Full Version: PhotoApp (mac) comming soon
Pages: 1 2 3
Ok, I got it!
On one hand there was a bug in my code which caused the first error.
On the other hand it seems not to be possible to compare the timestamp of the smb database file and the timestamp of the local copy, which caused the second error (only if the copy already exists). To avoid more problems I removed the timestamp check for the moment, which will lead to some more network traffic and to some delay while you are navigating within the add-on. As soon I know the rest works fine, I will find an other soultion to avoid the unnecessary file reading overhead.
I hope it works now in your environment too.
Yeah, well done. Now it works.
I don’t know, what your plan or time line is, but I see a few bugs
- rotation infos are not read correctely or do not store
- always change sorting from ascending to descending
- view mode is not stored
Maybe you will extend the functionality and integrate faces, locations and so on?
Thank you very much.
While Photos.app and so the addon is able to play videos stored in the DB the addon don’t show thumbnails of these videos. Instead showing an icon of a generic folder.
I am glad it works :-)
Thank you for the bug list and the improvement ideas.
I am going to see that i can implement as much as possible in the next version.
I found a big problem. You know about write ahead logging? https://www.sqlite.org/wal.html
Photos.app can handle this and reads the content of Library.apdb-wal. Because your addon only copies the Library.apdb it lacks of the latest updates of the database. Is there any solution to handle also both files?
Thank you for reporting that bug. I will try to fix that in the next version.
Hi, is development of this plugin still active ? If i try to access Library over NFS share it does not work. (Kodi 15.2 on Ubuntu 14.04). I dont want to copy to local Harddrive becaus the library is too big. With Kodi iphoto plugin it worked in the past.
Yes, development is still active.
For NFS support you need to activate the 'make local copy of the photo-library' - option in the addon settings (it does not copy the whole library, but only the database).
NFS works in general. However there are some unsolverd issues with NFS (see post #20).
Hi i have a problem configuring the add-on with kodi 15.2 installed on my QNAP NAS, where is also stored my Photo Library.
When i try to access on photos the add-on return an error and ask me to check log file.
Any suggestion?
Sorry for the late answer. I somehow missed your question...
For NAS support please try with the "Make a local copy of the Photo-Library" option activated in the addon settings.
Tired to turn on the option, but still not help. No Pictures.
Can you send me the log file?
Now it "runs". but i only see one Picture ?!?Hope it help.
21:41:15 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
21:41:15 T:140701920364288  NOTICE: {'action': 'albums', 'folderUuid': 'TopLevelAlbums'}
21:41:15 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
21:41:15 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
21:41:15 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
21:41:15 T:140701920364288  NOTICE: photoapp.db: Retrieving list of folders
21:41:15 T:140701920364288  NOTICE: photoapp.db: GetFolderList: file is encrypted or is not a database
21:41:15 T:140701920364288  NOTICE: photoapp.gui: No folders to display
21:41:15 T:140701920364288  NOTICE: photoapp.db: Retrieving list of albums
21:41:15 T:140701920364288  NOTICE: photoapp.db: GetAlbumList: file is encrypted or is not a database
21:41:15 T:140701920364288  NOTICE: photoapp.gui: No albums to display
21:41:15 T:140701920364288  NOTICE: photoapp.gui: Keine Elemente
21:41:15 T:140703928563648   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums
21:41:15 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums) failed
21:41:15 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
21:41:15 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
21:41:18 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
21:41:18 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
21:41:18 T:140701920364288  NOTICE: {'action': 'slideshows', 'folderUuid': 'TopLevelSlideshows'}
21:41:18 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
21:41:18 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
21:41:18 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
21:41:18 T:140701920364288  NOTICE: photoapp.db: Retrieving list of albums
21:41:18 T:140701920364288  NOTICE: photoapp.db: GetAlbumList: file is encrypted or is not a database
21:41:18 T:140701920364288  NOTICE: photoapp.gui: No Slideshow to display
21:41:18 T:140701920364288  NOTICE: photoapp.gui: Keine Elemente
21:41:18 T:140703928563648   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=slideshows&folderUuid=TopLevelSlideshows
21:41:18 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=slideshows&folderUuid=TopLevelSlideshows) failed
21:41:18 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
21:42:52 T:140703928563648  NOTICE: NFS is idle. Closing the remaining connections.
