Full Version: iOS App Signer - Install Kodi without Jailbreak (iOS and tvOS)
EDIT: All good with the new bash script Smile
Thanks DanTheMan827, saves me having to compile all over again, great time saver.
I'm using OSX El Capitan, Xcode 7.1 and an iPad3 - iOS 9.1
This is what users should see if all goes well:
PHP Code:
Codesigning ./Kodi.app with entitlements
./Kodi.appreplacing existing signature
Packaging
Doing some housekeeping...
Donethe package is located at /Users/WRXTASY/Desktop/com.wrxtasy.Kodi-15-2-signed.ipa
EDIT2: If people get an "Untrusted Developer" popup on their iOS device please follow this link to fix:
https://support.apple.com/en-au/HT204460
MODS - please sticky this thread !
Thank you so much for this, all working perfectly now. I appreciate all your help on this and the work you put in to save us time
Don't suppose there is a simpler guide to getting this on my iPad is there?
Or should I not bother if the instructions on the 1st page are as simple as it's going to get? lol
(2015-11-03, 16:27)B.Moxham Wrote: [ -> ]Don't suppose there is a simpler guide to getting this on my iPad is there?
The terminal is never as simple as it can get, that's what GUIs are for.
I'll see if I can put together one to automate even more of the process.
Thanks Dan - followed your script and managed to install the ipa to my iPad Air on iOS9.02 on Xcode 7.1, but crashes when run. I have allowed my profile to be trusted etc.
script output:
/var/folders/tm/_5_kq7lj52n085llyn40rbmc0000gn/T/tmp.jTYODpiV/out/Payload/Kodi.app: replacing existing signature
/var/folders/tm/_5_kq7lj52n085llyn40rbmc0000gn/T/tmp.jTYODpiV/out/Payload/Kodi.app: signed bundle with Mach-O thin (armv7) [org.sur.myKodi]
rm: /Users/nsXXXX/org.sur.myKodi-signed.ipa: No such file or directory
/Users/nsXXXX
But I do have the ipa file in my home folder. Any idea?
(2015-11-03, 19:30)slauz Wrote: [ -> ]Thanks Dan - followed your script and managed to install the ipa to my iPad Air on iOS9.02 on Xcode 7.1, but crashes when run. I have allowed my profile to be trusted etc.
script output:
/Users/nsXXXX
Based on that output, you appear to have an old version of the script, the current version is here https://gist.github.com/DanTheMan827/158...4b1462b29a
Some of the early versions didn't actually create launchable apps (they crashed at launch), this was due to the entitlements.plist being generated as binary instead of text.
If the new version still doesn't work, post the crash output of Kodi (if there is any)
Thanks Dan - the output now reflects your latest script. However, still crash when run. Here's the log output. Do I need to be on IOS9.1?
Incident Identifier: 7699599A-AD6E-4D0B-B758-1006A35A651A
CrashReporter Key: 8daa1d982aaa99110018b159be76301a7c526bcf
Hardware Model: iPad4,1
Process: Kodi [327]
Path: /private/var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Kodi
Identifier: org.sur.myKodi
Version: 1.0
Code Type: ARM (Native)
Parent Process: launchd [1]
Date/Time: 2015-11-04 11:50:03.03 +0800
Launch Time: 2015-11-04 11:50:03.03 +0800
OS Version: iOS 9.0.2 (13A452)
Report Version: 105
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000001, 0x00000000e7ffdefe
Triggered by Thread: 0
Filtered syslog:
None found
Dyld Error Message:
Dyld Message: Library not loaded: @executable_path/Frameworks/libsmbclient.dylib.0
Referenced from: /var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Kodi
Reason: no suitable image found. Did find:
/var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Frameworks/libsmbclient.dylib.0: mmap() errno=1 validating first page of '/var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Frameworks/libsmbclient.dylib.0'
/private/var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Frameworks/libsmbclient.dylib.0: mmap() errno=1 validating first page of '/private/var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Frameworks/libsmbclient.dylib.0'
Dyld Version: 369.12
Binary Images:
0x9c000 - 0x1d03fff Kodi armv7 <2fe92c40647d3b399d4f1d3e6b7f2117> /var/mobile/Containers/Bundle/Application/E493B65C-7571-49C0-81EE-B7B4DCA623B1/Kodi.app/Kodi
0x1fe24000 - 0x1fe4bfff dyld armv7s <208fd9e5719439acb248b91286f1dd33> /usr/lib/dyld
Could you please try it with the current version of the script and post the output (please put it inside the code tag).
