I'm trying to make the same effect the new apple tv animates it's icon for my new skin. It does a sort of wiggle and wondering if some could help me out?
Video link?
EDIT: Found it.
Looks complicated for Kodi to pull off.
Yeah i'm thinking it might not be possible
you can use zoom with 2 coords to stretch/wiggle etc.
<effect type="zoom" end="150,75" start="100,200" time="200" center="auto" tween="quadratic" easing="in" />
xy, so will stretch or w/e
but the wiggling layers is some depth perception shizzle, if that is included in the os or just advert?
im seeing maybe overlay the logo and the clearart on poster to create a composite then wiggle all 3 in different axis
3d plugin on that, no chance unless ripped to python :/
Are you talking about the apple parallax images?
I have had some success with 3d animations.
So maybe some gif images layered in a group
A video or gif animation of what you mean will help others understand and me as I don't own a single apple product.
that might be a good idea i'll give the gif idea a go
"rotatey" shuld do the trick for you!
maby you have to mix the animation with "rotatex" to get a slightly similar animation.
all you have to think about is how to trigger the animation to get the same feel. (with mouse you could use hidden buttons on each side, but how to do it when a remote or Keybord is used? No Idea.