22:23:57 T:140701928756992  NOTICE: Thread JobWorker start, auto delete: true
22:23:59 T:140701920364288  NOTICE: Previous line repeats 1 times.
22:23:59 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:23:59 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:23:59 T:140701920364288  NOTICE: {'action': 'moments'}
22:23:59 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:23:59 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:23:59 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:23:59 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:23:59 T:140701920364288  NOTICE: photoapp.db: GetMomentList: file is encrypted or is not a database
22:23:59 T:140701920364288  NOTICE: photoapp.gui: No moments to display
22:23:59 T:140701920364288  NOTICE: photoapp.gui: Keine Elemente
22:24:00 T:140703928563648   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=moments
22:24:00 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=moments) failed
22:24:00 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:00 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:00 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:00 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:00 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:00 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:02 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:02 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:03 T:140701920364288  NOTICE: {'action': 'albums', 'folderUuid': 'TopLevelAlbums'}
22:24:03 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:03 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:03 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:03 T:140701920364288  NOTICE: photoapp.db: Retrieving list of folders
22:24:03 T:140701920364288  NOTICE: photoapp.db: GetFolderList: file is encrypted or is not a database
22:24:03 T:140701920364288  NOTICE: photoapp.gui: No folders to display
22:24:03 T:140701920364288  NOTICE: photoapp.db: Retrieving list of albums
22:24:03 T:140701920364288  NOTICE: photoapp.db: GetAlbumList: file is encrypted or is not a database
22:24:03 T:140701920364288  NOTICE: photoapp.gui: No albums to display
22:24:03 T:140701920364288  NOTICE: photoapp.gui: Keine Elemente
22:24:03 T:140703928563648   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums
22:24:03 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums) failed
22:24:03 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:03 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:03 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:07 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:07 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:07 T:140701920364288  NOTICE: {'action': 'slideshows', 'folderUuid': 'TopLevelSlideshows'}
22:24:07 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:07 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:07 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:07 T:140701920364288  NOTICE: photoapp.db: Retrieving list of albums
22:24:07 T:140701920364288  NOTICE: photoapp.db: GetAlbumList: file is encrypted or is not a database
22:24:07 T:140701920364288  NOTICE: photoapp.gui: No Slideshow to display
22:24:07 T:140701920364288  NOTICE: photoapp.gui: Keine Elemente
22:24:07 T:140703928563648   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=slideshows&folderUuid=TopLevelSlideshows
22:24:07 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=slideshows&folderUuid=TopLevelSlideshows) failed
22:24:08 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:08 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:08 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:08 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:08 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:10 T:140703016748800   ERROR: Unable to find plugin
22:24:10 T:140703928563648   ERROR: GetDirectory - Error getting plugin://
22:24:10 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://) failed
22:24:10 T:140701920364288  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:15 T:140701920364288  NOTICE: Previous line repeats 2 times.
22:24:15 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:15 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:15 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:15 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:15 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:15 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:34 T:140701920364288  NOTICE: Previous line repeats 1 times.
22:24:34 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:34 T:140703928563648   ERROR: Control 51 in window 10002 has been asked to focus, but it can't
22:24:34 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:35 T:140703928563648   ERROR: Control 51 in window 10002 has been asked to focus, but it can't
22:24:35 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:35 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:41 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:41 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:44 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:44 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:44 T:140701920364288  NOTICE: {'action': 'moments'}
22:24:44 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:44 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:44 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:44 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:24:44 T:140701920364288  NOTICE: photoapp.gui: moment: 2012
22:24:44 T:140701920364288  NOTICE: photoapp.gui: moment: 2015
22:24:44 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:47 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:47 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:47 T:140701920364288  NOTICE: {'action': 'moments', 'year': '2012'}
22:24:47 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:47 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:47 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:47 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:24:47 T:140701920364288  NOTICE: photoapp.gui: moment: 07
22:24:47 T:140702029960960  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:50 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:50 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:50 T:140701920364288  NOTICE: {'action': 'moments'}
22:24:50 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:50 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:50 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:50 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:24:50 T:140701920364288  NOTICE: photoapp.gui: moment: 2012
22:24:50 T:140701920364288  NOTICE: photoapp.gui: moment: 2015
22:24:50 T:140702693689088  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:53 T:140701920364288  NOTICE: Previous line repeats 1 times.
