Full Version: KODI config 15.2 install
How do I carry out a KODI config update on the Prometheus HTPC
I believe 15.2 isengrad is the latest build
Thanks in advance for you help
love to know myself
IF you find any solutions guys would appreciate some help I deleted Kodi by mistake with playing about with my android pro box
If your device has the play store, you can download it and install from there. You might have to uninstall kodi that came with it
If not, go to kod.tv/download/ and download it there to sideload it onto the device
If that wont work, and its baked into the firmware, then you have to talk to whomeever made your box about updating them
Cheers!
