Hello!
I want to use an additional external M3U list in "IPTV Simple Client".
Now I've read that one should just install "IPTV Simple Client" a 2nd time.
This looks very simple in Youtube video instructions, but I just can't find a matching download of "IPTV Simple Client 2" for Kodi 15.1 (Raspberry Pi 2 with OpenELEC 5.95.5)
I'm grateful for any help!
Thanks & best regards!
You are searching for something that you already has. Just duplicate the iptv addon and change id in addon.xml like f.e.
<?xml version="1.0" encoding="UTF-8"?>
<addon
id="pvr.iptvsimple2"
version="1.12.3"
name="PVR IPTV Simple Client 2"
This should be enough.
So easy?
And it works... thank you!!!
I have openelec 6.0 with kodi 15.2, and this methode not work. before with kodi 15.1 I was doing so well and everything worked.
can you help me?
(2015-10-31, 20:37)illiac4 Wrote: [ -> ] You are searching for something that you already has. Just duplicate the iptv addon and change id in addon.xml like f.e.
<addon
version="1.12.3"
i did this.
but now i have a problem:
Kodi load the first list from Simple Client 1
then Kodi load the second list from Simple Client 2
now when i go to Live TV kodi shows the channels from the simple client 2 only
the channels from the first Simple Client are missing
update: i read somewhere that the second list must be local path, i did that but still its not working
Hi. I accidentally uninstalled pvr iptv simple client and cannot find a link that works. I need to download and reinstall. Please help
