(2016-02-05, 06:27)AbRASiON Wrote: [ -> ]Just to clarify, I don't need to 'hack' my iPad to do this, right?
I mean I'm not sure I even NEED it right now - but it'd be nice, when I go on holidays, to take some stuff with me.
As for losing MYSQL while away from home, that's cool, I can get over that to be honest. Just playing files from a local file is ok
Thx
No "hack" is needed, you just need to sign Kodi with the free developer account and it will install onto a completely unmodified iDevice
Hopefully someone can answer this I've side loaded the latest tvos kodi build but I seen ipwnstore offering the kodi rc build how can I get does builds?
It was already stated here that this build is some crap stuff ... its the same build i provide but just renamed to jarvis rc or what not. It is NOT jarvis. My builds are always based on latest master (which is krypton in development)...
so the tvos isn't Jarvis it's krypton ?
Thank you for the fast reply is there way to be notified about new release ?
Yes - keep checking the forum
(2016-02-06, 19:53)Vito416 Wrote: [ -> ]Thank you for the fast reply is there way to be notified about new release ?
There's a new release of iOS App Signer that can sign the new version of Kodi
The top shelf still won't work (WIP) but the app runs
ALTHOUGH... there's a broken plist inside the latest deb that causes Xcode to not install it at all...
Here's a version with that plist fixed, just run that through iOS App Signer
The how-to has been updated with instructions to get a working top shelf on tvOS
The top shelf requires Kodi build 20160207 or newer to work with re-signing
(2016-02-05, 06:33)DanTheMan827 Wrote: [ -> ] (2016-02-05, 06:27)AbRASiON Wrote: [ -> ]Just to clarify, I don't need to 'hack' my iPad to do this, right?
Thx
No I realise that, it works great, thank you.
I meant "iFunBox" hacking in the Advancedsettings.XML file for MySQL support, can that also be done on an un modified iOS device?
(2016-02-07, 23:56)AbRASiON Wrote: [ -> ] (2016-02-05, 06:33)DanTheMan827 Wrote: [ -> ] (2016-02-05, 06:27)AbRASiON Wrote: [ -> ]Just to clarify, I don't need to 'hack' my iPad to do this, right?
Thx
Oh, my bad... yeah, you can use that on any iOS device (not Apple TV)
hey very professional - do you do those videos for living?
(2016-02-08, 08:02)Memphiz Wrote: [ -> ]hey very professional - do you do those videos for living?
Nope, just QuickTime, iMovie, and an iPhone (for the audio)
I'm a fairly quick learner
