2015-10-29, 19:39
I was recenly using UPNP just fine running Kodi from laptop and streaming via the UPNP to my Samsung Smart TV. It was working like a charm with all compatible addons.
About a week ago it just stopped working. I can still see my Smart tv in the "Play Using" section when i right click the file i wish to play.
I have enabled all the UPNP settings within Kodi. I have double checked the option to support alternative player within youtube settings. As i said i have had this working with other addons and none of them are working but i have used YOUTUBE addon to demonstrate my bug/error on the log file below.
I have tried the following.
1. Virgin media super hub settings, (ensured upnp was enabled)
2. Tried another router of the same kind which i had as a spare (rang virgin got it connected and no joy)
3. Tried both wireless and through ethernet.
4. Reset router
5. Factory reset on Samsung smart 3d tv.
6. Made sure the kodi youtube settings box was ticked so as to use other devices.
7. Reinstalled windows.
8. Upgraded windows to windows 8 then windows 10.
9. Rang samsung to check all was ok settings wise.
10. Same with virgin.
11. Tried a different device with kodi installed.
12. Made sure kodi upnp settings were all correct.
I cannot think of anythingelse i can do, I have even tried previous version of Kodi as it was working with v15.1. I just don't understand why all of a sudden it no longer works.
In youtube (kodi) i right click and it even picks up my tv and i click it but it just wont transfer it.
Can anyone help me. Been trying this for over a week now. I would really appreciate any help.
http://xbmclogs.com/pkdstqhrv
The only errors/warnings I can find are pasted below. Unless I am missing something?
17:21:09 T:3260 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
17:21:09 T:3260 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
17:21:10 T:3260 WARNING: JSONRPC: Could not parse type "PVR.Details.Channel"
17:21:10 T:3260 WARNING: JSONRPC: Could not parse type "PVR.Details.ChannelGroup.Extended"
17:21:10 T:3260 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
17:21:10 T:3260 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
17:22:35 T:3260 ERROR: CUPnPPlayer:layFile(https://r3---sn-8pgbpohxqp5-ac5l.googlev...ps=2098750) failed to find a matching resource
17:22:35 T:3260 ERROR: UPNP: CUPnPPlayer::OpenFile - unable to open file https://r3---sn-8pgbpohxqp5-ac5l.googlev...ps=2098750
4. Reset router
