(2015-12-21, 20:38)DanTheMan827 Wrote: [ -> ] (2015-12-21, 12:04)Vinnie22 Wrote: [ -> ] (2015-12-21, 01:23)DanTheMan827 Wrote: [ -> ]What version of OS X are you running?
And could you post the log from the program? You can find it in the View menu
Hello Dan , Im using El Capitan latest version .
The log is below :
(Snip...)
Really Really Appreciate your help >
Thank you
This isn't a log, it's skeleton code for a new blank swift app
I'm interested in the log of the app signer
Sorry Dan
Here is the log from App Signer
2015-12-21 20:22:00 Found 6 Provisioning Profiles
2015-12-21 20:22:00 Added profile com.Family.AppleKodi, expires (11/03/2016)
2015-12-21 20:22:00 Added profile com.Family.ECKODI, expires (11/03/2016)
2015-12-21 20:22:00 Added profile com.Family.KODI2, expires (11/03/2016)
2015-12-21 20:22:00 Added profile com.Family.Kodi, expires (11/03/2016)
2015-12-21 20:22:00 Added profile com.Family1.Kodi2, expires (20/03/2016)
2015-12-21 20:22:00 Added profile com.FamilyMangat.KodiMangat, expires (19/03/2016)
2015-12-21 20:22:01 Found 2 Codesigning Certificates
2015-12-21 20:22:01 Added signing certificate "iPhone Developer:
[email protected] (W5A9K4A79H)"
[email protected] (U498FE6MF7)"
2015-12-21 20:22:01 Loaded Codesigning Certificate from Defaults: iPhone Developer:
2015-12-21 20:22:01 Ready
2015-12-21 20:22:07 Set Codesigning Certificate Default to: 1
2015-12-21 20:22:10 Selected provisioning profile com.Family1.Kodi2
2015-12-21 20:22:12 Temp folder: /var/folders/x3/zl6dr7ts6kxg0z60xc6b36kh0000gp/T/com.DanTheMan827.AppSigner.hZYVRRco
2015-12-21 20:22:12 Working directory: /var/folders/x3/zl6dr7ts6kxg0z60xc6b36kh0000gp/T/com.DanTheMan827.AppSigner.hZYVRRco/out
2015-12-21 20:22:12 Payload directory: /var/folders/x3/zl6dr7ts6kxg0z60xc6b36kh0000gp/T/com.DanTheMan827.AppSigner.hZYVRRco/out/Payload
2015-12-21 20:22:12 Extracting deb file
2015-12-21 20:22:12 xcrun: error: active developer path ("/Volumes/Xcode 2/Xcode.app/Contents/Developer") does not exist, use `xcode-select --switch path/to/Xcode.app` to specify the Xcode that you wish to use for command line developer tools (or see `man xcode-select`)
2015-12-21 20:22:12 Error processing deb file
