I've just installed NHL TV and despite the highlights working, I can't watch games. Here is the log of an attempt to watch a game:
15:43:32 T:139964070029312 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:43:32 T:139964070029312 NOTICE: -----------------------------------------------------------------------
15:43:32 T:139964070029312 NOTICE: Starting Kodi (16.0 Git:a5f3a99). Platform: Linux x86 64-bit
15:43:32 T:139964070029312 NOTICE: Using Release Kodi x64 build
15:43:32 T:139964070029312 NOTICE: Kodi compiled Feb 20 2016 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
15:43:32 T:139964070029312 NOTICE: Running on Ubuntu 14.04.4 LTS, kernel: Linux x86 64-bit version 3.13.0-85-generic
15:43:32 T:139964070029312 NOTICE: FFmpeg statically linked, version: 2.8.6-kodi-2.8.6-Jarvis-16.0
15:43:32 T:139964070029312 NOTICE: Host CPU: Intel® Pentium® CPU B960 @ 2.20GHz, 2 cores available
15:43:32 T:139964070029312 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
15:43:32 T:139964070029312 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
15:43:32 T:139964070029312 NOTICE: special://masterprofile/ is mapped to: /home/trevor/.kodi/userdata
15:43:32 T:139964070029312 NOTICE: special://home/ is mapped to: /home/trevor/.kodi
15:43:32 T:139964070029312 NOTICE: special://temp/ is mapped to: /home/trevor/.kodi/temp
15:43:32 T:139964070029312 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
15:43:32 T:139964070029312 NOTICE: Local hostname: trevor-K54C
15:43:32 T:139964070029312 NOTICE: Log File is located: /home/trevor/.kodi/temp/kodi.log
15:43:33 T:139964070029312 NOTICE: load settings...
15:43:33 T:139964070029312 NOTICE: Found 1 Lists of Devices
15:43:33 T:139964070029312 NOTICE: Enumerated PULSE devices:
15:43:33 T:139964070029312 NOTICE: Device 1
15:43:33 T:139964070029312 NOTICE: m_deviceName : Default
15:43:33 T:139964070029312 NOTICE: m_displayName : Default
15:43:33 T:139964070029312 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
15:43:33 T:139964070029312 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:43:33 T:139964070029312 NOTICE: m_channels : FL,FR
15:43:33 T:139964070029312 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
15:43:33 T:139964070029312 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
15:43:33 T:139964070029312 NOTICE: Device 2
15:43:33 T:139964070029312 NOTICE: m_deviceName : alsa_output.pci-0000_00_1b.0.analog-stereo
15:43:33 T:139964070029312 NOTICE: m_displayName : Built-in Audio Analog Stereo
15:43:33 T:139964070029312 NOTICE: m_displayNameExtra: Headphones (PULSEAUDIO)
15:43:33 T:139964070029312 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
15:43:33 T:139964070029312 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:43:33 T:139964070029312 NOTICE: Default DVD Player: dvdplayer
15:43:33 T:139964070029312 NOTICE: Default Video Player: dvdplayer
15:43:33 T:139964070029312 NOTICE: Default Audio Player: paplayer
15:43:33 T:139964070029312 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:43:33 T:139964070029312 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:43:33 T:139964070029312 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:43:33 T:139964070029312 NOTICE: Loaded playercorefactory configuration
15:43:33 T:139964070029312 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:43:33 T:139964070029312 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:43:33 T:139963666847488 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
15:43:33 T:139964070029312 NOTICE: Running database version Addons20
15:43:34 T:139964070029312 NOTICE: ADDONS: Using repository repository.xbmc.org
15:43:34 T:139964070029312 NOTICE: ADDONS: Using repository repository.eracknaphobia
15:43:35 T:139964070029312 NOTICE: Setup SDL
15:43:35 T:139964070029312 NOTICE: Checking resolution 16
15:43:35 T:139964070029312 NOTICE: Using visual 0x20
15:43:35 T:139964070029312 NOTICE: GL_VENDOR = Intel Open Source Technology Center
15:43:35 T:139964070029312 NOTICE: GL_RENDERER = Mesa DRI Intel® Sandybridge Mobile
15:43:35 T:139964070029312 NOTICE: GL_VERSION = 3.0 Mesa 10.1.3
15:43:35 T:139964070029312 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
15:43:35 T:139964070029312 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_AMD_performance_monitor GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_draw_buffers_blend GL_AMD_seamless_cubemap_per_texture GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_ARB_texture_cube_map_array GL_ARB_texture_multisample GL_ARB_texture_query_lod GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_ES3_compatibility GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_texture_query_levels GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev GL_EXT_shader_integer_mix
15:43:36 T:139964070029312 NOTICE: Running database version Addons20
15:43:36 T:139964070029312 NOTICE: Running database version ViewModes6
15:43:36 T:139964070029312 NOTICE: Running database version Textures13
15:43:36 T:139964070029312 NOTICE: Running database version MyMusic56
15:43:36 T:139964070029312 NOTICE: Running database version MyVideos99
15:43:36 T:139964070029312 NOTICE: Running database version TV29
15:43:36 T:139964070029312 NOTICE: Running database version Epg11
15:43:36 T:139964070029312 NOTICE: start dvd mediatype detection
15:43:37 T:139964070029312 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:43:37 T:139964070029312 NOTICE: ActiveAE DSP - starting
15:43:37 T:139964070029312 NOTICE: initialize done
15:43:37 T:139964070029312 NOTICE: Running the application...