22:24:53 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:53 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:53 T:140701920364288  NOTICE: {'action': 'albums', 'folderUuid': 'TopLevelAlbums'}
22:24:53 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:53 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:53 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:53 T:140701920364288  NOTICE: photoapp.db: Retrieving list of folders
22:24:53 T:140701920364288  NOTICE: photoapp.gui: No folders to display
22:24:53 T:140701920364288  NOTICE: photoapp.db: Retrieving list of albums
22:24:53 T:140701920364288  NOTICE: photoapp.gui: No albums to display
22:24:53 T:140701920364288  NOTICE: photoapp.gui: Keine Elemente
22:24:53 T:140703928563648   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums
22:24:53 T:140703928563648   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums) failed
22:24:54 T:140701920364288  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:56 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:56 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:57 T:140701920364288  NOTICE: {'action': 'moments'}
22:24:57 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:57 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:57 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:57 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:24:57 T:140701920364288  NOTICE: photoapp.gui: moment: 2012
22:24:57 T:140701920364288  NOTICE: photoapp.gui: moment: 2015
22:24:57 T:140702721767168  NOTICE: Thread BackgroundLoader start, auto delete: false
22:24:58 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:24:58 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:24:58 T:140701920364288  NOTICE: {'action': 'moments', 'year': '2015'}
22:24:58 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:24:58 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:58 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:24:58 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:24:58 T:140701920364288  NOTICE: photoapp.gui: moment: 10
22:24:58 T:140701920364288  NOTICE: photoapp.gui: moment: 11
22:24:58 T:140701920364288  NOTICE: photoapp.gui: moment: 12
22:24:58 T:140702721767168  NOTICE: Thread BackgroundLoader start, auto delete: false
22:25:01 T:140701920364288  NOTICE: Thread LanguageInvoker start, auto delete: false
22:25:01 T:140701920364288  NOTICE: -->Python Interpreter Initialized<--
22:25:01 T:140701920364288  NOTICE: {'action': 'moments', 'year': '2015', 'month': '12'}
22:25:01 T:140701920364288  NOTICE: photoapp.gui: Copy Photo Library Database...
22:25:01 T:140701920364288  NOTICE: photoapp.gui: from nfs://192.168.178.8/USBDisk1/Fotos/aktuell/Fotos-Mediathek-2016.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:25:01 T:140701920364288  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
22:25:01 T:140701920364288  NOTICE: photoapp.db: Retrieving list of moments
22:25:01 T:140701920364288  NOTICE: photoapp.gui: moment: 01
Until now no success ... No pictures are Displayed.
07:53:34 T:140523626829568  NOTICE: photoapp.gui: Photo App DB not found: /var/lib/vdr/Pictures/Fotos Library.photoslibrary/Database/Library.apdb
07:53:34 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:53:39 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:53:39 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:53:39 T:140523626829568  NOTICE: {'action': 'albums', 'folderUuid': 'TopLevelAlbums'}
07:53:39 T:140523626829568  NOTICE: photoapp.gui: Photo App DB not found: /var/lib/vdr/Pictures/Fotos Library.photoslibrary/Database/Library.apdb
07:53:39 T:140523626829568   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'NoneType' object has no attribute 'GetFolderList'
                                              File "/var/lib/vdr/.kodi/addons/plugin.image.photoapp/addon.py", line 299, in <module>
                                                items = photoApp.list_albums(folderUuid[0])
                                              File "/var/lib/vdr/.kodi/addons/plugin.image.photoapp/addon.py", line 145, in list_albums
                                                folders = self.db.GetFolderList(folderUuid)
                                            AttributeError: 'NoneType' object has no attribute 'GetFolderList'
07:53:39 T:140525626902464   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums
07:53:39 T:140525626902464   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums) failed
07:53:39 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:53:42 T:140523626829568  NOTICE: Previous line repeats 2 times.
07:53:42 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:53:42 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:53:42 T:140523626829568  NOTICE: photoapp.gui: Photo App DB not found: /var/lib/vdr/Pictures/Fotos Library.photoslibrary/Database/Library.apdb
07:53:42 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:54:00 T:140523729835776  NOTICE: Previous line repeats 1 times.
