Full Version: PseudoTV Live - SetTop Box Experience v.0.8.x
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
watch gallery
What is PseudoTV Live?
  • PseudoTV Live acts similar to normal broadcast or cable TV, complete with multiple preset, user-defined channels and a EPG. PseudoTV Live, PTVL for short; can directly integrate with various Kodi sources such as Plugins, Library Media, Hdhomerun, UPNP and PVR backends. The project goal is to create a familiar, easy to use "Settop Box" experience while using all Kodi has to offer.
About:
Readme
wiki
Changelog
More Screenshots
PseudoTV Live is ONLY available through my repository, all third party installer are unsupported!
Please remember PTVL is designed to work with the latest "Stable Release" of Kodi. Beta's, nightlies and custom builds are untested and not natively supported.
Resources:
Follow @PseudoTV_Live for exclusive updates, tips and information...
Visit the PseudoTV Live Website for community forums, tips, faq and support threads.
Guides, Tutorials and Miscellaneous Documents:
The Dumbass Guide to PseudoTV Live!
Ultimate Guide to PseudoTV
  • * Courtesy of Milkman
Manual Settings2 Configuration Examples/Templates
Howto use XMLTV with PTVL
Spotlight:
Bests XBMC Addons
NoRights Podcast S3E25
NoRights Podcast: S4E7
Howtogeek
gadgtspot
cordkillers
Contribute:
  • Donations* for this addon gratefully accepted. Please Visit
PseudoTVLive.com for details.
Installation:
Lunatixz Repository
How to Install from zip file
Recommended plugins for autotuning & channel building:
Recommended for enhanced interface:
Key Features:
  • [✓] Emby, Plex, Serviio and UPNP Support.
    [✓] Online Channel configurations, Custom Skin's.
    [✓] Full Kodi integration including Context Menu and Artwork.
    [✓] Overlay Sidebar ("On Now") Skinnable quick menu.
    [✓] "Coming Up Next" Skinnable Overlay.
    [✓] Enhanced EPG icon flags (rec, new, sickbeard, couchpotato, HD, PG rating).
    [✓] Dynamic artwork for EPG and Overlay.
    [✓] Enhanced Guide Data: "Find Missing Art/Info" using TVDB, TMDB, Fanart.TV
    [✓] Donor Extras - BCT media, PseudoCinema Experience
    [✓] Skin Selector [Temporary Disabled]
    [½] Music Channels.
    [✓] Music Video Channels with Internet Streaming features.
    [✓] EZ channel configuration ("Autotuning").
    [✓] EZ in-app channel configuration
    [✓] Ability to add channels via Kodi favourites list.
    [✓] Hdhomerun Support (Dual/Prime/Extend).
    [✓] USTVnow w/ EPG data.
    [✓] Automatic Bumpers, Commercials, and Trailers w/ Online support ("BCT's").
    [✓] Youtube/RSS Channel types
    [✓] TVDB/TMDB/IMDB/Fanart.TV Integration w/ trakt support
    [½] Sonarr/ Sickbeard / Couchpotato Integration.
    [✓] Error handling (dead link) filter.
    [✓] EPG Color Categories
    [✓] Autostart Service *core created by Steveb1968
    [✓] Channel Manager Tool (Windows Only)
    [½] Companion Tool
    [ ] PVR (Recording Feature)
    [ ] Virtual Movie Poster (Showtime) Integration.
    [½] Kodi web interface w/EPG, Channel editor, Remote Control.
    [✓] Direct Plugin directory channel building (ie. Mylibrary method without the need to build strms).
    [✓] Direct Playon channel building (Requires Playon Software).
    [✓] Direct UPNP channel building.
    [✓] Direct Plugin channel building.
    [✓] Kodi PVR Backend channel building w/epg data
    [✓] Classic Coming Up Next dialog artwork.
    [½] Vevo Music Video Channel w/ EPG Information
    [✓] Settop Box mode, 24/7 Operation w/ self updating channels.
    [✓] Multiroom Video Mirroring.
    [✓] Multiroom Channel sharing.
    [½] EPG Guide data from Schedules Direct, TV Guide and Zap2it.
    ✓ = Added to master
    ½ = Added to master, but may not be functional.
Topic Rules:
  • I encourage everyone, novice to expert to share information and ideas on how to improve this plugin. You are free to contribute as you see fit... Share your skins, etc... But please respect a few rules.
    1. PLEASE READ POSTS BEFORE POSTING, I will update the post to keep information relevant.
    2. Do not post illegal internet feeds, or related plugins
banned from Kodi's forum
    3. Before posting, try using the search tool to find your answer. Please do not abuse private messaging, the proper way to ask for help is through the forum.
    4. Report all bugs with as much detail as possible, accompanied by a link to
your log
  • . Please do not post Incomplete or snippets of your log. If you have privacy concerns you can PM me your log.
