2015-10-16, 21:49
Hi there , i really try to send email to AngelsCry but its impossible find it . well i hope this can be read
Hi there , i wanna know if possible , the dev can make some changes in the Add-on
Because i wanna "Export" and/or "Import" for Example "Game for Emulator" for this Add-on
but this is hard , because all its in one file in "launchers.xml"
But if possible some dev can modify that and made the add-on for example reads in
"~/.kodi/userdata/addon_data/plugin.program.advanced.launcher/launchers" ( folder ) inside sub-folders of emulator(s)
Nes , Snes , Sms , Smd , Gbc , Gba , Ps1 , Ngc , Psp , etc . . .
Inside the folder 1 File , can be .xml but contain the things for
"Image" , "Thumbnail" , "nfo" , "Path" , etc . . .
The thing its , 1 File for each "Game" inside the Kodi Add-on , the user can edit the file for fix path in case are diferent .
and not put 1 Incremental Text File becasue for persons with minimun hardware for use Kodi and the Addon , when add , and add again and overagain , can be slow on some machines .
Well , i ask me , if someone understand my idea , for change that's things in the add-on .
Thank you for anyone read me.