07:54:00 T:140523729835776   ERROR: Unable to lookup host: ''
07:54:59 T:140523626829568   ERROR: Previous line repeats 2 times.
07:54:59 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:54:59 T:140525626902464   ERROR: Control 512 in window 10002 has been asked to focus, but it can't
07:54:59 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:54:59 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:54:59 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:00 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:00 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:08 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:08 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:08 T:140523626829568  NOTICE: {'action': 'albums', 'folderUuid': 'TopLevelAlbums'}
07:55:08 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:08 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:08 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:08 T:140523626829568  NOTICE: photoapp.db: Retrieving list of folders
07:55:08 T:140523626829568  NOTICE: photoapp.gui: No folders to display
07:55:08 T:140523626829568  NOTICE: photoapp.db: Retrieving list of albums
07:55:08 T:140523626829568  NOTICE: photoapp.gui: No albums to display
07:55:08 T:140523626829568  NOTICE: photoapp.gui: Keine Elemente
07:55:08 T:140525626902464   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums
07:55:08 T:140525626902464   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=albums&folderUuid=TopLevelAlbums) failed
07:55:08 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:14 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:14 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:14 T:140523626829568  NOTICE: {'action': 'moments'}
07:55:14 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:14 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:14 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:14 T:140523626829568  NOTICE: photoapp.db: Retrieving list of moments
07:55:14 T:140523626829568  NOTICE: photoapp.gui: moment: 2012
07:55:14 T:140523626829568  NOTICE: photoapp.gui: moment: 2014
07:55:14 T:140523626829568  NOTICE: photoapp.gui: moment: 2015
07:55:14 T:140523626829568  NOTICE: photoapp.gui: moment: 2016
07:55:14 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:15 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:16 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:16 T:140523626829568  NOTICE: {'action': 'moments', 'year': '2016'}
07:55:16 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:16 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:16 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:16 T:140523626829568  NOTICE: photoapp.db: Retrieving list of moments
07:55:16 T:140523626829568  NOTICE: photoapp.gui: moment: 01
07:55:16 T:140523626829568  NOTICE: photoapp.gui: moment: 02
07:55:16 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:17 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:17 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:17 T:140523626829568  NOTICE: {'action': 'moments', 'year': '2016', 'month': '02'}
07:55:17 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:17 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:18 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:18 T:140523626829568  NOTICE: photoapp.db: Retrieving list of moments
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 01
07:55:18 T:140523626829568  NOTICE: Previous line repeats 1 times.
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 02
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 03
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 04
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 05
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 06
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 07
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 08
07:55:18 T:140523626829568  NOTICE: photoapp.gui: moment: 09
07:55:18 T:140524643325696  NOTICE: Previous line repeats 1 times.
07:55:18 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:20 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:20 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:20 T:140523626829568  NOTICE: {'action': 'moments', 'uuid': 'mPaywxhiTJildeE6051bpw', 'year': '2016', 'day': '01', 'month': '02'}
07:55:20 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:20 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:20 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:20 T:140523626829568  NOTICE: photoapp.db: Retrieving list of pictures
07:55:20 T:140523626829568  NOTICE: photoapp.gui: No pictures to display
07:55:20 T:140523626829568  NOTICE: photoapp.gui: Keine Elemente
07:55:20 T:140525626902464   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=moments&day=01&month=02&uuid=mPaywxhiTJildeE6051bpw&year=2016
07:55:20 T:140525626902464   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=moments&day=01&month=02&uuid=mPaywxhiTJildeE6051bpw&year=2016) failed
07:55:21 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:21 T:140523626829568  NOTICE: {'action': 'moments', 'year': '2016', 'month': '02'}
07:55:21 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:21 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:21 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:21 T:140523626829568  NOTICE: photoapp.db: Retrieving list of moments
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 01
07:55:21 T:140523626829568  NOTICE: Previous line repeats 1 times.
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 02
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 03
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 04
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 05
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 06
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 07
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 08
07:55:21 T:140523626829568  NOTICE: photoapp.gui: moment: 09
07:55:21 T:140524643325696  NOTICE: Previous line repeats 1 times.
