: [ -> ]Unlocator was working with this add-on and I believe they have a 7 day free trial to give it a go.
https://unlocator.com/
Unblock-us.com works fine as well, I am watching the Redwings/Rangers game right now
I can't watch any games with unblockus, just get an error.
I too was unable to watch games with unblock-us. Switched to unlocator and am watching Red Wings and Rangers as I post. Thanks for the helpful info.
Strange! I have no problems with unblock-us. Does it work in a browser? What region do you have set?
(2016-03-12, 22:50)Mickelin Wrote: [ -> ]Strange! I have no problems with unblock-us. Does it work in a browser? What region do you have set?
Unblockus won't work for me with KODI using PC or my nexus player, region set to usa.
What about if you login to
www.nhl.com, can you watch games in a browser on the PC? If you go to
www.unblock-us.com, do you get the three green bars? Try setting the region to a non-US setting. I use Mexico, that makes all games out of market and no black-outs occur.
Has anyone noticed that you dont need anymore vpn or dns watching games? In here finland i needed vpn about a week ago, now all games works without.
(2016-03-14, 14:30)Jezze Wrote: [ -> ]Has anyone noticed that you dont need anymore vpn or dns watching games? In here finland i needed vpn about a week ago, now all games works without.
So it seems. Works also on iPad (location services turned on).
Let´s see how long this fun lasts...
Hi there,
First of all, thanks for this awesome add-on. I'm having issues with the Add-on, let me explain.
- I installed Kodi (Jarvis) on my PC with Windows 10. I installed the NHLTV Kodi addon, setup my username/password (using Rogers) and then the addon works perfectly.
- I installed Kodi (Jarvis) on my NAS (Asustor AS5002T). I installed the NHLTV Kodi addon, setup my username/password (using Rogers) and when I try to launch the addon, I get a "NHLTV error, please check logs" message.
- I installed Kodi (Jarvis) on my M8S Android TV Box. I installed the NHLTV Kodi addon, setup my username/password (using Rogers) and when I try to launch the addon, I get a "NHLTV error, please check logs" message.
- I installed Kodi (Jarvis) on my Apple TV (4th generation). I installed the NHLTV Kodi addon, setup my username/password (using Rogers) and when I try to launch the addon, I get a "NHLTV error, please check logs" message.
I've tryed to "Logout" menu option in the NHLTV addon on my working PC installation of Kodi and still no luck on other platforms. Is there something I miss. I've double-checked the login credentials and they are perfectly fine. Note that I have a free Rogers Gamecenter Live access because I'm a Rogers Mobility customer which give free access to Rogers Gamecenter Live.
Any idea ?
No idea, unless we can see the logs
(2016-03-14, 19:16)eracknaphobia Wrote: [ -> ]No idea, unless we can see the logs
I'll try to get the logs tonight.
Damn, even the games from a few days ago are all blocky and constantly buffer. Yet I have excellent signal. I can't figure it out. I've removed the addon, even went as far as removing the directories from the kodi/addons folders.
I've tried hard wired as well, same exact thing. I'm starting to wonder if Unlocator is causing it somehow. Its fine everywhere else though. Just affects the FireTVs (1st gen)
Got it working... Did a full uninstall of kodi.. wiped it all away.. on my fire tv. Re-added just this plugin and it works perfect. Guess i'll add back my stuff slowly to see what is affecting it.
(2016-03-15, 04:51)th3matrix Wrote: [ -> ]Apple TV 4th Gen : http://xbmclogs.com/pvfzbtqd1
URLError: <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:590)>
The apple tv is getting an error when trying to log in to your nhl tv account. If you are using a dns or vpn service, try disabling them. Select a stream you know you are not blacked out from. Then you may try re-enabling your dns / vpn service. Also I noticed you were on kodi 17 alpha release, I haven't done any testing for that so it would probably be safer to stay at 16 for now.
(2016-03-15, 04:51)th3matrix Wrote: [ -> ]Asustor 5002T : http://xbmclogs.com/pise7egmb
from PIL import Image
ImportError: No module named PIL
The asus cannot locate the Python Image Library library which should've been installed with the addon because it is a requirement. Try to uninstall / install the nhl.tv addon again
The last two days the page today game, when is live action, loads sometimes 20 seconds.
(2016-03-15, 14:28)eracknaphobia Wrote: [ -> ] (2016-03-15, 04:51)th3matrix Wrote: [ -> ]Apple TV 4th Gen : http://xbmclogs.com/pvfzbtqd1
So here is the result.
- On the Apple TV, I've installed Jarvis (16) and installed again the NHLTV Addon. Still can't watch any game (even the one that should not be blackouted). I don't have any VPN setup.
- On my Asustor. I've tryed uninstalling the plugin, installed it back but it does not work. I completely uninstalled Kodi and reinstalled it back but no luck. I still have the PIL error saying that the module is not installed.
The module is not in the addon folder (script.module.pil) and I can't find a good way to install it manually. By doing some research, it seems that PIL is no more supported and that Script.Module.Pillow should be used instead (which is backward compatible with PIL).
I am getting a similar error on my Pivos box running Tofulinux 031116 - 16.0 Kodi, NHL.TV plugin version is 2016.3.11
When I launch I get an error saying check the logs.
The log contains the following:
Quote:19:50:01 T:1497748464 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named PIL
File "/root/.kodi/addons/plugin.video.nhlgcl/main.py", line 2, in <module>
from resources.lib.globals import *
File "/root/.kodi/addons/plugin.video.nhlgcl/resources/lib/globals.py", line 14, in <module>
