2015-10-20, 23:52
Hello all,
FYI: I am not an advanced user, as I am sure will become obvious..
I run KODI 15.2 on a Matricom G box Q, using Android 4.4.2
I just lost my settings for the first time and I really dont want to go through that again so I looked into backing up. I found the backup app and have tried everything I can think of (except going and buying an SD card, which I am not sure would work anyway). I always get the "Write Error Detected" message and then it tells me in the bottom right that "Not All Files Were Copied". When I select "Restore", there are no backups listed.
Is this a permissions issue? I tried creating a new folder but that option is grayed out (I looked and its the same thing in file manager too). If so, where do I change the setting?
UPDATE: I bought an SD card, it let me write a backup to it... So the problem isn't really solved but at least I wont have to deal with starting from scratch again.