It appears that either there is a signing issue with my script or a compatibility issue with Kodi
I do want to note that my devices are on 9.1, but I don't have an iPad Air to test (works with an Air 2 though)
This is a sample of proper output
iOS App Signer rev. 35
Extracting .deb file
Copy .mobileprovision to app bundle
Changed app identifier to com.danielradtke.kodi to match the provisioning profile
Signing with entitlements
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
    <key>application-identifier</key>
    <string>C3WJFV3K5U.com.danielradtke.kodi</string>
    <key>com.apple.developer.team-identifier</key>
    <string>C3WJFV3K5U</string>
    <key>get-task-allow</key>
    <true/>
    <key>keychain-access-groups</key>
    <array>
        <string>C3WJFV3K5U.*</string>
    </array>
</dict>
</plist>
./Kodi.app/AppData/AppHome/addons/audiodecoder.modplug/audiodecoder.modplug.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.modplug.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.modplug/audiodecoder.modplug.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.modplug.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.modplug/audiodecoder.modplug.dylib: signed Mach-O thin (armv7) [audiodecoder.modplug]
./Kodi.app/AppData/AppHome/addons/audiodecoder.nosefart/audiodecoder.nosefart.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.nosefart.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.nosefart/audiodecoder.nosefart.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.nosefart.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.nosefart/audiodecoder.nosefart.dylib: signed Mach-O thin (armv7) [audiodecoder.nosefart]
./Kodi.app/AppData/AppHome/addons/audiodecoder.sidplay/audiodecoder.sidplay.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.sidplay.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.sidplay/audiodecoder.sidplay.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.sidplay.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.sidplay/audiodecoder.sidplay.dylib: signed Mach-O thin (armv7) [audiodecoder.sidplay]
./Kodi.app/AppData/AppHome/addons/audiodecoder.snesapu/audiodecoder.snesapu.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.snesapu.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.snesapu/audiodecoder.snesapu.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.snesapu.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.snesapu/audiodecoder.snesapu.dylib: signed Mach-O thin (armv7) [audiodecoder.snesapu]
./Kodi.app/AppData/AppHome/addons/audiodecoder.stsound/audiodecoder.stsound.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.stsound.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.stsound/audiodecoder.stsound.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.stsound.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.stsound/audiodecoder.stsound.dylib: signed Mach-O thin (armv7) [audiodecoder.stsound]
./Kodi.app/AppData/AppHome/addons/audiodecoder.timidity/audiodecoder.timidity.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.timidity.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.timidity/audiodecoder.timidity.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.timidity.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.timidity/audiodecoder.timidity.dylib: signed Mach-O thin (armv7) [audiodecoder.timidity]
./Kodi.app/AppData/AppHome/addons/audiodecoder.vgmstream/audiodecoder.vgmstream.1.0.1.dylib: signed Mach-O thin (armv7) [audiodecoder.vgmstream.1]
./Kodi.app/AppData/AppHome/addons/audiodecoder.vgmstream/audiodecoder.vgmstream.15.2.dylib: signed Mach-O thin (armv7) [audiodecoder.vgmstream.15]
./Kodi.app/AppData/AppHome/addons/audiodecoder.vgmstream/audiodecoder.vgmstream.dylib: signed Mach-O thin (armv7) [audiodecoder.vgmstream]