    In Order to post logs, you need to enable both
Debugging in Kodi
  • and in PTVL (under Misc settings). Skin issues are not considered a bug, so no log is necessary. If you can include a link to a screenshot it would be appreciated.
    5. Follow
Kodi's code of conduct
Special Thanks to:
jason102, angrycamel, jtucker1972, ARYEZ, ,thedarkonaut, tman12, peppy6582, earlieb, Steveb1968, kurumushi, twinther, LordIndy, ronie, mcorcoran, sphere, giftie, spoyser, Eldorados, lambda, kinkin, bradvido88, Phil65, RagnaroktA, learningit, -bry
Supported Devices and Services*:
*The devices and services listed above serve to advise compatibility. Links are not here to solicit hardware or services, but merely to acknowledge that either custom code or personal attention has been made to ensure compatibility and function with the aforementioned links .PseudoTV Live works regardless of the above devices or services.
Migration info:
  • If you already have pseudotv installed:
    This version is independent from the original Pseudotv; this will help facilitate the transition between copies. Now you can experiment with this plugin and see if its for you, without any worry. Your userdata (ie cache,playlists,settings.xml,settings2.xml) are all compatible... but outdated. Copy this data over to userdata/script.pseudotv.live/ and be sure to check the settings before running.
    If you are new to pseudotv:
    Install, check settings, then run... pseudotv live will automatically build a few channels including some InternetTV channels; see “Autotune” above...
    All configurations should be either manual or through Pseudotv's channel manager...
Recommended Kodi Changes!
Disable Play Next Automatically under XBMC Video and Music Settings
Add "pvr://" and "upnp://" as a Kodi video source.
  • Edit your advancedsettings.xml, add the following:
        <network>
            <curlclienttimeout>15</curlclienttimeout>  <!-- Timeout in seconds for libcurl (http/ftp) connections -->
            <curllowspeedtime>5</curllowspeedtime>  <!-- Time in seconds for libcurl to consider a connection lowspeed -->
            <cachemembuffersize>0</cachemembuffersize>  <!-- number of bytes used for buffering streams ahead in memory
            XBMC will not buffer ahead more than this. WARNING: for the bytes set here, XBMC will consume 3x the amount of RAM -->
        </network>
If you are running Kodi on windows? Download this I/O Cache tool and set to "Multimedia".
ATTENTION: If you are running Kodi 15... it's recommended you individually add "pvr://" and "upnp://" as a video source in kodi.
New to PseudoTV?:
  • If you are new to PseudoTV, take the time to read through the forum... try to familiarize yourself with the terms, settings and basic concept of this plugin.
    Before running PseudoTV Live remember to setup and configure any plugins that require additional configurations(ie. USTVnow, etc).
Brief XMLTV Tutorial:
What is XMLTV? XMLTV is a very popular XML based file format for describing TV listings. see XMLTVFormat
How do I get an XMLTV File? there are several ways, I will list two possible ways:
Free: If you want to build a xmltv file for free with very basic info try MC2XML or ZAP2XML
Pay: If you want a more detailed TV listing try Schedules Direct
I suggest you build your XMLTV file with only a few channels, and no more then 3 days data (follow the guidelines listed in the grabbers you have chosen).
*If you build a XMLTV file over 2mb the plugin will take longer to load (smaller file = quicker load times; so chose wisely when building your xmltv file, you don't need info for channels you don't have nor do you need to list more then a week at a time!)
XMLTV must use default encoding format "UTF-8" do not enable "ISO-8859-1"
Please visit XMLTV for more info...
Example XMLTV configurations that work with PseudoTV Live
zap2xml.exe -u [email protected] -p PASSWORD -o xmltv.xml -i icons -U -I -T -D -A -d 3
mc2xml.exe -a -f -A -L -s -5 -d 72 -g ZIPCODE -U -D xmltv.dat -o xmltv.xml
Bumpers, Commercials and Trailers (BCT's):
If Auto is enabled for BCT's: PTVL will add one bumper and automatically fill commercials and trailers in order to stay under the "hide short clip" value.
(B)umpers:
Bumpers are short videos TV stations play between shows. If not auto, select your bumper folder and the amount of bumpers you would like between each show. Organize bumpers by channel name, e.g.
  • Code:
    C:\Bumpers\
              \CBS
              \NBC
(C )ommercials:
Commercials are any short video advertisement or promo. Options include:
  • Local folder, Select your folder and If not auto, select the amount of Commercials you would like between each show.
    Internet , Parses various website for commercials filtered by region and resolution. Configure: (Region, All), select preferred resolution.
    Available regions include.
    Youtube, Similar to a YouTube chtype. Channels, Playlists, and User Subscriptions are available. Configure: (Name,Type,Limit), example below.
