Full Version: Adding Submenu
I am currently using Kodi 14.2 on Raspberry Pi 2. I have sorted all my files into categories onto Emby and use Emby for Kodi add-on.
I would like to know if there is a way to add specific videos from the Emby to the Kodi submenu?
For Example,
I would like to put my English Series, Korean Series and Japanese Series under Tv shows in Kodi.
Thus, when i click Tv shows, the dropdown menu should be those three.
However, i am not sure on how to do this.
Can someone help me?
Thank you.
Use Super Favorites Add-on. You need to create super folder under Tv Shows.
More details you can find on
http://kodi.wiki/view/Add-on:Super_Favourites
Edit the Includes.xml file and add a submenu to open a smart playlist like below.
<item id="XX" description="Korean TV">
<visible>Container(300).HasFocus(21)</visible>
<label>Korean TV</label>
<onclick>ActivateWindow(Videos,special://userdata/playlists/video/Korean TV.xsp,return)</onclick>
</item>
The item id="XX" where the XX is the main menu name you want the sub menu to be placed under.
Like below.
