2015-10-20, 10:48
i have a question on the Kodi Settings running on Braswell, Ubuntu. not for 4K or new Codecs.
Hardware
Motherboard: ASRock N3700-ITX
RAM: 4GB
SSD for the OS
i have installed the Latest Stable Ubuntu 15.04.x 64bit. and done an Update.
Installed Stable Kodi Instructions found here http://kodi.wiki/view/HOW-TO:Install_Kodi_for_Linux
i assume that i need the Hardware acceleration "vaapi" and not "vdpau". please correct me if i am wrong.
verified with "vainfo" that everything is loaded and not returning an error.
i found here http://forum.kodi.tv/showthread.php?tid=231955 some settings.
i would like to know if this settings are the right settings for my Hardware. like i wrote i am not playing 4K content or new HEVEC Codecs.
2.) KODI settings
System->Settings->System->Video Settings:
Vertical Sync: Let Driver decide
System ->Video->Acceleration:
Enable HQ Scalers for scaling above: 20%
Allow hardware acceleration (VDPAU): off
Allow hardware acceleration (VAAPI): On
Use Mpeg-2 VAAPI: Yes
Use Mpeg-4 VAAPI: if you like
UseVC-1 VAAPI: on
Prefer VAAPI Render Method: on <- This version has the banding fixed, so enable that setting to save CPU cycles with 100% quality.
Adjust Refreshrate to match video: On
System -> Video -> Playback
Sync Playback to Display: On if you don't use passthrough and Off if passthrough enabled (* This makes no sense when you want to use passthrough, why? Read: http://forum.kodi.tv/showthread.php?tid=...d2107461). In current versions (Jarvis) passthrough is disabled by us if users wants to Sync Playback to Display to care for people that refuse to read.
Adjust display refresh rate to match video: On Start / Stop
While watching a SD(!) video, that is accelerated by VAAPI, e.g. mpeg-2 or h264, click the film role and choose: Deinterlace: Auto (Never set this to ON it will harm for everything that is not interlaced) Deinterlacing-Method: VAAPI-MCDI or VAAPI-MADI (Baytrail, Sandybridge), Scaling Method: Lanczos3 Optimized and choose save for all files. Remember to do this only in combination with the above "scaling above" for 20%. This Lanczos3 Optimized filter might be too heavy for BYTs, here you might - depending on the file - choose Bilinear.
Regards,
Jan.
Hardware
RAM: 4GB
SSD for the OS
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install kodi
2.) KODI settings
UseVC-1 VAAPI: on
Regards,
Jan.
