2015-10-22, 19:46
hi Guys
Over the last 3 days, i ve been struggling to fix a VERY annoying issue I have with the sound
I have two issues :
the volume goes up and down for no reason
there s a permanent cracking noise
Consequences : I have to set the kodi volume to 100% to be able to hear (1) and there are still some parasites among the main stream.
What did I do ?
NOTHING ...this is the largest frustration !
it just happens all the sudden
What did I try to solve it ?
1- upgrade to 15.2 : no success
2- testing another sound system (amp and two speakers) : same problem
3- playing a file from the laptop with VLC : sound just works FINE as it should be !
4- playing various files from my 2 nas : same problem
5- changing the output from directsound to whatever can be in the list : same problem
6- reset to default : same problem
If you have a lead, please don t hesitate as I m out of ideas now
Thanks a mill in advance ,
DeepDish
My current settings :
HP Laptop with Windows 8.1
Kodi 15.2
Logitech 2.1 for sound via the headphone
Network 1Go speed with 2 NAS attached
I have two issues :
What did I do ?
DeepDish
Kodi 15.2
