Full Version: Windows sharing + Fire tv
Hello,
Is there a guide on how to share a folder on a win8 pc with the fire tv.
It has been ages since I managed to share and make it work flawlessly.
Thanks in advance.
Does the sticky at the top of forum called "Windows 8 SMB Share" help you?
(2015-10-15, 16:54)wyild1 Wrote: [ -> ]Does the sticky at the top of forum called "Windows 8 SMB Share" help you?
You mean "Windows 8.1 SMB share"?
It did not work. I did check the wiki before posting.
What's your issue, exactly?
Only peculiarity I know of is that you have to use your usename as id, not the email address. Username is normally your first name, or whatever folder name is yours under "c:\Users"
(2015-10-15, 17:23)Koying Wrote: [ -> ]What's your issue, exactly?
Managed to set it up but I get connection timeout. Tried the same on my ipad, works fine.
Ideas?
