(2015-10-25, 23:48)Dark_Slayer Wrote: [ -> ]I have it installed from the play store on mine. After clicking install from your browser did you try a reboot?
Tried that...no dice.
When did you install it? I think this started happening yesterday - not sure what time.
(2015-10-25, 23:51)clankfu Wrote: [ -> ]Tried that...no dice.
If all else fails, just install ES File Explorer, then use this method:
http://www.aftvnews.com/how-to-sideload-...e-fire-tv/
Once you add it to "Favorites" you can install and update Kodi using that method without having to re-enter the address. Also if you want the ability to install released versions or nightlies, use the address:
http://mirrors.kodi.tv/ instead.
(2015-10-25, 23:51)clankfu Wrote: [ -> ] (2015-10-25, 23:48)Dark_Slayer Wrote: [ -> ]I have it installed from the play store on mine. After clicking install from your browser did you try a reboot?
A while back, but it has self updated ever since. At 15.2 currently
Hopefully, it's just a hiccup and it'll be back in the Store eventually. Not a huge deal since I can still sideload it.
(2015-10-25, 02:31)clankfu Wrote: [ -> ] (2015-10-24, 18:56)Martijn Wrote: [ -> ]I updated some images so perhaps it takes a while for it to come back. Just relax or use the webbrowser to push it to your device
I'm experiencing something similar on my Nexus Player running Android 6.0.
Tried installing it via Chrome on my desktop and when I hit "install", the Nexus Player shows up in the drop-down. Clicked the Nexus Player and hit install but it just hung there.
I backed out and it shows as "Installed" but Kodi is nowhere to be found on my Nexus Player.
Yeah same thing here. i thought I was only one.
As of yesterday is back up on the Google play store for the nexus player.