07:55:21 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:23 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:23 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:23 T:140523626829568  NOTICE: {'action': 'moments', 'uuid': 'dCbj0YIcQ%25W6Tc3fui2rVg', 'year': '2016', 'day': '02', 'month': '02'}
07:55:23 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:23 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:23 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:23 T:140523626829568  NOTICE: photoapp.db: Retrieving list of pictures
07:55:23 T:140523626829568  NOTICE: photoapp.gui: No pictures to display
07:55:23 T:140523626829568  NOTICE: photoapp.gui: Keine Elemente
07:55:23 T:140525626902464   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=moments&day=02&month=02&uuid=dCbj0YIcQ%25W6Tc3fui2rVg&year=2016
07:55:23 T:140525626902464   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=moments&day=02&month=02&uuid=dCbj0YIcQ%25W6Tc3fui2rVg&year=2016) failed
07:55:23 T:140523626829568  NOTICE: {'action': 'moments', 'year': '2016', 'month': '02'}
07:55:23 T:140523626829568  NOTICE: photoapp.db: Retrieving list of moments
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 01
07:55:23 T:140523626829568  NOTICE: Previous line repeats 1 times.
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 02
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 03
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 04
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 05
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 06
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 07
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 08
07:55:23 T:140523626829568  NOTICE: photoapp.gui: moment: 09
07:55:23 T:140524643325696  NOTICE: Previous line repeats 1 times.
07:55:23 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:28 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:28 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:28 T:140523626829568  NOTICE: {'action': 'moments', 'uuid': 'TpH%25jWutRLKFJfsYqFqZPQ', 'year': '2016', 'day': '04', 'month': '02'}
07:55:28 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:28 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:28 T:140523626829568  NOTICE: photoapp.db: Opening database: /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
07:55:28 T:140523626829568  NOTICE: photoapp.db: Retrieving list of pictures
07:55:28 T:140523626829568  NOTICE: photoapp.gui: No pictures to display
07:55:28 T:140523626829568  NOTICE: photoapp.gui: Keine Elemente
07:55:28 T:140525626902464   ERROR: GetDirectory - Error getting plugin://plugin.image.photoapp/?action=moments&day=04&month=02&uuid=TpH%25jWutRLKFJfsYqFqZPQ&year=2016
07:55:28 T:140525626902464   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.image.photoapp/?action=moments&day=04&month=02&uuid=TpH%25jWutRLKFJfsYqFqZPQ&year=2016) failed
07:55:28 T:140523626829568  NOTICE: {'action': 'moments', 'year': '2016', 'month': '02'}
07:55:28 T:140523626829568  NOTICE: photoapp.db: Retrieving list of moments
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 01
07:55:28 T:140523626829568  NOTICE: Previous line repeats 1 times.
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 02
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 03
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 04
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 05
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 06
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 07
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 08
07:55:28 T:140523626829568  NOTICE: photoapp.gui: moment: 09
07:55:28 T:140524643325696  NOTICE: Previous line repeats 1 times.
07:55:28 T:140524643325696  NOTICE: Thread BackgroundLoader start, auto delete: false
07:55:30 T:140523626829568  NOTICE: Thread LanguageInvoker start, auto delete: false
07:55:30 T:140523626829568  NOTICE: -->Python Interpreter Initialized<--
07:55:31 T:140523626829568  NOTICE: {'action': 'moments', 'uuid': 'ipsG0SyWQzGWZ8rJnG9OHQ', 'year': '2016', 'day': '09', 'month': '02'}
07:55:31 T:140523626829568  NOTICE: photoapp.gui: Copy Photo Library Database...
07:55:31 T:140523626829568  NOTICE: photoapp.gui: from nfs://192.168.178.8/VD-Fotos-2016-2017/NAS-Fotos-2016-2017.photoslibrary/Database/Library.apdb to /var/lib/vdr/.kodi/userdata/addon_data/plugin.image.photoapp/Library.apdb
Hi
on my system (openelec 6.0.1/raspberry pi/macbook pro) it isn't working. I have activate filesharing on the macbook and in Kodi I see the photo-library files (SMB) but if i want to run the addon I get an error message
Pages: 1 2 3