./Kodi.app/AppData/AppHome/addons/audioencoder.lame/audioencoder.lame.1.0.0.dylib: signed Mach-O thin (armv7) [audioencoder.lame.1]
./Kodi.app/AppData/AppHome/addons/audioencoder.lame/audioencoder.lame.15.2.dylib: signed Mach-O thin (armv7) [audioencoder.lame.15]
./Kodi.app/AppData/AppHome/addons/audioencoder.lame/audioencoder.lame.dylib: signed Mach-O thin (armv7) [audioencoder.lame]
./Kodi.app/AppData/AppHome/addons/audioencoder.vorbis/audioencoder.vorbis.1.0.0.dylib: signed Mach-O thin (armv7) [audioencoder.vorbis.1]
./Kodi.app/AppData/AppHome/addons/audioencoder.vorbis/audioencoder.vorbis.15.2.dylib: signed Mach-O thin (armv7) [audioencoder.vorbis.15]
./Kodi.app/AppData/AppHome/addons/audioencoder.vorbis/audioencoder.vorbis.dylib: signed Mach-O thin (armv7) [audioencoder.vorbis]
./Kodi.app/AppData/AppHome/addons/audioencoder.wav/audioencoder.wav.1.0.0.dylib: signed Mach-O thin (armv7) [audioencoder.wav.1]
./Kodi.app/AppData/AppHome/addons/audioencoder.wav/audioencoder.wav.15.2.dylib: signed Mach-O thin (armv7) [audioencoder.wav.15]
./Kodi.app/AppData/AppHome/addons/audioencoder.wav/audioencoder.wav.dylib: signed Mach-O thin (armv7) [audioencoder.wav]
./Kodi.app/AppData/AppHome/addons/pvr.argustv/pvr.argustv.1.10.11.dylib: signed Mach-O thin (armv7) [pvr.argustv.1]
./Kodi.app/AppData/AppHome/addons/pvr.argustv/pvr.argustv.15.2.dylib: signed Mach-O thin (armv7) [pvr.argustv.15]
./Kodi.app/AppData/AppHome/addons/pvr.argustv/pvr.argustv.dylib: signed Mach-O thin (armv7) [pvr.argustv]
./Kodi.app/AppData/AppHome/addons/pvr.demo/pvr.demo.1.10.7.dylib: signed Mach-O thin (armv7) [pvr.demo.1]
./Kodi.app/AppData/AppHome/addons/pvr.demo/pvr.demo.15.2.dylib: signed Mach-O thin (armv7) [pvr.demo.15]
./Kodi.app/AppData/AppHome/addons/pvr.demo/pvr.demo.dylib: signed Mach-O thin (armv7) [pvr.demo]
./Kodi.app/AppData/AppHome/addons/pvr.dvblink/pvr.dvblink.1.10.9.dylib: signed Mach-O thin (armv7) [pvr.dvblink.1]
./Kodi.app/AppData/AppHome/addons/pvr.dvblink/pvr.dvblink.15.2.dylib: signed Mach-O thin (armv7) [pvr.dvblink.15]
./Kodi.app/AppData/AppHome/addons/pvr.dvblink/pvr.dvblink.dylib: signed Mach-O thin (armv7) [pvr.dvblink]
./Kodi.app/AppData/AppHome/addons/pvr.dvbviewer/pvr.dvbviewer.1.10.35.dylib: signed Mach-O thin (armv7) [pvr.dvbviewer.1]
./Kodi.app/AppData/AppHome/addons/pvr.dvbviewer/pvr.dvbviewer.15.2.dylib: signed Mach-O thin (armv7) [pvr.dvbviewer.15]
./Kodi.app/AppData/AppHome/addons/pvr.dvbviewer/pvr.dvbviewer.dylib: signed Mach-O thin (armv7) [pvr.dvbviewer]
./Kodi.app/AppData/AppHome/addons/pvr.filmon/pvr.filmon.0.5.9.dylib: signed Mach-O thin (armv7) [pvr.filmon.0]
./Kodi.app/AppData/AppHome/addons/pvr.filmon/pvr.filmon.15.2.dylib: signed Mach-O thin (armv7) [pvr.filmon.15]
./Kodi.app/AppData/AppHome/addons/pvr.filmon/pvr.filmon.dylib: signed Mach-O thin (armv7) [pvr.filmon]
./Kodi.app/AppData/AppHome/addons/pvr.hts/pvr.hts.15.2.dylib: signed Mach-O thin (armv7) [pvr.hts.15]
./Kodi.app/AppData/AppHome/addons/pvr.hts/pvr.hts.2.1.18.dylib: signed Mach-O thin (armv7) [pvr.hts.2]
./Kodi.app/AppData/AppHome/addons/pvr.hts/pvr.hts.dylib: signed Mach-O thin (armv7) [pvr.hts]
./Kodi.app/AppData/AppHome/addons/pvr.iptvsimple/pvr.iptvsimple.1.11.5.dylib: signed Mach-O thin (armv7) [pvr.iptvsimple.1]
./Kodi.app/AppData/AppHome/addons/pvr.iptvsimple/pvr.iptvsimple.15.2.dylib: signed Mach-O thin (armv7) [pvr.iptvsimple.15]
./Kodi.app/AppData/AppHome/addons/pvr.iptvsimple/pvr.iptvsimple.dylib: signed Mach-O thin (armv7) [pvr.iptvsimple]
./Kodi.app/AppData/AppHome/addons/pvr.mediaportal.tvserver/pvr.mediaportal.tvserver.1.10.9.dylib: signed Mach-O thin (armv7) [pvr.mediaportal.tvserver.1]
./Kodi.app/AppData/AppHome/addons/pvr.mediaportal.tvserver/pvr.mediaportal.tvserver.15.2.dylib: signed Mach-O thin (armv7) [pvr.mediaportal.tvserver.15]
