Full Version: iOS App Signer - Install Kodi without Jailbreak (iOS and tvOS)
(2016-01-04, 17:21)Hotlinx Wrote: [ -> ]
(2016-01-04, 17:18)Nandor690 Wrote: [ -> ]
(2016-01-04, 17:17)Hotlinx Wrote: [ -> ]The problem is it just keeps saying I need to create a " provisioning profile" and this is not letting me
Ok, do you have the side menu open where it says Project and then under that it says targets?
Yes
And only Kodi is highlighted under target. Not koditests or kodiuitests?
Have you tried just changing the provisioning profile to something else? like, com.HotlinxKodi
(2016-01-04, 09:11)Hotlinx Wrote: [ -> ]I cannot get this to work, I downloaded Xcode, and again and again, it won't let me get passed the "fix" part. I tried to delete my ID, and re add it, and it's still not giving me permission. I even added a new iCloud account, and says summ about the strings. I'm so freaking pissed at this point .
another thing to make sure. When you are in the General tab where you put the bundle identifier and your apple account, make sure the side bar is visible and you are highlighted on Kodi and NOT koditests or kodiuiTest. or the "fix" error will not get fixed
I have l, still says no provision profile
When trying to install IPA, it gives me error,
App installation failed
A valid provisioning profile for this executable wasn't not found
(2016-01-04, 17:32)Hotlinx Wrote: [ -> ]After I hit fix button it says:
No Device registered
Creating a provisioning profile requires one or more devices to be registered with your team connect a device to your Mac to add it to a team
I just tried this with my iPhone 6s Plus. Sorry I thought you were doing this for apple tv. And Nfidel is exactly right. What version of iOS are you on?
If you go to the scheme in Xcode and just highlight your iPhone (not click on it), (and by the way if you look you will probably see 'unavailable device' and your iPhone name right under that) a warning will come up saying something like, your iPhone iOS 9.0.2 does not match kodi.app deployment target iOS 9.1
OSX EL capitan
(2016-01-04, 17:51)Hotlinx Wrote: [ -> ]OSX EL capitan
No. What version of iOS is your iPhone on?
(2016-01-04, 17:15)Nfidel Wrote: [ -> ]
(2016-01-04, 16:50)Hotlinx Wrote: [ -> ]After I hit the fIx button, I get the "NO DEVICE REGISTERED, creating a provisioning profile requires one or more device to be registered with your team . Connect a device to your Mac to add it to your team .
I have done this numerous Time, deleted all certain in key chain, and retried. Still no luck with this fox button? Any help? Smile I'm so lost
Did you verify that your connected device was running EXACTLY the same version of iOS you are specifying in Xcode. If it is not, then your device can't be registered.
Your description is exactly the same problem I had last week.
You are exactly right. I thought he was trying to install on Apple TV 4. Im trying to explain this to him now. Thanks for mentioning this
Sorry, this is for IOS phone.
Should I just update to 9.2?
(2016-01-04, 17:56)Hotlinx Wrote: [ -> ]Sorry, this is for IOS phone.
i know. What version of iOS does your iPhone have installed?
(2016-01-04, 17:57)Nandor690 Wrote: [ -> ]
Version 9.1
(2016-01-04, 17:58)Hotlinx Wrote: [ -> ]
Version 9.1
and you downloaded the stable version from here: http://mirrors.kodi.tv/apt/ios/deb/
Changing led the version to 9.1 under bundle identifier Instead of 1.0
(2016-01-04, 18:02)Hotlinx Wrote: [ -> ]Changing led the version to 9.1 under bundle identifier Instead of 1.0
Under Project click on kodi and under Deployment Target make sure it is on iOS Deployment Target [9.1]
