Full Version: HOW-TO compile mplayer.dll from SVN
Compiling Mplayer for XBMC
Prerequisites
  • MinGW
  • MSYS
  • TortoiseSVN
Getting Source
Using TortoiseSVN
If you have TortoiseSVN, you can skip the first two steps.
Building Mplayer
Build Environment Setup
To build mplayer you need to download and install msys.
  • Get MingW 4.1.0 from SourceForge
  • Run and Choose Full (It will download about 45mb in total)
  • Get MSYS from SourceForge
  • Install MinGW to C:\MinGW (The root is the best place)
  • Install MSYS
  • Complete the questions you get after the install in a command window
  • Get GCC Core 3.4.4 from SourceForge
  • Extract GCC-Core to a temporary folder, then copy bin,lib and libexec to the MinGW folder and overwrite
You should now have both the source and the building environment to compile a Mplayer.dll
Making the Mplayer.dll
This part of the how to assumes that you did install MinGW to C:\MinGW and download Mplayer to c:\mplayer-xbmc
  • Run MSYS.BAT (located in C:\Msys\Msys.bat)
  • Command Window should show type cd /c/mplayer-xbmc
  • Type ./configurexbmc --disable-libavformat (Use the --disable-libavformat to shrink the dll further. May cause compability issues with certain codecs, yet to be determined)
  • Wait till that finshes, with luck it should have no errors/problems
  • Type make
  • Type makedll
  • Type exit
This how to is also on the wiki/manual