./Kodi.app/AppData/AppHome/addons/pvr.mediaportal.tvserver/pvr.mediaportal.tvserver.dylib: signed Mach-O thin (armv7) [pvr.mediaportal.tvserver]
./Kodi.app/AppData/AppHome/addons/pvr.mythtv/pvr.mythtv.15.2.dylib: signed Mach-O thin (armv7) [pvr.mythtv.15]
./Kodi.app/AppData/AppHome/addons/pvr.mythtv/pvr.mythtv.2.7.4.dylib: signed Mach-O thin (armv7) [pvr.mythtv.2]
./Kodi.app/AppData/AppHome/addons/pvr.mythtv/pvr.mythtv.dylib: signed Mach-O thin (armv7) [pvr.mythtv]
./Kodi.app/AppData/AppHome/addons/pvr.nextpvr/pvr.nextpvr.1.10.8.dylib: signed Mach-O thin (armv7) [pvr.nextpvr.1]
./Kodi.app/AppData/AppHome/addons/pvr.nextpvr/pvr.nextpvr.15.2.dylib: signed Mach-O thin (armv7) [pvr.nextpvr.15]
./Kodi.app/AppData/AppHome/addons/pvr.nextpvr/pvr.nextpvr.dylib: signed Mach-O thin (armv7) [pvr.nextpvr]
./Kodi.app/AppData/AppHome/addons/pvr.njoy/pvr.njoy.1.10.7.dylib: signed Mach-O thin (armv7) [pvr.njoy.1]
./Kodi.app/AppData/AppHome/addons/pvr.njoy/pvr.njoy.15.2.dylib: signed Mach-O thin (armv7) [pvr.njoy.15]
./Kodi.app/AppData/AppHome/addons/pvr.njoy/pvr.njoy.dylib: signed Mach-O thin (armv7) [pvr.njoy]
./Kodi.app/AppData/AppHome/addons/pvr.pctv/pvr.pctv.0.1.11.dylib: signed Mach-O thin (armv7) [pvr.pctv.0]
./Kodi.app/AppData/AppHome/addons/pvr.pctv/pvr.pctv.15.2.dylib: signed Mach-O thin (armv7) [pvr.pctv.15]
./Kodi.app/AppData/AppHome/addons/pvr.pctv/pvr.pctv.dylib: signed Mach-O thin (armv7) [pvr.pctv]
./Kodi.app/AppData/AppHome/addons/pvr.stalker/pvr.stalker.0.8.4.dylib: signed Mach-O thin (armv7) [pvr.stalker.0]
./Kodi.app/AppData/AppHome/addons/pvr.stalker/pvr.stalker.15.2.dylib: signed Mach-O thin (armv7) [pvr.stalker.15]
./Kodi.app/AppData/AppHome/addons/pvr.stalker/pvr.stalker.dylib: signed Mach-O thin (armv7) [pvr.stalker]
./Kodi.app/AppData/AppHome/addons/pvr.vbox/pvr.vbox.1.3.9.dylib: signed Mach-O thin (armv7) [pvr.vbox.1]
./Kodi.app/AppData/AppHome/addons/pvr.vbox/pvr.vbox.15.2.dylib: signed Mach-O thin (armv7) [pvr.vbox.15]
./Kodi.app/AppData/AppHome/addons/pvr.vbox/pvr.vbox.dylib: signed Mach-O thin (armv7) [pvr.vbox]
./Kodi.app/AppData/AppHome/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.1.10.10.dylib: signed Mach-O thin (armv7) [pvr.vdr.vnsi.1]
./Kodi.app/AppData/AppHome/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.15.2.dylib: signed Mach-O thin (armv7) [pvr.vdr.vnsi.15]
./Kodi.app/AppData/AppHome/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.dylib: signed Mach-O thin (armv7) [pvr.vdr.vnsi]
./Kodi.app/AppData/AppHome/addons/pvr.vuplus/pvr.vuplus.1.10.7.dylib: signed Mach-O thin (armv7) [pvr.vuplus.1]
./Kodi.app/AppData/AppHome/addons/pvr.vuplus/pvr.vuplus.15.2.dylib: signed Mach-O thin (armv7) [pvr.vuplus.15]
./Kodi.app/AppData/AppHome/addons/pvr.vuplus/pvr.vuplus.dylib: signed Mach-O thin (armv7) [pvr.vuplus]
./Kodi.app/AppData/AppHome/addons/pvr.wmc/pvr.wmc.0.5.8.dylib: signed Mach-O thin (armv7) [pvr.wmc.0]
./Kodi.app/AppData/AppHome/addons/pvr.wmc/pvr.wmc.15.2.dylib: signed Mach-O thin (armv7) [pvr.wmc.15]
./Kodi.app/AppData/AppHome/addons/pvr.wmc/pvr.wmc.dylib: signed Mach-O thin (armv7) [pvr.wmc]
./Kodi.app/Frameworks/libass.5.dylib: signed Mach-O thin (armv7) [libass.5]
./Kodi.app/Frameworks/libbluray.1.dylib: signed Mach-O thin (armv7) [libbluray.1]
./Kodi.app/Frameworks/libcurl.4.dylib: signed Mach-O thin (armv7) [libcurl.4]
./Kodi.app/Frameworks/libmpeg2.0.dylib: signed Mach-O thin (armv7) [libmpeg2]
./Kodi.app/Frameworks/libnfs.4.dylib: signed Mach-O thin (armv7) [libnfs.4]
./Kodi.app/Frameworks/libplist.1.dylib: signed Mach-O thin (armv7) [libplist.1]
./Kodi.app/Frameworks/librtmp.1.dylib: signed Mach-O thin (armv7) [librtmp.1]
./Kodi.app/Frameworks/libshairplay.0.dylib: signed Mach-O thin (armv7) [libshairplay.0]
./Kodi.app/AppData/AppHome/addons/library.kodi.guilib/libKODI_guilib-arm-osx.so: signed Mach-O thin (armv7) [libKODI_guilib-arm-osx]
