2016-02-10, 04:26
Ok I believe I've answered most of my own questions after reading over things. Can anyone confirm that all the nonlocal content from USTV Now is in HD, and is not geo-blocked within the US or is that just an online rumor?
(2016-02-10, 04:26)shayde82 Wrote: [ -> ]Ok I believe I've answered most of my own questions after reading over things. Can anyone confirm that all the nonlocal content from USTV Now is in HD, and is not geo-blocked within the US or is that just an online rumor?It's been a while but IIFC some is near HD some is not. It is not geo-blocked.
(2016-02-10, 07:11)jctennis Wrote: [ -> ](2016-02-10, 06:39)Lunatixz Wrote: [ -> ]@nolos @jctennisShould I assume using the PlayOn browser is still broken or should this address that as well?
I disabled failed playback detection for the playon video source. This should stabilize the feed.
Either way, thanks boss. You're the best.
(2016-02-11, 06:23)476429 Wrote: [ -> ]I have a channel called TV that is a random mix of all the TV shows stored on my local hard drive. For some reason PTVL has associated the "BabyTV" logo with it. Is there any way I can get rid of the logo?
Thank you
Brett
(2016-02-05, 23:00)spyder Wrote: [ -> ]Was the max timeout duration for strm files shortened? I am trying to use strm files that have been added to my library from USTV VOD. The files play fine in Kodi, but they take a while to load, and fail in PTVL.Any info on this? Does anyone else use USTV-VOD strm files in PTVL? It seems like they do start, just as PTVL wants to timeout and cancel.
(2016-02-11, 15:45)azrael17 Wrote: [ -> ](2016-02-11, 06:23)476429 Wrote: [ -> ]I have a channel called TV that is a random mix of all the TV shows stored on my local hard drive. For some reason PTVL has associated the "BabyTV" logo with it. Is there any way I can get rid of the logo?Make sure there isn't a BabyTV logo in your logo folder called "TV".
(2016-02-11, 06:19)476429 Wrote: [ -> ]Channels are randomly disappearing while I'm watching them.
(2016-02-12, 05:05)476429 Wrote: [ -> ](2016-02-11, 06:19)476429 Wrote: [ -> ]Channels are randomly disappearing while I'm watching them.
It did it again just now. I was watching channel 2. The screen went black for second then switched to channel 1. I left it on channel 1 and after a couple of minutes the screen went black and changed to channel 7 (the last channel in my list). I opened the guide and channels 1 and 2 are gone--no longer in the guide.
I'm using the latest version of PTVL and Kodi 14.2. Is anyone else experiencing this problem? Is there anything I can do to fix it?
Thank you
Brett