    Channel:
    MotorTrend,1,50,0
    Playlist:
    PL9bsPVRSg1sl0kSa99jrim69esS0lQrkF,2,50,0
(T)railers:
  • Local folder, Select Trailers Folder, If not auto, select the amount of Trailers you would like between each show.
    XBMC Library, aka json parse your xbmc library for trailer urls. Option to match genre trailers to genre channel.
    Internet, Parses various website for trailers filtered by resolution.
    Channel: [code]MotorTrend,1,50,0
    | Playlist:
    [/code]
How to setup Multi Room Sharing:
Foundation:
Channel Sharing:
Channel Sharing, allows synchronization between multiple XBMC instances. Sharing works by copying a "master" setting2.xml to a "slave" instances while also syncing it's cache folder.
  • Master - Slave Setup:
    • Pick a Master XBMC Instance, this will be your main Kodi PTVL setup which already has a configured settings2.xml.
    • Network Share "master" userdata/script.pseudotv.live/ folder.
    • Go to your "slave" instance and enable channel sharing from within PTVL's settings. Point the share folder to the "master" "userdata/addon_data/script.pseudotv.live" folder.
    • BCT's are disabled during channel sharing.
    When the slave starts and stops it will sync itself to the "master". Your shows should be within a few minutes of each other.
    If you are using "LiveTV" Each instance of PTVL has to be configured to use the same xmltv file. Easiest way is to network share the folder you keep your xmltv file in, then configure each instance to use that folder.
    Multiroom Setup:
    • Make sure to run the client end at least once before configuring sharing.
    When each (master/client) instances starts they will sync between each other creating a "multiroom" experience.
Video Mirroring:
Unlike channel sharing "Video Mirroring" doesn't require PTVL to run on a client device. It only requires another system running XBMC (future plans include full UPNP support which will eliminate the need for a client to run XBMC).
The "master" instance of PTVL acts as video server, all media played will be forwarded to it's clients. No user control (ie. EPG/Overlay) is available on the client end. It's simply a mirror of the master instance.
Enable kodi's webserver, and enable control via upnp on both master and client systems. Config the clients IP, leaving the default port 9090 (not the same as Kodis webserver port) and enter UserTongueassword information, for up to three client devices...
Supported Tuners:
  • All Kodi LiveTV Backends through XBMC pvr:// protocol
  • HDhomerun - Dual (Strms), Prime/Extent (HTTP/UPNP)
  • USB Tuner -- VLC Stream
  • Ceton -- VLC Stream
Supported Plugins:
  • All Gotham and up plugins "should" work, but are not guaranteed with PseudoTV Live.
MISCELLANEOUS:
Add your own custom PseudoCinema videos!! go to CinemaVision
reserved
Boohoo?
Do you think it would be possible to add support for directv streams?
(2015-10-22, 22:47)GenerikS Wrote: [ -> ]Do you think it would be possible to add support for directv streams?
If a plugin was developed to use directv streams then yes... but that's highly unlikely for multiple reasons... USTVnow is a great alternative.... Also so are any tuners supported by Kodi PVR backends, and HDHomerun which does not require a backend.
(2015-10-22, 22:49)Lunatixz Wrote: [ -> ]
So, could I vpn to my home network to use HDHomerun abroad?
(2015-10-22, 23:15)GenerikS Wrote: [ -> ]
http://jonmaddox.com/wallop/
Lunatixz,
Since my xmltv file is not in English I never was able to get artwork for my live pvr channels.
Finally now I got artwork in all pvr windows with this command: Window(Home).Property(SkinHelper.PVR.Thumb) from the excellent "script.skin.helper.service"
All artwork is cached in a local folder.
I was wondering if there is a way to get these artork inside PLTV for my live channels through pvr backend.
(2015-10-23, 07:41)tromy Wrote: [ -> ]Lunatixz,
I already have code that pulls thumbs from the backend (it's been working great for me)... Rather then just steam roll past the problem. Can you post some logs over in the bugs thread, I'd like to fix it.
Create a channel configuration with only your livetv, and make sure debugging is enabled.... Navigate thru the EPG, then send me that log... Thanks
Should Youtube channels or Youtube playlist channels have a lot of repeated entries in the channel m3u files?
Apologies if this has been asked before but when a video is playing is there a button for previous channel?
(2015-10-24, 19:35)banananipple Wrote: [ -> ]Apologies if this has been asked before but when a video is playing is there a button for previous channel?
From the readme file:
Additional controls: Use the keymap plugin to link these action to a remote key.
Mute F8
Last Channel Recall ACTION_SHIFT
Favourite Channel Jump ACTION_SYMBOL
Subtitles ACTION_SHOW_SUBTITLES, ShowSubtitles
Next Subtitle NextSubtitle
Show Codec ACTION_SHOW_CODEC
Sleep Timer ACTION_ASPECT_RATIO
Record ACTION_RECORD -- To be used with future PVR features.
