2015-10-30, 23:10
I'm running OE with MCE IR receiver and HP MCE remote. Basically everything works fine ootb, but now I would like to change some buttons and add a script to a button on a remote. And actually there is one button that I can see when ssh into OE and running irw, but can't get that button working. I tried KeymapEditor too, it is great, but can't map a button as it only performs a function (playpause) and I can't change it. OK, many things, let's see the first:
irw output:
I want to map this button to run a script. At the moment, this button is not recognized in KeymapEditor addon, if I press it, nothing happens.
I guess I need to create a lircmap.xml file, but not sure about the correct path and content. Once I have lirc.xml, what next? Do I need keyboard.xml or remote.xml file?
The path I used: smb://openelec/userdata on openelec/keymaps
lirc.xml conent:
keyboard.xml content:
This is not working for some reason. Any ideas what I'm doing wrong?
The next thing is, there is a button on my HP MCE remote that is for some reason doing play/pause. The irw output is:
Obviously, I have play and pause buttons on the remote and they are working fine. I'm not able to change the mapping of this button. In KeymapEditor if I try to remap this button, I just get the pause/resume function performed, no mapping is done.
irw output:
OpenELEC:~ # irw
e0 0 KEY_BRIGHTNESSDOWN devinput
e0 0 KEY_BRIGHTNESSDOWN_UP devinput
lirc.xml conent:
<lircmap>
<remote device="devinput">
<script1>KEY_BRIGHTNESSDOWN</script1>
</remote>
</lircmap>
<keymap>
<global>
<keyboard>
<script1>RunScript(script.audio.profiles,0)</script1>
</keyboard>
</global>
</keymap>
a4 0 KEY_PLAYPAUSE devinput
a4 0 KEY_PLAYPAUSE_UP devinput
