(2015-10-24, 00:07)rascas Wrote: [ -> ]Yes, the addon was compiled with opengl instead of opengles2. I fixed it, it is already in the repo, you will be able to update it when the server is back online.
But I think this should be fixed upstream, not by me. See here:
https://github.com/kodi-pvr/pvr.vdr.vnsi...xt#L17-L35
OpenGL is always prefered over OpenGLES, it should have a system check to select the correct one in the compile time.
You you have an idea how to do this? On Linux X11 systems GL and GLES can be available, hence we choose GL. Are you saying that cross compilation for RPi results in a positive check for OpenGL?
Well I don't cross compile, I build things inside a Raspbian chroot under a Linux x86 machine. In my basic chroot I also have opengl libraries, hence it picks OpenGL instead.
I saw that the pvr.vdr.vnsi master branch already has a check for arm plataforms:
https://github.com/mk01/pvr.vdr.vnsi/com...a1b6b8d6f6
This should work for Jarvis and beyond.
Can I ask that?
I't possible to crosscompile full kodi+addons on a x86 machine targetting armhf? Compiling directly into rpi2 is very boring and long work.....
thanks
, another two question please.....
1) What about hw acceleration? like vnsi issue and GLES2 libraries? I must install default libgles2 on my system x86?
2) into you documentation:
$ make
$ sudo make install
but I can't do make install because the build process is made on a x86 machine and I need to create something like deb package.....
1) ok
, after about 2 hours, I'v latest kodi build
2) I'v found a script, mk-debian-{something}.sh.......but I'v read that don't work in cross.......however, can me address where to find correctly all file to deploy on my rpi2 please?
EDIT for point 2):
following exactly your guide at
https://github.com/xbmc/xbmc/blob/master...aspberrypi , I'v executed "make install" on my vmware x86_64 machine, and I'v noticed that seams to be copied into path:
/opt/xbmc-bcm/xbmc-dbg/arm-linux-gnueabihf
so I'v targizipped the following folders:
/opt/xbmc-bcm/xbmc-dbg/arm-linux-gnueabihf/bin/{xbmc*|kdi*}
/opt/xbmc-bcm/xbmc-dbg/arm-linux-gnueabihf/share/kodi
/opt/xbmc-bcm/xbmc-dbg/arm-linux-gnueabihf/lib/kodi
and copied on my rasp in that path "/opt/xbmc-bcm/xbmc-dbg/arm-linux-gnueabihf/...."
I'v missed something?
