hi, does anybody know which ports are used / must be opened in my firewall? i'm sure it's a port issue because when i disable the firewall everything works fine. cheers!
Look into the m3u which you use for IPTV Simple Client.
If the URL begins with http:// then it is port 80.
rtmp:// usually uses Port 1935
Some URLs contain an explicit port number. This is separated with ":" from the URL or IP.
Maybe your firewall disabled/limited internet access for certain applications like kodi or ffmpeg.
thanks for the fast reply! i forgot to add one more kodi rule...