./Kodi.app/AppData/AppHome/addons/library.xbmc.addon/libXBMC_addon-arm-osx.so: signed Mach-O thin (armv7) [libXBMC_addon-arm-osx]
./Kodi.app/AppData/AppHome/addons/library.xbmc.codec/libXBMC_codec-arm-osx.so: signed Mach-O thin (armv7) [libXBMC_codec-arm-osx]
./Kodi.app/AppData/AppHome/addons/library.xbmc.pvr/libXBMC_pvr-arm-osx.so: signed Mach-O thin (armv7) [libXBMC_pvr-arm-osx]
./Kodi.app/AppData/AppHome/system/hdhomerun-arm-osx.so: signed Mach-O thin (armv7) [hdhomerun-arm-osx]
./Kodi.app/AppData/AppHome/system/ImageLib-arm-osx.so: signed Mach-O thin (armv7) [ImageLib-arm-osx]
./Kodi.app/AppData/AppHome/system/libcpluff-arm-osx.so: signed Mach-O thin (armv7) [libcpluff-arm-osx]
./Kodi.app/AppData/AppHome/system/libexif-arm-osx.so: signed Mach-O thin (armv7) [libexif-arm-osx]
./Kodi.app/AppData/AppHome/system/players/dvdplayer/libdvdnav-arm-osx.so: signed Mach-O thin (armv7) [libdvdnav-arm-osx]
./Kodi.app/Frameworks/lib/python2.6/site-packages/PIL/_imaging.so: signed Mach-O thin (armv7) [_imaging]
./Kodi.app/Frameworks/lib/python2.6/site-packages/PIL/_imagingft.so: signed Mach-O thin (armv7) [_imagingft]
./Kodi.app/Frameworks/lib/python2.6/site-packages/PIL/_imagingmath.so: signed Mach-O thin (armv7) [_imagingmath]
./Kodi.app/Frameworks/libsmbclient.dylib.0: signed Mach-O thin (armv7) [libsmbclient.dylib.0]
./Kodi.app/AppData/AppHome/addons/visualization.glspectrum/opengl_spectrum.vis: signed Mach-O thin (armv7) [opengl_spectrum]
./Kodi.app/AppData/AppHome/addons/visualization.waveform/Waveform.vis: signed Mach-O thin (armv7) [Waveform]
./Kodi.app: replacing existing signature
./Kodi.app: signed bundle with Mach-O thin (armv7) [com.danielradtke.kodi]
Deleted existing output file
Packaging...
Done, the package is located at /Users/Daniel/Documents/IPA Files/signed/com.danielradtke.kodi-signed.ipa
Hi Dan
I ran the latest script as you mentioned. The output is below:
iOS App Signer rev. 33
Changed app identifier to org.sur.myKodi to match the provisioning profile
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.modplug/audiodecoder.modplug.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.modplug/audiodecoder.modplug.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.modplug/audiodecoder.modplug.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.nosefart/audiodecoder.nosefart.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.nosefart/audiodecoder.nosefart.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.nosefart/audiodecoder.nosefart.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.sidplay/audiodecoder.sidplay.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.sidplay/audiodecoder.sidplay.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.sidplay/audiodecoder.sidplay.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.snesapu/audiodecoder.snesapu.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.snesapu/audiodecoder.snesapu.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.snesapu/audiodecoder.snesapu.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.stsound/audiodecoder.stsound.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.stsound/audiodecoder.stsound.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.stsound/audiodecoder.stsound.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.timidity/audiodecoder.timidity.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.timidity/audiodecoder.timidity.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.timidity/audiodecoder.timidity.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.vgmstream/audiodecoder.vgmstream.1.0.1.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.vgmstream/audiodecoder.vgmstream.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audiodecoder.vgmstream/audiodecoder.vgmstream.