15:43:37 T:139964070029312 NOTICE: starting zeroconf publishing
15:43:37 T:139964070029312 NOTICE: starting upnp client
15:43:37 T:139962380973824 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
15:43:37 T:139962380973824 NOTICE: UDP: Listening on port 9777
15:43:39 T:139964068476672 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
15:43:39 T:139964068476672 ERROR: CCurlFile::Open failed with code 0 for
http://feeds.kodi.tv/xbmc
15:43:40 T:139963037714176 ERROR: [16/Apr/2016:15:43:40] ENGINE Bus STARTING
15:43:40 T:139963037714176 NOTICE: .
15:43:40 T:139963037714176 ERROR: CherryPy Checker:
The Application mounted at '' has an empty config.
15:43:40 T:139963037714176 ERROR: [16/Apr/2016:15:43:40] ENGINE Serving on
http://127.0.0.1:54321
15:43:40 T:139963037714176 ERROR: [16/Apr/2016:15:43:40] ENGINE Bus STARTED
15:43:46 T:139964068476672 ERROR: CCurlFile::FillBuffer - Failed: Couldn't connect to server(7)
15:43:46 T:139964068476672 ERROR: CCurlFile::Open failed with code 0 for
15:44:19 T:139962196399872 ERROR: /home/trevor/.kodi/addons/plugin.video.nhlgcl/main.py:594: SyntaxWarning: import * only allowed at module level
def logout(display_msg=None):
15:44:32 T:139962196399872 ERROR: Previous line repeats 2 times.
15:44:32 T:139962196399872 WARNING: Attempt to use invalid handle 3
15:44:32 T:139964070029312 NOTICE: DVDPlayer: Opening: |User-Agent=Mozilla/5.0 (iPad; CPU OS 8_4 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Mobile/12H143 ipad nhl 5.0925&Cookie=
15:44:32 T:139964070029312 WARNING: CDVDMessageQueue(player):
ut MSGQ_NOT_INITIALIZED
15:44:32 T:139962196399872 NOTICE: Creating InputStream
15:44:32 T:139962196399872 ERROR: CDVDPlayer::OpenInputStream - error opening [|User-Agent=Mozilla/5.0 (iPad; CPU OS 8_4 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Mobile/12H143 ipad nhl 5.0925&Cookie=]
15:44:32 T:139962196399872 NOTICE: CDVDPlayer::OnExit()
15:44:32 T:139964070029312 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.nhlgcl/?url=&mode=104&name=%5BCOLOR%3DFFF69E20%5D05%3A55+1st%5B%2FCOLOR%5D+New+York+Rangers+at+Pittsburgh+Penguins&game_id=2015030142&epg=%5B%7B%22platform%22%3A+%22web%22%2C+%22items%22%3A+%5B%7B%22eventId%22%3A+%22221-1001664%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22NATIONAL%22%2C+%22mediaPlaybackId%22%3A+%2243540303%22%2C+%22callLetters%22%3A+%22NBC%22%7D%2C+%7B%22eventId%22%3A+%22221-1001664%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22AWAY%22%2C+%22mediaPlaybackId%22%3A+%2243540403%22%2C+%22callLetters%22%3A+%22SN%22%7D%2C+%7B%22eventId%22%3A+%22221-1001664%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22fra%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22FRENCH%22%2C+%22mediaPlaybackId%22%3A+%2243540703%22%2C+%22callLetters%22%3A+%22TVAS%22%7D%2C+%7B%22eventId%22%3A+%22221-1001664%22%2C+%22feedName%22%3A+%22Multi-Cam+1%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22COMPOSITE%22%2C+%22mediaPlaybackId%22%3A+%2243540903%22%2C+%22callLetters%22%3A+%22%22%7D%5D%2C+%22title%22%3A+%22NHLTV%22%7D%2C+%7B%22items%22%3A+%5B%7B%22eventId%22%3A+%22221-1001664%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22HOME%22%2C+%22mediaPlaybackId%22%3A+%2243540503%22%2C+%22callLetters%22%3A+%22WXDX%22%7D%2C+%7B%22eventId%22%3A+%22221-1001664%22%2C+%22feedName%22%3A+%22%22%2C+%22language%22%3A+%22eng%22%2C+%22mediaState%22%3A+%22MEDIA_ON%22%2C+%22gamePlus%22%3A+false%2C+%22freeGame%22%3A+false%2C+%22mediaFeedType%22%3A+%22AWAY%22%2C+%22mediaPlaybackId%22%3A+%2243540603%22%2C+%22callLetters%22%3A+%22WEPN%22%7D%5D%2C+%22title%22%3A+%22Audio%22%7D%2C+%7B%22items%22%3A+%5B%5D%2C+%22topicList%22%3A+%22280291404%22%2C+%22title%22%3A+%22Extended+Highlights%22%7D%2C+%7B%22items%22%3A+%5B%5D%2C+%22topicList%22%3A+%22280291404%22%2C+%22title%22%3A+%22Recap%22%7D%5D&teams_stream=NYRPIT&stream_date=2016-04-16T19%3A00%3A00Z]
15:44:32 T:139964070029312 NOTICE: CDVDPlayer::CloseFile()
15:44:32 T:139964070029312 NOTICE: DVDPlayer: waiting for threads to exit
15:44:32 T:139964070029312 NOTICE: DVDPlayer: finished waiting
