Full Version: Problem Kodi - DvbViewer Recorder
I try to connect DvbViewer Recording with Kodi to used TV Live.
My SO : Windows 7
Kodi : last versione Isengrad.
DvdViewer Pro : 5.5.2.0
DvdViewer Recording ; 1.31.0.0 (beta)
All program in same machine... localhost.
DvbViewer Pro --> Connection to Recording Service - Wizard Configuration :
Registration from DvbViewer work!
Step 2 - Configuration DvbRecording :
Web Service... work all. EPG don't work, it remain empty.
Step 3 - DvdViewer Client PRV in Kodi :
Tv Live Enabled :Image
DvbViewer PVR Add-On Enabled : Image
Configuration with DvbViewer Ok : Image
PVR start to download list of Channels from DVBViewer in Kodi :
Channel 0. (dvbviewer 366 channels in list!).
Can you help to me to used LiveTV Kodi in Windows?
SOLVED... Versione DvBRecording 1.31 is instable. Version 1.29 is ok!