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.lame/audioencoder.lame.1.0.0.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.lame/audioencoder.lame.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.lame/audioencoder.lame.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.vorbis/audioencoder.vorbis.1.0.0.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.vorbis/audioencoder.vorbis.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.vorbis/audioencoder.vorbis.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.wav/audioencoder.wav.1.0.0.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.wav/audioencoder.wav.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/audioencoder.wav/audioencoder.wav.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.argustv/pvr.argustv.1.10.11.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.argustv/pvr.argustv.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.argustv/pvr.argustv.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.demo/pvr.demo.1.10.7.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.demo/pvr.demo.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.demo/pvr.demo.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.dvblink/pvr.dvblink.1.10.9.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.dvblink/pvr.dvblink.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.dvblink/pvr.dvblink.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.dvbviewer/pvr.dvbviewer.1.10.35.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.dvbviewer/pvr.dvbviewer.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.dvbviewer/pvr.dvbviewer.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.filmon/pvr.filmon.0.5.9.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.filmon/pvr.filmon.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.filmon/pvr.filmon.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.hts/pvr.hts.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.hts/pvr.hts.2.1.18.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.hts/pvr.hts.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.iptvsimple/pvr.iptvsimple.1.11.5.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.iptvsimple/pvr.iptvsimple.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.iptvsimple/pvr.iptvsimple.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.mediaportal.tvserver/pvr.mediaportal.tvserver.1.10.9.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.mediaportal.tvserver/pvr.mediaportal.tvserver.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.mediaportal.tvserver/pvr.mediaportal.tvserver.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.mythtv/pvr.mythtv.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.mythtv/pvr.mythtv.2.7.4.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.mythtv/pvr.mythtv.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.nextpvr/pvr.nextpvr.1.10.8.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.nextpvr/pvr.nextpvr.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.nextpvr/pvr.nextpvr.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.njoy/pvr.njoy.1.10.7.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.njoy/pvr.njoy.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.njoy/pvr.njoy.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.pctv/pvr.pctv.0.1.11.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.pctv/pvr.pctv.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.pctv/pvr.pctv.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.stalker/pvr.stalker.0.8.4.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.stalker/pvr.stalker.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.stalker/pvr.stalker.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vbox/pvr.vbox.1.3.9.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vbox/pvr.vbox.