Full Version: NHL TV™
Update installed:
no error, when I start the notification service.
I will test it tonight and report here.
That helped..stream rate was set for best quality..adjusted it to 3000 seems to be the best ...no freezing ...working now..will see how live games go tonight...thanks
(2016-10-13, 15:11)eracknaphobia Wrote: [ -> ]
(2016-10-13, 11:26)WHamilton Wrote: [ -> ]You must use kodi 16. kodi 17.0 is beta and the last update from the addon is from End July and there is no kodi 17.0 support.
Kodi 17 beta 3 (for Windows) works for me? I've only tested archived games, but live games should work too.
The issue I had with NHL.TV add on in Kodi 17 beta's 1,2, and 3 was the sound would be off by 4 or more seconds. I could manually offset the sound and would work just fine but didn't think that was necessary. So with someone else's advice about NHL.TV not being compatible for Kodi 17 yet I downgraded back to Kodi 16. Worked flawlessly.sound was on time. This offset sound problem was only and issue with the NHL.TV add on. I am fine sticking with Kodi 16 a while longer. I can submit a log if need be but since I don't have the issue with Kodi 16 any more I am satisfied with the quality and functionality.
Those that are able to get it to work, what's your setup? (OS, Kodi version)
(2016-10-13, 18:51)Brasqo Wrote: [ -> ]Those that are able to get it to work, what's your setup? (OS, Kodi version)
Windows 10 pro 64bit / Kodi 16.1 Jarvis
(2016-10-13, 16:57)Brasqo Wrote: [ -> ]Tried both 16.0 and 16.1.. 2016.07.27 addon... Using Windows 7 sp1.
Able to login, surf games, Will let me choose a stream, But games willnot startup when I select them. I dont get the spinning wheel of death in the bottom right corner or anything.. Just doesnt do anything.
Quote:19:02:18 T:2968 ERROR: C:\Users\xxx\AppData\Roaming\Kodi\addons\plugin.video.nhlgcl\main.py:624: SyntaxWarning: import * only allowed at module level
def logout(display_msg=None):
19:02:23 T:2724 ERROR: Previous line repeats 1 times.
19:02:23 T:2724 NOTICE: DVDPlayer: Opening: |User-Agent=Mozilla/5.0 (iPad; CPU OS 8_4 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Mobile/12H143 ipad nhl 5.0925&Cookie=
19:02:23 T:2724 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
19:02:23 T:716 NOTICE: Creating InputStream
19:02:23 T:716 ERROR: CDVDPlayer::OpenInputStream - error opening [|User-Agent=Mozilla/5.0 (iPad; CPU OS 8_4 like Mac OS X) AppleWebKit/600.1.4 (KHTML, like Gecko) Mobile/12H143 ipad nhl 5.0925&Cookie=]
19:02:23 T:716 NOTICE: CDVDPlayer::OnExit()
19:02:23 T:2724 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.nhlgcl...
I don't think you are getting logged in. There is no .m3u8 link and the cookie variable is blank. Have you tried Addon-Settings > logout? If you have any dns / vpn proxies setup please disable them and try again.
The login doesn't occur until a stream selection is made.
@eracknaphobia & WHamilton: thanks, I found it!
BTW under my test kodi 17 Version NHL.tv and MLB.tv work now.
Just wanted to say I installed this on my firetv stick with kodi 16.1 and its working good so far. I haven't been able to test a live game but the extended highlights are loading and working great. Thanks for this!!
[1] I'll try to logout/logout when i get home...
[2] I am utilizing a DNS (adfreetime). I used it last year with your app last year w/out issue....If relogging is unsuccessful, i'll disable DNS and try again.
Will report back either way...TY for all of your hardwork eracknaphobia!
(2016-10-13, 19:01)eracknaphobia Wrote: [ -> ]
Thanks so much Eracknaphobia !!! :-)
I had no issues with two kodi 16.1 (win 10AU) boxes last night. Also I had no issue with Amazon FTV (first gen); I think I have kodi 16 on it.
(2016-10-13, 14:57)eracknaphobia Wrote: [ -> ]
(2016-10-13, 14:56)J_K_M_A_N Wrote: [ -> ]Is anyone having trouble playing highlights? I don't have an account but I know it used to work. My log says something about Unknown URL type in an exception. Then it says it skips unplayable item. I can post a log file if it seems new but I thought I would check first.
J_K_M_A_N
Just noticed this too. I will be looking into a fix for this.
I forced an uninstall and installed the newer version and the highlights are working now. Not sure if you changed something or if the NHL site was just mixed up for a while or if uninstalling helped something but thanks! This is an awesome plugin.
Another quick question, can anyone confirm if you can watch your home team with this (and an account obviously)? I know with center ice, they blackout the games of your local team most of the time. Not sure if this is different. We pretty much only have cable for the hockey games. This would be much cheaper. Smile
J_K_M_A_N
Yes recap and extended Highlights working now.
(Without anything changin)
(2016-10-13, 22:44)J_K_M_A_N Wrote: [ -> ]
J_K_M_A_N
J_K_M_A_N
I can't confirm yet for the kodi version but for anything officially nhl tv app, You need a service like unlocator or adfreetime. Costs are about 3-5.00 per month and that will spoof you so you can watch every NHL game that normally would be blacked out. But its totally worth it to use it. If not, you will be blacked out for all your local team's games, anything thats on nhl network or nbc sports network.
EDIT 6:29pm et:
I cleaned my cache, changed my PW on the NHL.TV site... Put the new password into your app, now everything is working!!!...
Ok, updated to newest app version 10/13. Still on Kodi 16.1... Win 7 sp1....
I can currently only watch recap and extended highlights (will test live game tonight)...
I cannot watch a Full Replay of a game.. Saying my login/pw are not correct. I tried to "logout" thru the app, then tried again without success...
(2016-10-13, 23:09)WHamilton Wrote: [ -> ]Yes recap and extended Highlights working now.