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vbox/pvr.vbox.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.1.10.10.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vdr.vnsi/pvr.vdr.vnsi.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vuplus/pvr.vuplus.1.10.7.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vuplus/pvr.vuplus.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.vuplus/pvr.vuplus.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.wmc/pvr.wmc.0.5.8.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.wmc/pvr.wmc.15.2.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/pvr.wmc/pvr.wmc.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libass.5.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libbluray.1.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libcurl.4.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libmpeg2.0.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libnfs.4.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libplist.1.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/librtmp.1.dylib with entitlements
Codesigning ./Kodi.app/Frameworks/libshairplay.0.dylib with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/library.kodi.guilib/libKODI_guilib-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/library.xbmc.addon/libXBMC_addon-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/library.xbmc.codec/libXBMC_codec-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/library.xbmc.pvr/libXBMC_pvr-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/system/hdhomerun-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/system/ImageLib-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/system/libcpluff-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/system/libexif-arm-osx.so with entitlements
Codesigning ./Kodi.app/AppData/AppHome/system/players/dvdplayer/libdvdnav-arm-osx.so with entitlements
Codesigning ./Kodi.app/Frameworks/lib/python2.6/site-packages/PIL/_imaging.so with entitlements
Codesigning ./Kodi.app/Frameworks/lib/python2.6/site-packages/PIL/_imagingft.so with entitlements
Codesigning ./Kodi.app/Frameworks/lib/python2.6/site-packages/PIL/_imagingmath.so with entitlements
Codesigning ./Kodi.app/Frameworks/libsmbclient.dylib.0 with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/visualization.glspectrum/opengl_spectrum.vis with entitlements
Codesigning ./Kodi.app/AppData/AppHome/addons/visualization.waveform/Waveform.vis with entitlements
Packaging...
Done, the package is located at /Users/nsdesilva/org.sur.myKodi-signed.ipa
Thanks for helping.
No problem
But, I've updated the script since rev 33 to make it a bit more verbose
Current revision is #35
Hi Dan - do you have link to #35? latest I see is #34 - which crashes. Thanks.
My bad, I guess I forgot to commit that version to github...
It's up now
I was able to do this and install on my iPhone 6s, but now I'm trying to install on my 4th Gen iPad running 9.1 and when I goto devices and try to install I get the error. " App install failed. A valid provisioning profile for this executable was not found."
(2015-11-04, 20:17)kdfannin Wrote: [ -> ]I was able to do this and install on my iPhone 6s, but now I'm trying to install on my 4th Gen iPad running 9.1 and when I goto devices and try to install I get the error. " App install failed. A valid provisioning profile for this executable was not found."
I've updated step 2 of the directions
Basically:
2. Under the app properties, it should say "No matching provisioning profiles found", click "Fix Issue"
If you have additional devices
  • Plug in the device
  • Go to the Product Menu
  • Under Destination, select your device
  • Repeat step 2
You'll then have to continue from step 3 again
That works, thanks for the assistance!
